		woxofswa
				 Posted: Sun Oct 04, 2009 6:00 pm    Post subject: skin pimples |
				As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets.  When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface.
 Is there a prescribed way to deal with said pimples?
 I thought of maybe trying a spring punch and then superfil, but haven't tried that yet.
 Thanks in advance.
  _________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
		ricksked(at)embarqmail.co Guest
				 Posted: Sun Oct 04, 2009 6:22 pm    Post subject: skin pimples |
				Tell the neighbor thanks but no thanks.....  Pop them back in with a body hammer and fill them prior to paint....
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Sun Oct 04, 2009 6:24 pm    Post subject: Re: skin pimples |
				I'm sure there are better methods but I got every little bump and wave out of my skins by pushing the other end of a sharpie against the aluminum.  Use the edge of the back of the marker (not a fine point).  It is just soft enough plastic to work with the aluminum.  Don't hammer on the skin unless you back it up with a lead shot bag or similar.  If you back up the skin with something hard you will thin the aluminum and oil-can it.  I think most people just make sure it is an innee and not an outee and fill it in before painting with filler.
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
		AV8ORJWC
				 Posted: Sun Oct 04, 2009 8:39 pm    Post subject: skin pimples |
				Kent White of OSH Metalworking Class fame has a technique for shrinking the material. It would be considered advanced by some RV-10 builders. There is a hammering technique to limit the additional stretch of material that is worthy of planishing before resorting to weight adding body fillers.
  Wetsuit material laid inside the work area is a great line of defense for natural human occurances.
   John Cox
 Sent: Sun 10/4/2009 7:00 PM
 Subject: RV10-List: skin pimples
  [quote]--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com>  As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets.  When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface.  Is there a prescribed way to deal with said pimples?  -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress     Read this topic online here:  http://forums.matronics.com/viewtopic.php?p=266508#266508
		planesmith(at)hotmail.com Guest
				 Posted: Mon Oct 05, 2009 7:41 am    Post subject: skin pimples |
				If you are interested in pursuing this further Kent has a DVD at https://www.tinmantech.com/html/vid_basic_damage_repair_alu.php. Not all of the techniques are appropriate for working with2024 aluminum C but some work very well.
  Vern Smith #40324
   Subject: RE: skin pimples
 Date: Sun C 4 Oct 2009 21:31:47 -0700
   John Cox
   	  | Quote: | 	 		  --> RV10-List message posted by: "woxofswa" <woxof(at)aol.com>
 As I was riveting my QB wing skin C my well meaning neighbor helped me buck some rivets.  When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped C but unfortunately C the rags didn't get moved enough and sure enough C we ended up with a couple of skin "pimples" on the upper outer skin surface.
 Myron Nelson
 Mesa C AZ
 Emp completed C legacy build fuse in progress
 ky"%4M4}7(wrpppppppppppppppppppppppppppppp 8^E]t.+-fZ+mRǭ' Eyn jj+ ;azfȸb+bz.r.+-Rҹ*m ܆+Iryhik k  7 h!jٮrr6m 'ojj+E]t.+-i0fr(Z(W] kppppppppppppppppppppppppppppppp DH %SPķ &z j(קlڊVj^YŢp kyÆi鬙kx&i鬙kx&==============================2Шnbum({pӅʋ.+pjCexf}jp 0kx&'بm 'oܢ{kkpppppppppppppppppppppppppppppp~m 		 	   		  Hotmail: Powerful Free email with security by Micro='_new'>Get it now.  [quote][b]
