		Lew Gallagher
				 Posted: Tue Oct 06, 2009 9:28 am    Post subject: hat switch relays |
				OK, EE guys.
 We got the relay by aircraft extras (aircraftextras.com) to control the elavator trim through the hat switch.  Not expensive, well made, does the job (Thanks!).
 What I'm wondering is:  if i just got two SPDT 12v relays from radio shack, would it do the same thing?  As you know, I love to tinker and the aircraft extras relay gizmo incorporates a couple of diodes and something else (?) to "protect against inductive sparking generated from relays switching inductive loads such as motors".  How critical is this?  Anybody just go with the relays?
 Later, - Lew amazed-and-bedazzled-by-the-door-latch-braintrust Gallagher
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		Lew Gallagher
				 Posted: Wed Oct 07, 2009 5:55 am    Post subject: Re: hat switch relays |
				While you're thinking about the relays, here's another one:
 Are you isolating left and right grip controls with a switch on the panel?  The schematic that came with the relay board just shows both wired in -- assumes only one pilot will trigger the hat switch?  I've searched the archives and found some with a pretty hefty selector switch.
 Later, - Lew
				 Posted: Wed Oct 07, 2009 7:17 am    Post subject: hat switch relays |
				I wouldn't use the relay setup for nothing.....the fail safe trim system is the only way to go. IMHO...
		marcausman
				 Posted: Thu Oct 08, 2009 7:09 am    Post subject: Re: hat switch relays |
				Just a note to clarify this issue for anyone using the Vertical Power system.   You do not need relays or other boards for the trim. It is all built-in and all solid-state. Also, the pilot and co-pilot inputs are handled appropriately when there is conflicting control inputs between the two.
 On a separate but related note, you also do NOT need to install relays for the door latch annunciator switches. You just run the two switches in series from each door into a switched input pin, and you can change the logic (on when grounded or on when un-grounded) in the setup menus.
  _________________ Marc Ausman
http://www.verticalpower.com  "Move up to a modern electrical system"
RV-7 IO-390 Flying |
				 Posted: Thu Oct 08, 2009 7:53 am    Post subject: hat switch relays |
				Note, though, that the VP only handles 2 trim servos, so if you have
 3, then you will need a relay for the 3rd.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Oct 8, 2009, at 11:09 AM, marcausman wrote:
  the setup menus.
  Marc Ausman
  RV-7 IO-390 Flying
  http://forums.matronics.com/viewtopic.php?p 67102#267102
		dmaib@me.com
  Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
				 Posted: Fri Oct 09, 2009 3:55 am    Post subject: hat switch relays |
				I have pitch, roll, and yaw trim on my VP 200 and don't have any
 relay's. Maybe because I have VP-200 duo. ?
 David Maib
 40559
 On Oct 8, 2009, at 11:46 AM, Jesse Saint wrote:
  Jesse Saint
  Cell: 352-427-0285
  Fax: 815-377-3694
 > <marc(at)verticalpower.com>
 > Marc Ausman
 > RV-7 IO-390 Flying
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
				 Posted: Fri Oct 09, 2009 4:25 am    Post subject: hat switch relays |
				Correct.  You have 2 trims per control unit.
 Do not archive.
 Jesse Saint
 Saint Aviation
 352-427-0285
 On Oct 9, 2009, at 7:53 AM, David Maib <dmaib(at)me.com> wrote:
  David Maib
  40559
 > <jesse(at)saintaviation.com>
 > have 3, then you will need a relay for the 3rd.
 > Jesse Saint
 > Cell: 352-427-0285
 > Fax: 815-377-3694
 >> Marc Ausman
 >> RV-7 IO-390 Flying
		marcausman
				 Posted: Fri Oct 09, 2009 5:24 am    Post subject: Re: hat switch relays |
				Each Control Unit can handle two trim servos. So a system with two control units ("red boxes") can control and display three trim servos.
		Lew Gallagher
				 Posted: Fri Oct 09, 2009 6:15 am    Post subject: hat switch relays |
				Wow, Marc.
 Thanks for your link.  I can see now why others scoff at relays.  At this
 point we can only dream and drool of such an awesome gizmo!
 Later, - Lew
