rickofudall
				 Posted: Fri Oct 09, 2009 2:53 am    Post subject: FAA AC 20-27G |
				The FAA has released the latest version of Advisory Circular 20-27G, "Certification and Operation of Amateur-Built Aircraft". Topics covered are:
 (1) Certificating and operating your amateur-built aircraft,
  (2) What to do and know before building an amateur-built aircraft,
 (3) Designing and constructing your amateur-built aircraft,
 (4) Fabricating and assembling your amateur-built aircraft,
  (5) Registering your amateur-built aircraft,
 (6) Identifying and marking your amateur-built aircraft,
 (7) Applying for certification of your amateur-built aircraft,
 (  FAA inspection of your amateur-built aircraft,
  (9) Issuing an airworthiness certificate for your amateur-built aircraft,
 (10) Flight testing your amateur-built aircraft,
 (11) Operating your amateur-built aircraft after flight testing,
  (12) Amateur-built aircraft built outside the United States and purchased by a U.S. citizen,
 (13) Becoming a repairman for your amateur-built aircraft, and
 (14) General safety recommendations.
 A copy can be downloaded here:
 http://www.faa.gov/documentLibrary/media/Advisory_Circular/AC%2020-27G.pdf
 Rick Girard
