aerobubba(at)earthlink.ne Guest
Posted: Mon Oct 12, 2009 6:17 am Post subject: Control Stick Switches |
Hi Gordon-
| Quote: | Is it proper to have a single ground conductor for all of the stick
switch functions?
| Quote: | Should the PTT be given special consideration and a separate ground path
with perhaps both (to-from) paths shielded.
I elected to run three grounds for my two control sticks. Two of those
grounds go through a progressive switch on the panel. The ON position has
all grounds connected and both sticks are fully functional. The
intermediate position disconnects the ground for all rear seat stick
functions, disabling the stick should there be tiny or otherwise
inappropriate fingers poking around. The OFF position also disables the
rear stick and additionally disables the front stick trim controls. This
provides protection from trim system runaway while leaving the PTT and
other front stick switches active. The progressive switch itself is
located near the throttle, along with the other switches I might like to
operate quickly with my non-flying hand.
I like this configuration, and just offer it up as food for thought. YMMV-
glen matejcek
longg(at)pjm.com Guest
Posted: Mon Oct 12, 2009 7:23 am Post subject: Control Stick Switches |
Glenn,
I concur with the additional grounds save the space provided. In my Ray
Allen stick, they really only provide room for one solid ground to the
stick itself and little room for the remainder of the wires. My pet
peeve with RA is that lack of room. C'mon, just make that cap 1/4
thicker guys.
In defense of myself I made sure to add a circuit breaker to the panel
to drop the whole thing if it decides to try and kill me. I did the same
for the A/P which in my experience has also tried to kill me. If you can
kill it first, there's your safety margin. As grounds go, yes, I have
two separate grounds, one for pilot and co-pilot just to isolate good
grounds.
Glenn
