Control Stick/Flap Switches
bbradburry(at)bellsouth.n
PostPosted: Mon Oct 12, 2009 9:12 am    Post subject: Control Stick/Flap Switches Reply with quote
I have a flap switch wired thru a couple of relays to raise and lower the
flaps. The switch is a double pole double throw type.
I just installed an Infinity grip and there is a single throw single pole
switch on the grip that I would like to wire into the system to also control
the flap. I realize the in order to use either switch, the other switch
will have to be off.
The problem is that I am electron deficient and have no idea of how to wire
this up. Any help from the list would be greatly appreciated.
Bill B
Bruce(at)glasair.org
PostPosted: Mon Oct 12, 2009 9:31 am    Post subject: Control Stick/Flap Switches Reply with quote
It's a bad idea to put control of any function on a control stick that
if inadvertently activated could jeopardize the safety of the aircraft.
Bruce
www.Glasair.org
PostPosted: Mon Oct 12, 2009 10:13 am    Post subject: Control Stick/Flap Switches Reply with quote
Hmmm.
It is a bad idea to put such a situation anywhere!
peterlaurence6(at)gmail.c
My 2 cents--
Keep the stick simple and place the flap switch on the panel.
Peter
On Mon, Oct 12, 2009 at 1:27 PM, Bruce Gray <Bruce(at)glasair.org (Bruce(at)glasair.org)> wrote:
[quote]--> AeroElectric-List message posted by: "Bruce Gray" <Bruce(at)Glasair.org>
Bruce
www.Glasair.org
jbr79r(at)yahoo.com
PostPosted: Mon Oct 12, 2009 3:53 pm    Post subject: Control Stick/Flap Switches Reply with quote
I have my flap switch on the throttle and trim on the stick. Works great for me
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Mon, October 12, 2009 11:02:08 AM
Subject: RE: Control Stick/Flap Switches
--> AeroElectric-List message posted by: "Bill Bradburry" <bbradburry(at)bellsouth.net (bbradburry(at)bellsouth.net)>
Hmmm.
Eric M. Jones
PostPosted: Tue Oct 13, 2009 5:44 am    Post subject: Re: Control Stick/Flap Switches Reply with quote
A note on control stick switches:
Make sure they are environmentally sealed for the harshest jungle-like conditions encountered under sweaty palms.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
Tim Olson
PostPosted: Tue Oct 13, 2009 9:10 am    Post subject: Control Stick/Flap Switches Reply with quote
Absolutely agree with that one Bruce! A co-policy I have is
that all control moving circuits should have breakers, not
fuses, because you want them pull-able.
Tim Olson - RV-10 N104CD
Bruce
www.Glasair.org
MauleDriver(at)nc.rr.com
PostPosted: Tue Oct 13, 2009 10:13 am    Post subject: Control Stick/Flap Switches Reply with quote
Tim, I realize that I've followed the same policy in my fuse-centric
panel. Or at least I think I have.... So to compare notes:
I have 4 pull-able/reset-able breakers in my panel:
- (2) for the 2 B&C alternator controllers for proper operation of the
crow bar OV protection
- (1) for my flaps with FPS
- (1) for my AP
The rest are all fuses on a 2 bus Z-14
I didn't have a policy per se, but my thinking for the 2 latter fuses was:
- the flap motor could be overpowered by extension at high speeds - so a
reset-able capability is desirable since it is a control surface
- The pull-able breaker gives me an emergency off switch for the autopilot
I should add that I have the Safety Trim system which has a trim shut
off and other safety related functions.
> Bruce
> www.Glasair.org
Speedy11(at)aol.com
PostPosted: Tue Oct 13, 2009 5:33 pm    Post subject: Control Stick/Flap Switches Reply with quote
Bill,
If you can do it, Jim's setup is ideal.
Stan Sutterfield
me
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Speedy11(at)aol.com
Bill,
There is nothing wrong with or dangerous about putting your flap switch on the control stick. However, one must use due diligence when activating a switch on the stick when one has more than one switch on the stick. For example, I have flap switch, trim switch and starter switch all on the top of my stick. I also have PTT, AP disconnect and smoke on the stick. However, I've flown fighters for years and I'm comfortable with HOTAS.  It would be easy to accidentally activate the flaps when reaching for the trim (I disable my starter button with a switch when flying). If the flaps are accidentally started down, you simply switch them back up immediately.
So, while it is not dangerous to have flaps (or any other switch) on the stick, it might be prudent to put it on the panel or near the throttle if you are a private pilot who trained in aircraft that used a panel mounted flap switch. If you prefer to have switches on the stick, then wire it that way.
I would tell you how I wired mine, but mine is unique and may not fit your needs. Is there another builder nearby that can help?
If you can't find help, contact me directly (off the forum) and I'll talk you through my installation.
Stan Sutterfield
My 2 cents--
Peter
Bruce
www.Glasair.org
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill
Bradburry
Sent: Monday, October 12, 2009 1:02 PM
Subject: AeroElectric-List: Control Stick/Flap Switches
<bbradburry(at)bellsouth.net>
the
pole
control
wire
Bill B
trigo(at)mail.telepac.pt
PostPosted: Wed Oct 14, 2009 3:25 am    Post subject: Control Stick/Flap Switches Reply with quote
You can put a flap switch on the control stick and install an airspeed relay like this
http://www.aircraftextras.com/RelaySpeedCont1.htm
which will give you accidental flap deployment protection.
I know that this is not the KIS way, but it is a way.
I’m not related to “aircraft extras”, just an happy customer (although didn’t test it in flight yet)
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: quarta-feira, 14 de Outubro de 2009 1:45
Subject: Re: Control Stick/Flap Switches
Bill,
Stan Sutterfield
My 2 cents--
Peter
PostPosted: Wed Oct 14, 2009 6:56 am    Post subject: Control Stick/Flap Switches Reply with quote
Interesting. I would caution folks about urges
to add "bells and whistles" to their projects
"just because we can". The FARS began speaking to
the style, location and operation of flap and
landing gear handles very early on. Years of
experience with mis-operation of the simplest
of control systems drove the heavy duty thinkers
to advise (if not demand) standards that go
directly to reduction of accident due to error
(human factors) and/or failure (equipment
lacking robustness), or failure tolerance
(UN-elegant design).
The product cited in the link above is an interesting
discussion point. Diaphragm switches for low delta-
pressure (IAS sensors) are not very robust. Hardly
a device I could get qualified onto a TC aircraft
for the goal of "increased safety" . . .
[img]cid:.0[/img]
The relay board in the picture uses "mash-em"
terminal strips not unlike those used in other
products offered to the OBAM aviation community
[img]cid:.1[/img]
again . . . another technology that I would not even attempt
to qualify onto a TC aircraft. No gas tightness of electrical
connections, no support of wires adjacent to the stress-riser
at the connections.
I can only counsel caution when the siren call of "change"
is strong. It's prudent to understand the foundations
upon which the "status quo" exists. The elegant design
philosophy calls for lowest practical count of robust
parts and processes combined with an accommodation of
human frailties. What's the return on investment for replacing
simple, traditional flap and gear controls with new
whiz-bangs? Especially whiz-bangs that intended to make
add "convenience" to a 2-second action that happens 4x per
flight cycle? How does the proposed change improve or
degrade overall system reliability? What do the new whiz-
bangs offer in terms of risk for unintended operations?
Twice the parts count says you're twice as likely to
experience a failure-to-operate event.
May I further suggest that products like those illustrated
above do not move the state of our art in the right
direction?
( -Thomas Paine 1776- )
 Filesize:  139.51 KB
 Viewed:  10350 Time(s)
 Filesize:  26.66 KB
jbr79r(at)yahoo.com
PostPosted: Wed Oct 14, 2009 9:47 am    Post subject: Control Stick/Flap Switches Reply with quote
Thanks Stan
It has worked great for 4 yrs. I also have the flip flop radio, auto pilot disconnect, IDENT. and strobes on the stick buttons.
I have been happy with this arrangement.
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Tue, October 13, 2009 5:47:44 PM
Bill,
Stan Sutterfield
me
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
jbr79r(at)yahoo.com
PostPosted: Wed Oct 14, 2009 10:50 am    Post subject: Control Stick/Flap Switches Reply with quote
In my last reply I failed to mention a few things. Normally the throttle is full forward from takeoff to nearing approach. The switch has to be pressed up or down. Very difficult to inadvertently activate and if activated with the gear up the gear warning horn would sound. If it failed it would not be a safety of flight concern. No other electrical clutter needs be installed. I find this no more complex or failure prone than a switch on the panel
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Bill,
Stan Sutterfield
me
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Speedy11(at)aol.com
PostPosted: Thu Oct 15, 2009 4:44 pm    Post subject: Control Stick/Flap Switches Reply with quote
A good point, Carlos. I'd forgotten about that option.
Stan Sutterfield
like this
