Posted: Mon Oct 12, 2009 10:52 am Post subject: Tri-gear Jamar brakes |
Hi! Frans
I'm not familiar with the JAMAR term you use. I have trike foot brakes not
finger brakes. However I forced fluid up from the bottom using a lemonade
bottle linked to the nipple (You will be using a large vets SYRINGE)
However, have you realized that the bleed nipple at the brake end needs to
be on the bottom of the slave cylinder and the pipe connection to the master
cylinders need to be on the top?
Bob Harrison G-PTAG
frans(at)paardnatuurlijk. Guest
Posted: Mon Oct 12, 2009 11:52 am Post subject: Tri-gear Jamar brakes |
Robert C Harrison wrote:
Hi Robert,
Quote: | However, have you realized that the bleed nipple at the brake end needs to
Why would that be?
According to the manual, the bleed nipple should point forward (which
happens to be the upper connector). I felt no suspicion doing it that
way, because air tends to rise, so it seemed logical to have the bleed
nipple on top, that way any air in the caliper will collect near the
bleed nipple. Apart from that, the brake line will then nicely follow
the leg so the brake line won't dangle into the air.
Maybe you are right that it should be the other way around, but could
you please also explain why?
Frans
Posted: Mon Oct 12, 2009 12:41 pm Post subject: Tri-gear Jamar brakes |
Hi! Frans.
If you are filling oil from the bottom,(that is with the bleed (filling)
nipple at the bottom, as you say air rises so there will not be a pocket of
it in the slave cylinder top, you will expel all the air out of the master
cylinder. If the bleed nipple is at the top of the slave cylinder and you
are trying to expel air downwards and back to the master cylinder it won't
oblige!
You are actually NOT using it as a "bleed" nipple in this application you
are using it as a filling nipple to expel the air upwards and to the master
cylinder.
Hope you understand? Exasperating isn't it ?
Bob Harrison G-PTAG
kheindl(at)msn.com Guest
Posted: Mon Oct 12, 2009 1:26 pm Post subject: Tri-gear Jamar brakes |
Frans C
look at any Cessna etc. C you will find the 'bleed'nipple at the bottom.
Karl
[quote] From: ptag.dev(at)tiscali.co.uk
Subject: RE: Tri-gear Jamar brakes
Date: Mon C 12 Oct 2009 21:40:42 +0100
--> Europa-List message posted by: "Robert C Harrison" <ptag.dev(at)tiscali.co.uk>
Hi! Frans.
If you are filling oil from the bottom C(that is with the bleed (filling)
nipple at the bottom C as you say air rises so there will not be a pocket of
it in the slave cylinder top C you will expel all the air out of the master
oblige!
cylinder.
Bob Harrison G-PTAG
Posted: Mon Oct 12, 2009 1:35 pm Post subject: Tri-gear Jamar brakes |
Quote: | Hi! Frans. If you are filling oil from the bottom,(that is with the
bleed (filling) nipple at the bottom, as you say air rises so there
will not be a pocket of it in the slave cylinder top, you will expel
all the air out of the master cylinder. If the bleed nipple is at the
top of the slave cylinder and you are trying to expel air downwards
and back to the master cylinder it won't oblige! You are actually NOT
using it as a "bleed" nipple in this application you are using it as
a filling nipple to expel the air upwards and to the master cylinder.
Ok, got that. But I never intended to bleed it this way, but just
"normally" like with cars: top up the reservoir, push the brake and open
the nipple, close it, release brake, and repeat until the air is gone.
Actually, this is still what I intend to do after I initially filled the
system from the bottom up.
If the system is bleed entirely by pumping in fluid from the bottum up,
then your configuration makes more sense. Although it will be difficult
to route the brake line. If you route it down to the leg and then
upwards, then again there is a pocket where air can collect. The only
solution is then to route it upwards directly from the caliper, which is
a problem if you have the leg fairings installed.
Frans
Posted: Mon Oct 12, 2009 1:43 pm Post subject: Tri-gear Jamar brakes |
For what it's worth:
"look at any Cessna etc., you will find the 'bleed'nipple at the bottom.:
I owned a 1948 Cessna 170 that had Clevland brakes with bleed screw on bottom.
Always a bugger to bleed. Filling from bleed up helped, but also would help early on if would loosen connection going into wheel cylinder, let air out bottom up, and use that connection as a bleed from top down using wheel cylinder to pressurize and close connection before releasing pedal.
1948 had a different master cylinder compared to newer ones.
Just a friendly reminder, don't let Dot 5 brake fluid out of it's container anywhere near your aeroplane or shop if you need to do any layups, fill or paint. "IT IS SILICONE"!
Ron Parigoris
Visit - www.EuropaOwners.org
Posted: Mon Oct 12, 2009 1:55 pm Post subject: Tri-gear Jamar brakes |
Frans your plan is depending on having an adequate reservoir.
How will you change the pipe connector and nipple over without the ingress
of air? On mine there is no reservoir. Once filled from bottom up and all
air is gone I just fill the master cylinders to the top of the plug threads
and slowly screw in the plug to allow the excess to squeeze out of the
threads with rags packed round to soak up any spillage.
But don't let me confuse you .....mine are not finger brakes and not Jamar !
Bob.
