		kearney
				 Posted: Sun Oct 11, 2009 8:52 am    Post subject: Final Fitting of the canopy |
				Hi
 Yesterday was a red letter day as I put my canopy on for the last time and glassed it into the door frame. I am no looking at riveting up the side flanges to the fuse. I do have a question however. The plans suggest sealing the rear canopy flange to the tail cone forward top skin to prevent leaks.
 Is there any need to do something similar to the side flanges that fit inside the fuse skins and rest on top of the longerons?
 Inquiring minds need to know…..
 Les
 40643 – 90% finished with the cabin top f/g – only 90% to go
		Jim Berry
				 Posted: Sun Oct 11, 2009 9:05 am    Post subject: Re: Final Fitting of the canopy |
				Les,
 I think most people are putting a layer of fiberglass over the rivet line to hide the pull rivets, which effectively water proofs this area. Congratulations on getting the canopy anchored. Now you can get on to fitting the doors. Have fun with that.
 Jim Berry
 40482
 N15JB
		kearney
				 Posted: Sun Oct 11, 2009 11:43 am    Post subject: Final Fitting of the canopy |
				Hi Jim
 I was wondering about glassing that rivet line.
 If the truth be known, I have my doors fitted already. I just clecoed the
 top on while fitting the doors. This, as it turns out, was a good thing as
 it allowed the port door sill (fibreglass) to be relocated about 1/8"
 inboard so my door seals weren't compressed too much. This makes the door
 very easy to close. I expect as the seals get a memory it will be easy
 still. FYI, I am using the McMaster Carr seals and had them installed when
 fitting the doors.
 I all I have to do now is to adjust the door gap and then I can move on to
 something that doesn't involve sanding.
 Cheers
 Les
		Ron B.
				 Posted: Mon Oct 12, 2009 2:15 pm    Post subject: Re: Final Fitting of the canopy |
				That's what you think. It never ends.
 Ron
		Phil.Perry(at)netapp.com Guest
				 Posted: Tue Oct 13, 2009 7:05 am    Post subject: Final Fitting of the canopy |
				Is this the Fiberglass tape that everyone is using to hide those rivet
 lines on the side of the canopy and cowling?
 http://www.aircraftspruce.com/catalog/cmpages/etapes.php
 Phil
		Jim Berry
				 Posted: Tue Oct 13, 2009 8:29 am    Post subject: Re: Final Fitting of the canopy |
				Phil,
 I used 2 oz. tape for this. Heavier(thicker) tape is going to make it harder to get a smooth transition from the canopy to fuselage. I also used 2 oz. to cover the hinge rivet lines on the cowling and control surface fairings.
 Jim Berry
 40482
 N15JB
		MauleDriver(at)nc.rr.com Guest
				 Posted: Tue Oct 13, 2009 8:56 am    Post subject: Final Fitting of the canopy |
				Where did you get the 2oz tape?
 Bill Watson
 40605
 Jim Berry wrote:
  Phil,
  Jim Berry
  40482
  N15JB
  http://forums.matronics.com/viewtopic.php?p 67753#267753
				 Posted: Tue Oct 13, 2009 10:24 am    Post subject: Final Fitting of the canopy |
				Aerospace composite products:
  http://www.acp-composites.com/home.php Great site with so many goodies.
  	  | Quote: | 	 		   Date: Tue C 13 Oct 2009 12:55:41 -0400
  Subject: Re: RV10-List: Re: Final Fitting of the canopy
  --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
  Bill Watson
  40605
  Jim Berry wrote:
  > --> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net>
  > Phil C
  > Jim Berry
  > 40482
  > N15JB
  > http://forums.matronics.com/viewtopic.php?p=267753#267753
 &g============
		Jim Berry
				 Posted: Tue Oct 13, 2009 11:01 am    Post subject: Re: Final Fitting of the canopy |
				Bill,
 I got the 2 oz. tape from my local West Systems dealer, although it is not a West System product. I think most any fiberglass supplier will have it.
 Jim Berry
 40482
