WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Tue Oct 13, 2009 4:54 pm Post subject: What's your prop size/ prop clearance? |
So I currently have a 66" GSC that I have decided I should just replace over trying to adjust. Yes, i will look for any reason to upgrade. I have decided I want to go with an Ivoprop ground adjustable. I was planning on a 68" 3 blade ultralight, however when I called Ivo and talked to a salesman he suggested a 72" 2 blade medium based on the 3:1 gearbox I have. So here are the questions;
Anyone have a 582 with a 3:1 gearbox? What prop are you running?
Anyone have a 72" prop on a KF mod 1, 2, 3 and how is your ground clearance?
According to my measurements which are a little fuzzy due to the plane being on a trailer gives me about 17" of ground clearance in a level attitude, so a 72" should give me about 14" clearance. I don't see any reason this should be an issue and it sounds well within limits. Am I missing anything?
The salesman was talking about the 72" 2 blade having about 20# more thrust then the 68" 3 blade and that sounds good to me. Thanks for the information guys.
James
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Guy Buchanan
Posted: Tue Oct 13, 2009 5:31 pm Post subject: What's your prop size/ prop clearance? |
At 05:54 PM 10/13/2009, you wrote:
| Quote: | Anyone have a 582 with a 3:1 gearbox? What prop are you running?
70" Warp 3-blade.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Pat Reilly
Posted: Tue Oct 13, 2009 6:18 pm Post subject: What's your prop size/ prop clearance? |
James, I bought my FWF 582 with a 72" Warp Drive prop. It had flown on a model 3 for 100 hrs. I converted to a Lowell Fitt bush gear so now I have at least 4" more ground clearance. But, the 72" blade evidently had no ground clearance problem on the stock KF model 3 gear previous to my purchase.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Tue, Oct 13, 2009 at 7:54 PM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
[quote]--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.php?p=267826#267826
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
dave
Posted: Wed Oct 14, 2009 2:45 am Post subject: Re: What's your prop size/ prop clearance? |
IVO does not like to mix 3 bladed props with 3 to 1 gearbox due to harmonic issues. I run 3 blade warp on my 3 to 1 box with no issues. I have run other 3 blades props as well with no issues yet. GSC 68: a good working prop.
IVO medium you will only be able to run 2 blades but they work good and sound good.
Call Bob Robertson today 1-866-418-4164 toll free. HE had a demo 72 " 2 blade IVO Medium there. Not sure if he still has but it might be priced right if he still does.
I have used about 10 different props on the same engine combo that you have and they all have their attribute and all perform with a few % of each other.
I have a 70 or 72 " in flight adjustable GSC hub with WARP blades with SS leading edges here . 1400$ ( brand new is well over 2k$ ) this one has new blades.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
akflyer
Posted: Wed Oct 14, 2009 9:24 am Post subject: Re: What's your prop size/ prop clearance? |
I have about 40 hrs on mine with 3:1 gears and the IVO 72" 3 blade ultralight IFA with NO issues. I played around going back and forth between 2.62:1 and 3:1 gears and have decided to stick with the 3:1 on floats. I put the SS tape between the hub blades to check for movement issues, but so far, none have been detected. I think the big issues were with the older blades that had the aluminum inserts in the blades. The hub would tighten against the aluminum inserts and would not properly clamp the blades.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Guy Buchanan
Posted: Wed Oct 14, 2009 2:25 pm Post subject: What's your prop size/ prop clearance? |
At 03:45 AM 10/14/2009, you wrote:
| Quote: | I have a 70 or 72 " in flight adjustable GSC hub with WARP blades
Dave,
What is the weight of this system? Do you have more information on it?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
thesupe(at)hotmail.com Guest
Posted: Wed Oct 14, 2009 4:11 pm Post subject: What's your prop size/ prop clearance? |
I ran a 3 blade IVO on my first Avid which had a 3-1 gearbox with no problems. I think you are supposed to have the crosshatch pattern on the hub to better grip the blades. If you have the aluminum inserts C the hub should be slightly counterbored where the inserts are so the hub grips the body of the blades. That's what I remember reading on the IVO site C and I had no problems with the prop. Take care C Jim Chuk
[quote] Subject: Kitfox-List: Re: What's your prop size/ prop clearance?
Date: Wed C 14 Oct 2009 10:24:22 -0700
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
I have about 40 hrs on mine with 3:1 gears and the IVO 72" 3 blade ultralight IFA with NO issues. I played around going back and forth between 2.62:1 and 3:1 gears and have decided to stick with the 3:1 on floats. I put the SS tape between the hub blades to check for movement issues C but so far C none have been detected. I think the big issues were with the older blades that had the aluminum inserts in the blades. The hub would tighten against the aluminum inserts and would not properly clamp the blades.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p=267935#267935
Hotmail: Free C trusted aect/01/' target='_new'>Get it now.
dave
Posted: Wed Oct 14, 2009 4:33 pm Post subject: Re: What's your prop size/ prop clearance? |
Not sure exactly.
I could weigh this week if you like , just remind me.
Dave
http://www.ultralightprops.com/gta_inflight_adjustable_props/adjustprops.htm
Dave,
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting |
WurlyBird
Posted: Wed Oct 14, 2009 5:40 pm Post subject: Re: What's your prop size/ prop clearance? |
Hey Dave, speaking of "remind me", are you still interested in those brake components??
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sun Oct 18, 2009 3:52 am Post subject: Re: What's your prop size/ prop clearance? |
Dave;
I'm interested in that GSC IFA prop. I've e.mailed you off list.
Cheers
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
WurlyBird
Posted: Sun Oct 18, 2009 10:51 am Post subject: Re: What's your prop size/ prop clearance? |
Here is what IVOProp told me about 3 blades and 3:1 trannys;
Rotax 503, 532, 582, 583, 618 with 3:1, 3.47:1, 4:1 gear
ratios or other similar engines with high reduction ratios.
Recommendation is the meDium propeller with 5.5 inch diameter
hub. We can no longer recommend the Ultriaght model propeller
because of harmonics associated with these higher ratios
causing blades to move in the 4 inch diameter hub in the
direction of rotation indicated by the motion detector
tape that cannot be stopped with the torque value.
We no longer give refund or credit for undamaged
parts with Ultralight model on these combinations.
So my next question is based on the fact that I do not have my head wrapped around prop dynamics. What would be better, a 3 blade ultralight prop or a 2 blade medium? Based on what I have heard I could probably run 70-72" on either setup with difference being 2 thick blades or 3 thin. Anyone have some science or math they can throw at this question?
akflyer
Posted: Sun Oct 18, 2009 2:35 pm Post subject: Re: What's your prop size/ prop clearance? |
I did a science project on my brothers kitfox II with 2:62-1 gears. WE had my 72: IVO IFA ultralight prop on it, and for grins and giggles one day I pulled one of the blades and went 2 blade with it (I was on floats). Dont know what I was thinking, but I just did it..... With the IFA I was able to dial the prop in for max TO RPM then bump in more pitch to keep the EGTs under control in flight... IT SUCKED with the 2 blade. Take off run was about 3000' and it took me the other 3000' of lake to get high enough to turn down wind so I could land. I got back on the water, changed my pants and put the other blade back on and by golly we had an airplane again not a "fly in ground effect" worthless airboat.
Just my .02 on a personal experience.
FWIW, I am planning on trying out an IVO medium Ground Adjust to see if I get more thrust than the ultralight blades.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun Oct 18, 2009 4:09 pm Post subject: Re: What's your prop size/ prop clearance? |
For general reference. It is commonly accepted that the longer the prop and the slower you can turn it the more efficient it is. The fewer blades are moe efficient than more, ie. Two blades are more efficient than three blades and one blade (They used to run those with a counter weight to balance) is more efficient than two.
I run a 72 inch two blade warp prop on a 503 50 horse power with a 3:1 gear reduction. I used to have a 68 inch three blade GSC. My impression is the 2 blade climbs better but is not as smooth as the 3 blade. If I had a 582 I would run a three blade prop. That seems to be the prop of choice for Kitfoxes with two strokes.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Sun Oct 18, 2009 4:11 pm Post subject: What's your prop size/ prop clearance? |
Lenny, am I to understand that you removed one blade from a three-
bladed prop? And then ran the engine with 2 blades? WAAAAY out-of-
balance? That's what it sounds like to me. Or is this a prop that
allows you to do this. Admittedly I'm out of my league when it comes
to other than a fixed-pitch prop, but this sounds like a recipe for
engine shake, rattle and roll. : )
(Bill Haley, are you listening?)
Lynn Matteson
Jabiru 2200, #2062, 800.0 hrs
Countdown to 1000 hrs--200 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
On Oct 18, 2009, at 6:35 PM, akflyer wrote:
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p 68450#268450
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
akflyer
Posted: Mon Oct 19, 2009 4:39 am Post subject: Re: What's your prop size/ prop clearance? |
| Lynn Matteson wrote: | Lenny, am I to understand that you removed one blade from a three-
Lynn Matteson
Status: flying
I can see where you may be confused by my statement. With the IVO prop, you can pull one blade, insert the blade blocks and re-configure to a two blade, properly opposed and balanced. I will do some pretty dumb sh!t but I am not dumb enough to try whacking a blade off a normal 3 blade and then try to fly on just two. I can do some drinking, but your not gonna ever see me drunk enough to put quarters in for that ride!
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
Posted: Mon Oct 19, 2009 5:16 am Post subject: What's your prop size/ prop clearance? |
WHEW...THAT'S a relief! For a while there I thought we were gonna
have to start taking nominations for a new "hander outer of humorless
darwin awards" in case you went over the edge and did something
REALLY dumb. : )
*That* kind of ride might even be in the silver dollar category.
Lynn Matteson
Status: flying
On Oct 19, 2009, at 8:39 AM, akflyer wrote:
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Electroair direct-fire ignition system
> Status: flying
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p 68508#268508
N369LM |
