		Mike Whisky
				 Posted: Thu Oct 15, 2009 12:14 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Hi there,
 I was wondering if you did connect the AFS RPM sensor on the magnet or the LS ignition, or is it even possible to wire both and choose via software where the signal comes from.
 Michael
  _________________ RV-10 builder (flying)
#511 |
		jim(at)CombsFive.Com Guest
				 Posted: Thu Oct 15, 2009 4:23 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Have the same configuration Lightspeed on the left and magneto on the right.  I wired the AFS tach to the lightspeed ignition.Jim CDo Not Archive ---------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: "Michael Wellenzohn"<rv-10(at)wellenzohn.net>Hi there,I was wondering if you did connect the AFS RPM sensor on the magnet or theLS ignition, or is it even possible to wire both and choose via softwarewhere the signal comes from.ThanksMichael--------RV-10 builder (avionics, wiring)#511Read this topic online here:http://forums.matronics.com/viewtopic.php?p 68115#268115   [quote][b]
		partner14
				 Posted: Thu Oct 15, 2009 5:44 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Jim, I tried everything to get my Lightspeed to talk to my AFS.... with no success.  Robs people were great, but still nothing.  I have a backup Vans tach that I had to hook up using the cable and such out of the back of the motor.  What did you do to get it to work.  Gotta be specific here... Not at the hanger, so I can't cite pin numbers... hopefully you can...   Sure would be nice to get it to work,
 --- On Thu, 10/15/09, Jim <jim(at)combsfive.com> wrote:
 Subject: Re: AFM RPM Transducer on Magnet or LSI?
 Date: Thursday, October 15, 2009, 5:19 PM
 Jim C
 Hi there,
 Michael
 #511
 http://forums.matronics.com/viewtopic.php?p=268115#268115
 get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
 =nofollow>http://forums.matronics.com
 blank rel=nofollow>http://www.matronics.com/contribution
40636 |
		wcurtis(at)nerv10.com Guest
				 Posted: Fri Oct 16, 2009 4:11 am    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Even though AFS has a provision electronic ignition tach, the harness that come with the AFS does NOT include a pin or wire for for it. You have to add this additional wire if you want RPM indication from the electronic ignition on the AFS. Did you add this additional wire from the LS input connector pin 6 to the AFS EM harness pin 33?
  See page 4:
  http://wcurtis.nerv10.com/90Electrical/RV10WireBookAll.pdf
  William
  On Thu, Oct 15, 2009 at 9:33 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
  [quote]    Jim, I tried everything to get my Lightspeed to talk to my AFS.... with no success. Robs people were great, but still nothing.I have a backup Vans tach that I had to hook up using the cable and such out of the back of the motor. What did you do to get it to work. Gotta bespecific here... Not at the hanger, so I can'tcite pin numbers... hopefully you can... Sure would be nice to get it to work,
 --- On Thu, 10/15/09, Jim <jim(at)combsfive.com (jim(at)combsfive.com)> wrote:
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Fri Oct 16, 2009 7:39 am    Post subject: Re: AFM RPM Transducer on Magnet or LSI? |
				 	  | wcurtis(at)nerv10.com wrote: | 	 		  Even though AFS has a provision electronic ignition tach, the harness that come with the AFS does NOT include a pin or wire for for it.? You have to add this additional wire if you want RPM indication from the electronic ignition on the AFS.? Did you add this additional wire from the LS input connector pin 6 to the AFS EM harness pin 33?
  See page 4:
  William
 William,
 I don't have my wiring diagram in front of me right now, but quickly looking at your page 4, why are you trying to connect both your mag and LEI inputs?  I must be missing something.
 I have a Mag on the Left and LEI on the right.  My rpm readings come from my Left Mag and I always have a reading no mater what I have selected, L, R, Both.  If the engine is turning, I have an rpm reading.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
				 Posted: Fri Oct 16, 2009 7:42 am    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Michael,I will swing by the hanger today and give you more details.Jim CDo Not Archive---------------------------------------------------------------------Jim, I tried everything to get my Lightspeed to talk to my AFS.... with no success.  Robs people were great, but still nothing.  I have a backup Vans tach that I had to hook up using the cable and such out of the back of the motor.  What did you do to get it to work.  Gotta be specific here... Not at the hanger, so I can't cite pin numbers... hopefully you can...   Sure would be nice to get it to work, --- On Thu, 10/15/09, Jim <jim(at)combsfive.com> wrote:From: Jim <jim(at)combsfive.com>Subject: Re: AFM RPM Transducer on Magnet or LSI?To: rv10-list(at)matronics.comDate: Thursday, October 15, 2009, 5:19 PMHave the same configuration Lightspeed on the left and magneto on theright.  I wired the AFS tach to the lightspeed ignition.Jim CDo Not Archive---------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: "Michael Wellenzohn"<rv-10(at)wellenzohn.net>Hi there,I was wondering if you did connect the AFS RPM sensor on the magnet or theLS ignition, or is it even possible to wire both and choose via softwarewhere the signal comes from.ThanksMichael--------RV-10 builder (avionics, wiring)#511Read this topic online here:http://forums.matronics.com/viewtopic.php?p 68115#268115   [quote][b]
				 Posted: Fri Oct 16, 2009 8:27 am    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Ah, how about doing a mag check with other than your ear! --or being able to select from which device you want RPM indication. Why would you not?
  William
   [quote]William,
  Gary Blankenbiller
 RV10 - # 40674
 (N2GB Flying)
		orchidman
				 Posted: Fri Oct 16, 2009 3:11 pm    Post subject: Re: AFM RPM Transducer on Magnet or LSI? |
				 	  | wcurtis(at)nerv10.com wrote: | 	 		  Ah, how about doing a mag check with other than your ear! --or being able to select from which device you want RPM indication.� Why would you not?
  William
 William,
 I think you are missing a key point here.  You mount the sender on the mag and it detects magneto revolutions.  Maybe you have a different mag but on mine the sender mounts in the hole that the black vent plug goes in.  It has nothing to do with the fact that the mag is engaged or not engaged.  Unless the mag shaft breaks or the mag falls off the back of the engine, the main shaft of the mag will be rotating and the sender will detect the rpm of the shaft and therefore the engine.
 In this configuration, the left mag can be on or off and the right LSI can be on or off, as long as the mag shaft is turning, the AFS EM unit will indicate the engine speed.
RV10 - # 40674
(N2GB Flying) |
				 Posted: Fri Oct 16, 2009 4:21 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				My RPM uses the supplied speed sensor from AFS in the right mag vent.  I wired the LightSpeed but use the input from the mag mounted sensor as the primary RPM input. The plan is to eventually replace the mag with a P-Mag / E-Mag once the 6 cylinder version become available.  I would like to have an ignition system that does not rely on 12V to power it once running. Jim C--------------------------------------------------------------------------------------------------------------------------Jim, I tried everything to get my Lightspeed to talk to my AFS.... with nosuccess.  Robs people were great, but still nothing.  I have a backup Vanstach that I had to hook up using the cable and such out of the back of themotor.  What did you do to get it to work.  Gotta be specific here... Notat the hanger, so I can't cite pin numbers... hopefully you can...   Surewould be nice to get it to work, --- On Thu, 10/15/09, Jim <jim(at)combsfive.com> wrote:From: Jim <jim(at)combsfive.com>Subject: Re: AFM RPM Transducer on Magnet or LSI?To: rv10-list(at)matronics.comDate: Thursday, October 15, 2009, 5:19 PMHave the same configuration Lightspeed on the left and magneto on theright.  I wired the AFS tach to the lightspeed ignition.Jim CDo Not Archive---------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: "Michael Wellenzohn"<rv-10(at)wellenzohn.net>Hi there,I was wondering if you did connect the AFS RPM sensor on the magnet or theLS ignition, or is it even possible to wire both and choose via softwarewhere the signal comes from.ThanksMichael--------RV-10 builder (avionics, wiring)#511Read this topic online here:http://forums.matronics.com/viewtopic.php?p 68115#268115   [quote][b]
		ricksked(at)embarqmail.co Guest
				 Posted: Fri Oct 16, 2009 5:11 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">   Just to play devil's advocate and to get an idea of what everyone is thinking.... I'm running two slick mags...I might opt for one light speed/P-mag once proven but I can't help but love the reliability (safety??) of my dual mag system. A totally electrically dependent ignition system concerns me in a single engine piston aircraft....so don't bring multi engine turbines or jets into this...were talking good ol'e lycomings and even auto conversions in this...Thoughts?Rick S.N246RS......just two mags chuggin along......at 200 mph. Big smile
 Sent via BlackBerry by AT&TFrom:  "Jim" <jim(at)CombsFive.Com>
 Date: Fri, 16 Oct 2009 20:16:33 -0400
 Subject: Re: RV10-List: AFM RPM Transducer on Magnet or LSI?
 My RPM uses the supplied speed sensor from AFS in the right mag vent. I wired the LightSpeed but use the input from the mag mounted sensor as the primary RPM input. The plan is to eventually replace the mag with a P-Mag / E-Mag once the 6 cylinder version become available. I would like to have an ignition system that does not rely on 12V to power it once running. Jim C--------------------------------------------------------------------------------------------------------------------------Jim, I tried everything to get my Lightspeed to talk to my AFS.... with nosuccess. Robs people were great, but still nothing.I have a backup Vanstach that I had to hook up using the cable and such out of the back of themotor. What did you do to get it to work. Gotta bespecific here... Notat the hanger, so I can'tcite pin numbers... hopefully you can... Surewould be nice to get it to work,--- On Thu, 10/15/09, Jim <jim(at)combsfive.com> wrote:From: Jim <jim(at)combsfive.com>Subject: Re: RV10-List: AFM RPM Transducer on Magnet or LSI?To: rv10-list(at)matronics.comDate: Thursday, October 15, 2009, 5:19 PMHave the same configuration Lightspeed on the left and magneto on theright. I wired the AFS tach to the lightspeed ignition.Jim CDo Not Archive---------------------------------------------------------------------------------------------------------------------------> RV10-List message posted by: "Michael Wellenzohn"<rv-10(at)wellenzohn.net>Hi there,I was wondering if you did connect the AFS RPM sensor on the magnet or theLS ignition, or is it even possible to wire both and choose via softwarewhere the signal comes from.ThanksMichael--------RV-10 builder (avionics, wiring)#511Read this topic online here:http://forums.matronics.com/viewtopic.php?p=268115#268115   [quote][b]
				 Posted: Fri Oct 16, 2009 5:23 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Gary,
  Yup, I'm confuse by the question and think I missed your point again.
  AFS provides for RPM input on PINs 16,31 & 32 with the included mag sensor--I wired that.  AFS also provide for RPM indication with Electronic Ignition on pin 33 --so I wired that also.  This gives me the option of which device, mag or Electronic Ignition to get the RPM indicaton from.
  William
  On Fri, Oct 16, 2009 at 7:11 PM, orchidman <gary(at)wingscc.com (gary(at)wingscc.com)> wrote:
  [quote]--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
  	  | Quote: | 	 		   Ah, how about doing a mag check with other than your ear! --or being able to select from which device you want RPM indication.� Why would you not?
 William,
 Gary Blankenbiller
 RV10 - # 40674
  (N2GB Flying)
 http://forums.matronics.com/viewtopic.php?p=268283#268283
   such as List Un/Subscription,
  ://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
   href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
				 Posted: Fri Oct 16, 2009 6:21 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Rick,The LightSpeed will work with voltages down to 5 volts (if I remember correctly).I have not gone to a dual battery system but opted for a single larger amp hour battery.My plan is to always keep a engine operated ignition installed just in case.  I can always go with a small 2nd battery as a backup.Jim CDo Not Archive-------------------------------------------------------------------------------------------------------------------------Just to play devil's advocate and to get an idea of what everyone isthinking.... I'm running two slick mags...I might opt for one lightspeed/P-mag once proven but I can't help but love the reliability(safety??) of my dual mag system. A totally electrically dependentignition system concerns me in a single engine piston aircraft....so don'tbring multi engine turbines or jets into this...were talking good ol'elycomings and even auto conversions in this...Thoughts?Rick S.N246RS......just two mags chuggin along......at 200 mph. Big smileSent via BlackBerry by AT&T--
		Kellym
				 Posted: Fri Oct 16, 2009 6:40 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Well, when it comes time for overhaul on the mags, if you don't succumb
 to the siren song of electronics, you might consider a switch to the
 more reliable Bendix which also have hotter spark. Personally, if I can
 swing it, will aim for Bendix 1200 series for my engine...about the best
 high altitude mag out there.
 ricksked(at)embarqmail.com wrote:
  	  | Quote: | 	 		   Just to play devil's advocate and to get an idea of what everyone is
  Thoughts?
  Rick S.
  *Date: *Fri, 16 Oct 2009 20:16:33 -0400
  *To: *<rv10-list(at)matronics.com>
  *Subject: *Re: AFM RPM Transducer on Magnet or LSI?
  Jim C
  Jim C
  Hi there,
  Michael
  #511
  ¦·›~‰í²,Þg–ŠÓM4ÓGÚqà¢êâz¹ÞÁÊ.®'«���������������8E]t.+-f¢”Z+º`±ëaxÆ®‰ârÂâ²Ñ^jÛ«zÃZ¾(¶Ší¡ºèÂǶ¦j|‹ŠËn¶)b¶'¬²ç!jÂâ²Õ'ý+›±Êâ¦Ø¨œ�r¯y'šÈC£
  å¡§{
  ¬®Œ,x(Z´P�ø¶‹!j·šÙ®r®r¨jÞ|¶ŸÿÃ&jÚèž',r‰¿5«â«hu謶m§ÿðà š¶º'‰Ë¢oÍjø jÚ+E]t.+-ý���������������0Ñ8ÒIaäT1
  jg ær‰íz{Z–ʽ¨¥i¹^¾&…åžlZ+ºk¨yð¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿h���������������ŠËB¢{k‰»Š‰Öy´¢µà…©äÊ‹Ÿ¢¼¨º¸êèºË.¦š+´¶ÐëjY^.+-Ù¢œç†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢xm¶ŸÿÃ&jÚèž',r‰¿r‰í®&î¶*'ý���������������ýú'·úk{öèw/átml=
KCHD |
		jeff(at)westcottpress.com Guest
				 Posted: Fri Oct 16, 2009 10:51 pm    Post subject: AFM RPM Transducer on Magnet or LSI? |
				... I'm planning dual mags.... trying to make every decision now to keep systems simple, redundant and light.  I'll have an all electric panel with two AFS Advance Decks each with their own back up battery, single battery in the back and single alternator.
 Jeff Carpenter
 40304
 On Oct 16, 2009, at 5:56 PM, ricksked(at)embarqmail.com (ricksked(at)embarqmail.com) wrote:
  	  | Quote: | 	 		   Just to play devil's advocate and to get an idea of what everyone is thinking.... I'm running two slick mags...I might opt for one light speed/P-mag once proven but I can't help but love the reliability (safety??) of my dual mag system. A totally electrically dependent ignition system concerns me in a single engine piston aircraft....so don't bring multi engine turbines or jets into this...were talking good ol'e lycomings and even auto conversions in this...
 Thoughts?
 Rick S.
 Sent via BlackBerry by AT&TFrom:  "Jim" <jim(at)CombsFive.Com (jim(at)CombsFive.Com)>
 To: <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
 Jim C
 From: Jim <jim(at)combsfive.com (jim(at)combsfive.com)>
 Jim C
 <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
 Hi there,
 Michael
 #511
		orchidman
				 Posted: Sat Oct 17, 2009 5:10 am    Post subject: Re: AFM RPM Transducer on Magnet or LSI? |
				 	  | wcurtis(at)nerv10.com wrote: | 	 		  Gary,
  William
 I think I see what you are also trying to say.  You will go into setup and tell it which source you want?  I don't think we can display 2 sources at the same time, can we?  Have not looked.  And if you switch off the LSI as in a mag check, with LSI selected in setup, will you get any RPM reading?
 While I loose some redundancy and a backup option, I went with what I think is a simpler solution and just went with the single source.
 If I lost RPM's at run-up, it would be back to the hanger, but I have flown the plane enough now that if I lost it on TO or enroute, I know I would be able to land uneventfully.
RV10 - # 40674
(N2GB Flying) |
		partner14
				 Posted: Sat Oct 17, 2009 7:37 am    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Yes, I added the wire to that pin... that was the easy part.... then AFS told me I needed to install a 10k ohm resistor in series, and run a leg to ground. did that. still nothing.
  So apparently all you did was run the wire from LS #6 to AFS 33?
  Sure wish it had been that easy for me.
  Don McDonald
 --- On Fri, 10/16/09, William Curtis <wcurtis(at)nerv10.com> wrote:
 Date: Friday, October 16, 2009, 5:00 AM
  See page 4:
  William
   	  | Quote: | 	 		      Jim, I tried everything to get my Lightspeed to talk to my AFS.... with no success.  Robs people were great, but still nothing. I have a backup Vans tach that I had to hook up using the cable and such out of the back of the motor.  What did you do to get it to work.  Gotta be specific here... Not at the hanger, so I can'tcite pin numbers... hopefully you can...   Sure would be nice to get it to work,
40636 |
		partner14
				 Posted: Sat Oct 17, 2009 7:43 am    Post subject: AFM RPM Transducer on Magnet or LSI? |
				Sorry Jim, I forgot to sign my email.... it was me who had the questions on the LSE/AFS tach hook up.  Where are you located?
  Don McDonald
 --- On Fri, 10/16/09, Jim <jim(at)combsfive.com> wrote:
 Date: Friday, October 16, 2009, 8:29 AM
  Michael,
 Jim C
 Jim C
 Hi there,
 Michael
 #511
40636 |
