rebrunk42(at)gmail.com Guest
				 Posted: Sun Oct 18, 2009 10:55 am    Post subject: RV10-List Digest: 7 Msgs - 10/17/09 |
				I am doing maintenance on the nose fork . I can't get the fork off the
 spindle. It is very tight . Help!!!
 Robert E. Brunkenhoefer
 Brunkenhoefer Law Firm, P.C.
 520 Lawrence St.
 Corpus Christi, Texas 78401
 Phone: 361-888-8808
 Facsimile: 361-888-6753
 robert(at)brunklaw.com
 On Oct 18, 2009, at 1:58 AM, RV10-List Digest Server <rv10-list(at)matronics.com
  > wrote:
  	  | Quote: | 	 		   *
  Today's complete RV10-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest
  formatted
  in HTML for viewing with a web browser and features Hyperlinked
  Indexes
  and Message Navigation.  The .txt file includes the plain ASCII
  version
  of the RV10-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 09-10-17&Archive=RV10
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 09-10-17&Archive=RV10
                            RV10-List Digest Archive
                      Total Messages Posted Sat 10/17/09: 7
  Today's Message Index:
      1. 06:11 AM - Re: AFM RPM Transducer on Magnet or LSI?
  (orchidman)
      2. 08:37 AM - Re: AFM RPM Transducer on Magnet or LSI?  (Don
  McDonald)
      3. 08:43 AM - Re: AFM RPM Transducer on Magnet or LSI?  (Don
  McDonald)
      4. 01:24 PM - AFS RPM Transducer on Magnet or LSI?   (RobHickman(at)aol.com
      5. 01:29 PM - Re: AFS RPM Transducer on Magnet or LSI?  (Michael
  Wellenzohn)
      6. 02:54 PM - Re: AFS RPM Transducer on Magnet or LSI?  (William
  Curtis)
      7. 04:26 PM - Re: AFS RPM Transducer on Magnet or LSI?  (RobHickman(at)aol.com
  ________________________________  Message 1
  _____________________________________
  Time: 06:11:56 AM PST US
  Subject: Re: AFM RPM Transducer on Magnet or LSI?
  wcurtis(at)nerv10.com wrote:
 > Gary,
 > Yup, I'm confuse by the question andthink I missed your point again.
 > AFS provides for RPM input on PINs 16,31 &32 with the included mag
 > sensor--I
  wired that. AFS also provide for RPM indication with Electronic
  Ignition on pin
  33 --so I wired that also. This gives me the option of which device,
  mag or
  Electronic Ignition to get the RPM indicaton from.
 > William
  I think I see what you are also trying to say.  You will go into
  setup and tell
  it which source you want?  I don't think we can display 2 sources at
  the same
  time, can we?  Have not looked.  And if you switch off the LSI as in
  a mag check,
  with LSI selected in setup, will you get any RPM reading?
  While I loose some redundancy and a backup option, I went with what
  I think is
  a simpler solution and just went with the single source.
  If I lost RPM's at run-up, it would be back to the hanger, but I
  have flown the
  plane enough now that if I lost it on TO or enroute, I know I would
  be able to
  land uneventfully.
  Gary Blankenbiller
  RV10 - # 40674
  (N2GB Flying)
  http://forums.matronics.com/viewtopic.php?p 68319#268319
  ________________________________  Message 2
  Time: 08:37:25 AM PST US
  Yes, I added the wire to that pin... that was the easy part.... then
  AFS to
  ld me I needed to install a 10k ohm resistor in series, and run a
  leg to gr
  ound. did that. still nothing.
  So apparently all you did was run the wire from LS #6 to AFS 33?
  Sure wish it had been that easy for me.
  Don McDonald
  Even though AFS has a provision electronic ignition tach, the
  harness that
  come with the AFS does NOT include a pin or wire for for it.- You
  have to
  add this additional wire if you want RPM indication from the
  electronic ig
  nition on the AFS.- Did you add this additional wire from the LS
  input co
  nnector pin 6 to the AFS EM harness pin 33?
  See page 4:
  http://wcurtis.nerv10.com/90Electrical/RV10WireBookAll.pdf
  William
  On Thu, Oct 15, 2009 at 9:33 PM, Don McDonald <building_partner(at)yahoo.com
  wrote:
  Jim, I tried everything to get my Lightspeed to talk to my AFS....
  with no
  success.- Robs people were great, but still nothing.--I have a backup
  Vans tach that I had to hook up using the cable and such out of the
  back o
  f the motor.- What did you do to get it to work.- Gotta be-specific h
  ere... Not at the hanger, so I can't-cite pin numbers... hopefully
  you ca
  n...-- Sure would be nice to get it to work,-
  Have the same configuration Lightspeed on the left and magneto on
  the right
  .- I wired the AFS tach to the lightspeed ignition.
  Jim C
  =0A=0A=0A
  ________________________________  Message 3
  Time: 08:43:21 AM PST US
  Sorry Jim, I forgot to sign my email.... it was me who had the
  questions on
  the LSE/AFS tach hook up.- Where are you located?
  Don McDonald
  Michael,
  I will swing by the hanger today and give you more details.
  Jim C
  with no
  back o
  you ca
  Have the same configuration Lightspeed on the left and magneto on the
  right.- I wired the AFS tach to the lightspeed ignition.
  Jim C
  <rv-10(at)wellenzohn.net>
  Hi there,
  I was wondering if you did connect the AFS RPM sensor on the magnet
  or the
  LS ignition, or is it even possible to wire both and choose via
  software
  where the signal comes from.
  Michael
  RV-10 builder (avionics, wiring)
  #511
  http://forums.matronics.com/viewtopic.php?p 68115#268115
  =0A=0A=0A
  ________________________________  Message 4
  Time: 01:24:35 PM PST US
  Subject: AFS RPM Transducer on Magnet or LSI?
  In a message dated 10/16/2009 6:24:10 P.M. Pacific Daylight Time,
  wcurtis(at)nerv10.com writes:
  AFS provides for RPM input on PINs 16,31 & 32 with the included  mag
  sensor--I wired that.  AFS also provide for RPM indication with
  Electronic
  Ignition on pin 33 --so I wired that also.  This gives me the
  option of which
  device, mag or Electronic Ignition to get the RPM indicaton  from.
  William
  You should only connect 1 RPM input (MAG or Electronic) If you  have
  one
  mag and one electronic you should use only the MAG input.  As  long
  as the mag
  is still turning you will get displayed RPM even when it is  off.
  You need to disconnect pin 33 or it will not work properly.
  Rob Hickman
  Advanced Flight Systems
  ________________________________  Message 5
  Time: 01:29:59 PM PST US
  Subject: Re: AFS RPM Transducer on Magnet or LSI?
  From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
  Thank you Rob that was exactly the answer and explanation that I
  needed.
  Michael
  #511
  http://forums.matronics.com/viewtopic.php?p 68340#268340
  ________________________________  Message 6
  Time: 02:54:50 PM PST US
  I was hoping the software would allow me to alternatively select.
  Since I
  want this option in the future, I will install an in-line switch to
  to pin
  33 for now.
  William
 > Electronic
 > option of
 > which device, mag or Electronic Ignition to get the RPM indicaton
 > from.
 > William
 > one mag
 > and one electronic you should use only the MAG input.  As long as
 > the mag is
 > Rob Hickman
  ________________________________  Message 7
  Time: 04:26:16 PM PST US
  You do not want or need a switch.  If later on you decide to add a 6
  Cylinder PMAG you will need to disconnect the RPM sensor and then
  you will
  connect the Electronic input to only the PMAG, and yes the PMAG will
  drive the
  RPM display even when it is off for your light speed side.  We do
  not want  a
  wire connected to Pin 33 and floating at the switch acting like a big
  antenna,   you will get noise on your RPM display if you do  this.
  In my airplanes I have the following:
  RV-4
  1 Slick Mag
  1 PMAG
  The RPM input is tied from the PMAG to the Electronic RPM input Pin
  33
  RV-10
  1 Slick Mag
  1 LightSpeed
  The RPM input is tied from our RPM sensor in the Mag to RPM input
  Pin 32
  In both cases the RPM display works perfect on RIGHT / LEFT / and
  BOTH
  Call me on my cell if you need further assistance.
  (503) 701-5042
  Rob Hickman
