		DanM
  Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
				 Posted: Sun Oct 18, 2009 8:41 am    Post subject: Flaperon Rigging Problem |
				Hello all--- I preparing N443DM  (mod IV) for 1st flight and am having a problem rigging the flaperons!
 1st-- the construction manual call out an angle of 19 to 20 deg down from horizontal on the flaperon bell crank. I also have spec sheets that says the angle should be 11 1/2 deg. I don't know which is correct.
 2nd-- is the flap handle suppose to be full forward until it contacts the cross tube during the setup procedure.?
 Thanks for the help
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Sun Oct 18, 2009 3:57 pm    Post subject: Re: Flaperon Rigging Problem |
				 	  | Quote: | 	 		  1st-- the construction manual call out an angle of 19 to 20 deg down from horizontal on the flaperon bell crank. I also have spec sheets that says the angle should be 11 1/2 deg. I don't know which is correct.
 Dan,
 from my 1994 classic 4 assembly manual, "Rigging the Flaperons":
 step (16): Adjust the flap push-pull tube so the angle between the belly of the aircraft and the #15049 bellcrank is 11.4 degrees...(A "Smartlevel" is invaluable for this.)
  	  | Quote: | 	 		  | 2nd-- is the flap handle suppose to be full forward until it contacts the cross tube during the setup procedure.?  |
 Yes, that's how I rigged mine.
 I also second the vote for the smart level.  I rigged mine the old fashion way with a bubble level and a protractor the first time.  That took me several days.  I rigged it again a couple years ago with a smart level in a couple hours.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		DanM
				 Posted: Mon Oct 19, 2009 6:45 am    Post subject: Re: Flaperon Rigging Problem |
				Thanks Tom, back to the airport on Saturday to try again. I guess the sheet spec's that specify 19 to 20 degrees is a mistake???? Oh yea I have a digital smart level also.
Kitfox IV
Sensenich 62x46
N443DM |
