brentblue(at)wyoming.com Guest
Posted: Mon Oct 19, 2009 4:22 am Post subject: Carb Problems |
I have been unable to develop full power on a homebuilt with a M14P. Can only get fuel flow to about 16 gph (both static and high speed taxi) with full rpm and only 24 mp. Have checked the fuel supply and boost to the fine screen and get up to 50 gph with the boost pump to that point.
Is this a problem with pressurizing the carb and/or an aneroid problem?
Thanks for any help.
Brent
--- m14pengines-list(at)matronics.com wrote:
From: M14PEngines-List Digest Server <m14pengines-list(at)matronics.com>
To: M14PEngines-List Digest List <m14pengines-list-digest(at)matronics.com>
Subject: M14PEngines-List Digest: 0 Msgs - 10/18/09
Date: Sun, 18 Oct 2009 23:56:42 -0700
Today's complete M14PEngines-List Digest can also be found in either of the
of the M14PEngines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 09-10-18&Archive=M14PEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 09-10-18&Archive=M14PEngines
M14PEngines-List Digest Archive
Total Messages Posted Sun 10/18/09: 0
Today's Message Index:
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
Posted: Mon Oct 19, 2009 5:14 am Post subject: Carb Problems |
Have you tried adjusting the prop governor and what type propeller is on the engine?
Dennis
n801bh(at)netzero.com Guest
Posted: Mon Oct 19, 2009 5:42 am Post subject: Carb Problems |
A few things to consider.
Have you comfirmed the fuel flow numbers are correct and transducer is caliberated ?
Confirmed the RPM reading is correct? have ya used an optical tach to test ?
I think you have the 360 HP motor as 24" is darn close to what you would see at DIJ's elevation, this seems to comfirm you don't have an intake track restriction issue either.
If the motor is fresh and putting out 360 at sea level your 16 GPH is not that far off. Up here your 360 is about 295 HP or so and 17-19 is the GPH numbers you should be seeing.
Ben Haas
N801BH
www.haaspowerair.com
