		rvg8tor
				 Posted: Mon Oct 19, 2009 12:58 pm    Post subject: 2-10 switch spacing |
				I asked this of B&C who sells the switches but they directed me to ask Bob Nuckolls on this forum so I am putting it out for anyone with the information.  I am not sure why B&C would not know technical information for items they sell!
 I had drilled holes 3/4" on center for my switches.  The bigger 2-10 switches fit, but with very little room between them.
 Is there a minimum space between switches required?
 Thanks for the help.
  _________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
		ulflyer(at)verizon.net Guest
				 Posted: Tue Oct 20, 2009 1:37 pm    Post subject: 2-10 switch spacing |
				Yes, room for the replacement switch when the original fails and are
 no longer available.  It's happened before it will happen again.
 If the wire crimp(s) can be mounted on the terminals and not touch by
 some reasonable clearance, I would think that would be acceptable
 -  only exception might be switch controlling very high current loads
 which may warm up some.
 jerb
 At 01:58 PM 10/19/2009, you wrote:
 Mike "Nemo" Elliott
 RV-8A QB (Fuselage)
 http://forums.matronics.com/viewtopic.php?p 68599#268599
