aviateer
Posted: Wed Oct 21, 2009 6:36 pm Post subject: Re-Kreem Fuel Tanks |
Hello Paul,
You say you are flying again. What type of fuel lines did you install on your newly Kreemed fuel tanks?
I have been experiencing the same thing. My engine started to run rough about four years ago. I just completed the re-slosh with Kreem and I bought some fuel line at NAPA auto stores. It is black rubber gas line. I would expect that ethanol and any other auto fuel will not harm this fuel line. I do not know about 100LL however. I sometimes fuel up with 100LL during cross country flights.
Kirk Martenson
Classic IV 912UL
Lynn Matteson
Posted: Wed Oct 21, 2009 7:52 pm Post subject: Re-Kreem Fuel Tanks |
If you bought the SAE 30R7 fuel line, you can rest assured that 100LL
will not harm it. I have over 800 hours running this type of
line...in some cases, the SAME line for all of those 800 hours, and
no signs of any harm to the lines, some of which I changed just last
week. And NO sign of the Kreeme flaking, peeling, dissolving, etc.
And that's after approximately 3200 gallons passing through those tanks.
I fly an airplane, and when I DO decide to put fuel into this
airplane, is it 99.999% always airplane fuel.....that's one of the
Old Wives Tales that I pay attention to.
Lynn Matteson
Jabiru 2200, #2062, 801.4 hrs
Countdown to 1000 hrs--199 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Oct 21, 2009, at 10:33 PM, Kitfoxkirk wrote:
| Quote: | Hello Paul,
Kirk Martenson
Classic IV 912UL
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
pchristensen10(at)austin. Guest
Posted: Thu Oct 22, 2009 4:57 am Post subject: Re-Kreem Fuel Tanks |
If you Kreem your fuel tanks how do you protect the various holes like site gauge etc. from being plugged.
Pete
KFIII, 912
pwmac(at)sisna.com Guest
Posted: Thu Oct 22, 2009 5:45 am Post subject: Re-Kreem Fuel Tanks |
Take out all of them and replace with pipe plugs.
Then put them back in with your original sealant.
Paul
At 05:52 AM 10/22/2009, you wrote:
[quote]If you Kreem your fuel tanks how do you protect the various holes like site gauge etc. from being plugged.
Pete
KFIII, 912
paul perry
Posted: Fri Oct 23, 2009 8:18 pm Post subject: Re: Re-Kreem Fuel Tanks |
Hi Kirk...yes I'm flying again and I bought the R-9 fuel line, but like Lynn says I'm sure the R-7 type would be just fine. I had read a couple of posts recommending the R-9 version so I went with that...I think the diff is the R-9 is for some types of fuel injection systems and maybe more resistant to alcohol, but I'm sure there are others who could say for sure. I went with poly-urethane tubing from "Spruce" for the vent line and the sight tubes and changed out the "compression type" fittings on the sight tubes to nylon tube fittings 1/4Tx1/8P that AS&S recommends for gravity fed fuel lines. The good news with all this is I've had no more sticking valve problems since getting all this done. I know I had exposed fiberglass in the tanks from where the kreem was coming off, but there is no way I can say for sure that the resin was being dissolved or if it was that it was the ethanol or some other additive in the auto gas that did it...I suppose it could have been the flaking kreem itself..no way to know for sure...but I do know that when I eliminated the fuel tanks and ran the engine from a temporary marine tank setup the problem began to clear up after the first 30 min run. I've now flown for about 4 hours on the re-sloshed tanks with 100LL and for the last several flights the engine has ran completely smooth on initial startup(sticking valve symptoms gone).
I recently ordered decalin from AS&S and plan on continuing with the 100LL. Good luck with your return to flight!! Paul Perry
KF IV Speedster
912UL
Oh, I just installed an Ivoprop Ultralight quick adjust 68" and am loving it....same cruise and better climb than the GSC(also 68") and I might go another 1/2-1 turn adj and get even better cruise.
