WhiskeyVictor36(at)AOL.CO Guest
Posted: Fri Apr 07, 2006 9:03 pm Post subject: Sneaky Wind - Kolb Damage Report |
Alan Mancus, the owner of the Original Kolb FireStar that was turned over
onto it's back by the wind, while parked, has decided to rebuild it. Today we
did a complete survey of the damage.
WINGS and AILERONS:
Alan was at first reluctant to cut the fabric from the wings, thinking he
may be able to do the repair and just patch up any access holes. But after
talking to him about possible internal hidden damage, he finally did get out his
knife and remove the fabric.
We had already cut a couple of holes to look inside, but it was hard to see
the damage we then found with all the fabric off. When the wings hit the
ground inverted, the force caused the leading edge tube spars to push on the
ribs. There are two diagonals in the front portion of the rib. The longest
one, that goes from the top center of the rib to the bottom of the flange on the
main spar was bent out of column and the flange was also bent where the
diagonal attached. The rivets held tight. All but two ribs, in both wings, were
damaged identically. Also, the leading and trailing spars of the wings and
ailerons were bent. On one wing, the trailing spar and aileron leading spar
were minimally bent and we were able to straighten them. But all of the
others will be replaced. Some of the wing tip bow support tubing was also bent
slightly. Most will be replaced. The bow tube itself was not bent. The
right aileron will have to be rebuilt as both leading and trailing spars were
bent. The left aileron will need a new trailing spar only plus a rib or two.
TAIL FEATHERS:
The rudder and one elevator will have to be rebuilt as they were severely
bent and a couple of ribs broken.
BOOM TUBE:
Completely bent and twisted to the point of almost broken in two at the aft
end of the 'H' section, were the big bolt holds it to the cage. Will be
replaced. The 'H' section is bent. Possibly can straighten it, but then would
have to weld all the rivet holes shut in order to install in new boom tube.
Unless someone has an idea on how to match drill the existing holes.
FUSELAGE CAGE:
Saved. No damage to it except for a few scratches on the Lexan windshield.
He had just spent 6 months or more rebuilding the cage with a new nose cone,
fabric and Lexan windshield, so was fortunate there.
COVERING and PAINTING:
Almost all surfaces will be redone. This will probably be the most
expensive part of the rebuild.
It will be a lot of work. Drilling out the old rivets will be the worst
problem. Some come out easily, some with great difficulty, especially those
stainless steel ones. If the rivet spins during drilling, it can cause the hole
to become enlarged, but Alan has discovered that if you just drill the head
off, then punch the rest of the rivet through into the tube, or whatever its
in, it won't enlarge the hole. If it does, we found a source for 5/32"
rivets that will fill the gap.
Bill Varnes
Audubon NJ
Eugene Zimmerman
Posted: Sat Apr 08, 2006 4:59 am Post subject: Sneaky Wind - Kolb Damage Report |
On Apr 8, 2006, at 1:00 AM, WhiskeyVictor36(at)aol.com wrote:
| Quote: | The 'H' section is bent. Possibly can straighten it, but then would
boom tube.
Bill,
It is possible to match all the holes. Just drill all the rivets out
and remove the H section.
Then take a large piece of paper and wrap it around the tube snugly
and tape it together securely to form a paper tube. Secure this
paper tube with tape in place where the rivet holes are then
carefully drill or punch the holes in the paper.
Carefully remove this paper tube "pattern" from the old fuse tube by
sliding it off the tube away from the bent and distorted end. Slide
this pattern on to the new tube, making sure it is oriented exactly
the same as on the old one. Center punch the holes and drill one
hole each end of the line of holes. Use these holes to realign the H
section in place in the new tube. Then drill and rivet the remaining
holes.
It is helpful to use paper that is large enough to extent 4 to 6
inches past the line of rivets to form a slight " bell end" into
the paper pattern you want to slide on to the new tube.
Gene
Richard Pike
For match drilling the holes, you might try this:
Take just the section of boom where the old holes are at and cut if off
from the rest of the boom tube. Now cut it in half vertically. Verify
that all the holes line up with the straightened H section. Lay each
half on either side of the new tube with an equal gap top and bottom
between the two pieces. Make sure they lay snug and flush. Giant hose
clamps would be good. Drill just the four end holes, slide the H section
in and see if they line up enough to cleco the tube to the H section. If
they do, proceed. If they don't, you are only out four holes, which
would probably still work with a new H section.
Richard Pike
MKIII N420P (420ldPoops)
<snip>
BOOM TUBE:
<snip>
Bill Varnes
Audubon NJ
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Richard Pike
Posted: Sat Apr 08, 2006 5:17 am Post subject: Sneaky Wind - Kolb Damage Report |
Boy, I wish I'd read this before I posted my idea 5 minutes ago. I like
yours better.
Richard Pike
Eugene Zimmerman wrote:
> boom tube.
Bill,
holes.
Gene
Kingsport, TN 3TN0
Eugene Zimmerman
Posted: Sat Apr 08, 2006 6:50 am Post subject: Sneaky Wind - Kolb Damage Report |
Hello Pastor Pike,
Have you experienced damage from any of the storms that hit your
state or ,,,,,,, "is the living God, is thy God, whom thou servest
continually, able to deliver thee from the lions?"
Gene
On Apr 8, 2006, at 9:16 AM, Richard Pike wrote:
like
yours better.
Richard Pike
Richard Pike
Posted: Sat Apr 08, 2006 11:51 am Post subject: Sneaky Wind - Kolb Damage Report |
Since Hebrews 11:32-34 is still true, we did well.
Richard Pike
Hello Pastor Pike,
Gene
Kingsport, TN 3TN0
WhiskeyVictor36(at)aol.co Guest
Posted: Sat Apr 08, 2006 6:22 pm Post subject: Sneaky Wind - Kolb Damage Report |
In a message dated 4/8/2006 9:00:17 A.M. Eastern Standard Time,
richard(at)bcchapel.org writes:
Richard,
Another good idea to try. Boy, one question got a lot of good responses.
Bill Varnes
Audubon NJ
In a message dated 4/8/2006 9:00:14 A.M. Eastern Standard Time,
etzim62(at)earthlink.net writes:
Gene,
Thanks for that idea. The boom tube is bent somewhat in that area, so not
sure if the paper would give an accurate location on the new straight tube.
But its an idea to consider and try.
Bill Varnes
Audubon NJ
