ulflyer(at)verizon.net Guest
Posted: Thu Oct 29, 2009 8:53 pm Post subject: Poly-Fiber Reducer substitute?- Cutting Fabric |
Using pinking shears can be a challenge, I got Fiskars and also the expensive ones Aircraft Spruce sells. If you need to cut much get a Fiskars rotary cutter and mat. The cutter resembles a rotary pizza cutter available in straight and jagged edge. Man you can cut Dacron fabric like there is nothing to it. You can do curves, circles, etc. Great for cutting circle pieces for covering the plastic inspection holes reinforcements. A great Christmas gift for your wife if she sews much.
If you need a lot of tape for seams, it's probably just plain easier to buy it, get the bias type tape if your going around curves like corners of control surfaces like rudder or elevator.
jerb
At 03:01 PM 10/29/2009, you wrote:
[quote]Real Lacquer Thinner works well with polyfiber system substitute for the Poly-Fiber Reducer if you have pinking shears you can cut finishing tapes out of your fabric you have
Ellery in Maine
Mk3C 582 Blue head
E-Gear box
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Thu Oct 29, 2009 9:54 pm Post subject: Re: Poly-Fiber Reducer substitute?- Cutting Fabric |
29oct09
Thanks... I've got a heavy duty set and only one patch to do.
Aloha
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
elleryweld(at)aol.com Guest
Posted: Fri Oct 30, 2009 3:53 pm Post subject: Poly-Fiber Reducer substitute?- Cutting Fabric |
I was just posting that to the guy in Hawaii because he doesn't have all the items in his area available and he will have to compromise with what he has on hand to work with
Ellery in Maine
