Battery Contactor Coil Wiring
messydeer
PostPosted: Sat Oct 31, 2009 5:50 pm    Post subject: Battery Contactor Coil Wiring Reply with quote
Hi!
I've got a Tyco EV200 battery contactor. In addition to the two high current posts, it has two small wires labelled coil positive and coil negative. The Z diagrams show just one wire between the switch and battery contactor. In my case, seems like this would be the coil positive. So where would the coil negative wire be connected?
Tyco EV200 battery contactor wiring.pdf
Download
 Filename:  Tyco EV200 battery contactor wiring.pdf
 Filesize:  233.3 KB
 Downloaded:  12 Time(s)
Dan
dsvs(at)ca.rr.com
PostPosted: Sat Oct 31, 2009 6:08 pm    Post subject: Battery Contactor Coil Wiring Reply with quote
It probably drives a light to tell you that the contactor is closed. This
can be helpful to prevent starter damage.
bob(at)bob-white.com
PostPosted: Sat Oct 31, 2009 6:26 pm    Post subject: Battery Contactor Coil Wiring Reply with quote
Hi Dan,
Take a look at how the switch is wired. Most likely it connects the
wire to the contactor to ground. In this case, the red wire can be
connected directly to the large terminal that goes to the battery.
Connect the black wire to the lead to the switch. You don't need the
diode when using the EV200.
If the switch connects the wire on the contactor to a bus (12V), then
the black wire would be connected to ground.
Bob W.
On Sat, 31 Oct 2009 18:50:19 -0700
"messydeer" <messydeer(at)yahoo.com> wrote:
Hi!
Dan
http://forums.matronics.com/viewtopic.php?p 70293#270293
http://forums.matronics.com//files/tyco_ev200_battery_contactor_wiring_664.pdf
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
Now Rotary Powered Alpine
http://www.youtube.com/watch?v=FwceNc2ydN8
Cables for your rotary installation - http://roblinstores.com/
messydeer
PostPosted: Sat Oct 31, 2009 6:31 pm    Post subject: Re: Battery Contactor Coil Wiring Reply with quote
Thanks, but this is a battery contactor. Seems like what you're saying might work for starter contactor, or am I missing something?
Dan
dsvs(at)ca.rr.com
PostPosted: Sat Oct 31, 2009 7:09 pm    Post subject: Battery Contactor Coil Wiring Reply with quote
You are not missing anything, I mis read the post. Sorry
user9253
PostPosted: Sun Nov 01, 2009 4:43 am    Post subject: Re: Battery Contactor Coil Wiring Reply with quote
Hi Dan,
Connect the positive coil wire to the big terminal on the EV200 that goes to the battery.
Connect the negative coil wire to the master switch. When turned on, the master switch will connect the negative coil wire to ground.
Joe
Joe Gores
messydeer
PostPosted: Sun Nov 01, 2009 7:37 am    Post subject: Re: Battery Contactor Coil Wiring Reply with quote
Thanks, guys Smile
2 here and 1 by private email makes the score 3-0 for doing this. So I'll crimp a ring onto the red wire and hang it on the positive post of the contactor and splice the black wire to my master switch.
There must be a reason they didn't wire the positive coil lead internally to the post. This is the only contactor I've dealt with. Are they all like this?
Dan
Bob McC
PostPosted: Sun Nov 01, 2009 8:56 am    Post subject: Battery Contactor Coil Wiring Reply with quote
Dan;
No not all relays or contactors are wired like this. They are all wired,
however, to serve whatever applications they are designed for. If you
purchase a contactor intended for aircraft master relay use then chances are
it will be wired with the internal jumper.
The EV200 you're referring to is not a battery contactor per se but a
generic device used in tens of thousands of different applications and wired
in many different ways. Use as an aircraft master relay is an
infinitesimally small percentage of their total sales and therefore the
design will not take that into account because it would limit some of the
other applications for which it is used. You have to understand how to wire
a device such as this (or any other) for the way your application uses it,
which is what others have explained. Positive to battery, negative through
switch to ground. The rationale is explained in "the book".
Following this list, asking questions, and reading "the book" will soon
result in a good understanding of the not so mysterious mysteries behind the
functioning of many things electrical. There are other ways of wiring this
relay to function in your application by the way, but the "standard accepted
aircraft practice" is as described by the three responses you refer to.
Good luck on the road to understanding. This is a great place to learn. P.S.
don't forget to support Matt's efforts via his annual fundraiser.
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
