Phil White
Joined: 10 Jan 2006 Posts: 45 Location: Downers Grove, IL
Posted: Mon Nov 02, 2009 7:58 pm Post subject: GPS multiple feeds - how many? |
I am building an RV-10, and beginning to assemble and wire a panel. My
main GPS is a Garmin 396. I need it to feed my GRT EFIS, a Tru-Trak
autopilot, and a 406 MHz ELT. Will I have any problems with impedance
matching, or signal degradation if all 3 are fed from the GPS directly?
I don't know the input impedances of any of these fed boxes, or what
sort of power the Garmin can generate on its RS-232 feed.
I read the 2007 post about using a DB25 connector to facilitate the
multiple connections, but wonder if one needs a buffer or amplifier of
any sort to handle 3 outputs from one.
Phil in IL
melvinke(at)coho.net Guest
Posted: Mon Nov 02, 2009 9:05 pm Post subject: GPS multiple feeds - how many? |
My Garmin 395, and now a 496, drives a Trutrak autopilot, Argus 5000,
and automatic position reporting transmitter perfectly well, without
any consideration of impedance compatibility. Consultation with Garmin
tech support had indicated that these portable GPS units are expected
to drive three devices without degradation of signal. and I can
confirm that. I tied together the five pins of a DB9 connector as a
"NMEA-bus", and it works well.
Kenneth Melvin, N669TJ, RV-9A
On Nov 2, 2009, at 7:38 PM, Phil White wrote:
My main GPS is a Garmin 396. I need it to feed my GRT EFIS, a Tru-
Trak autopilot, and a 406 MHz ELT. Will I have any problems with
impedance matching, or signal degradation if all 3 are fed from the
GPS directly? I don't know the input impedances of any of these fed
boxes, or what sort of power the Garmin can generate on its RS-232
feed.
the multiple connections, but wonder if one needs a buffer or
amplifier of any sort to handle 3 outputs from one.
Phil in IL
Posted: Tue Nov 03, 2009 5:28 am Post subject: GPS multiple feeds - how many? |
I have a 396 (not in the '10) and all those other components but I can't
answer your question.
It occurs to me that a cost effective solution may be to simply add a
$150 external GPS from GRT. It can drive at least the EFIS and the AP.
And it would be permanently mounted like the EFIS and TT though I'm
sure you are planning to 'permanently' mount the 396.
Bill "just finishing up the panel and going back to fiberglass" Watson
RV10 40605
Phil White wrote:
Tru-Trak autopilot, and a 406 MHz ELT. Will I have any problems with
boxes, or what sort of power the Garmin can generate on its RS-232 feed.
Phil in IL
