What is the type of this pin?
Overtorque
PostPosted: Fri Oct 02, 2009 9:42 am    Post subject: What is the type of this pin? Reply with quote
Hi All,
who will be able to tell me what is the type of this connector? I found it in a switch coming from a military aircraft. In order to give a new life to the switch, I need to buy some pins....but I know nothing about it.
Thank you for your help
Overtorque.
PS: On the first pic, it is millimeter....
recapen(at)earthlink.net
PostPosted: Fri Oct 02, 2009 10:46 am    Post subject: What is the type of this pin? Reply with quote
Wasn't able to get any of the images to load to see what you are referring to.
Tried going directly to the site too with no joy.
If it came from a military aircraft, there's a milspec for it and you should be able to get replacements using the milspec number.....the trick then is determining what the milspec is.....
BobsV35B(at)aol.com
PostPosted: Fri Oct 02, 2009 10:54 am    Post subject: What is the type of this pin? Reply with quote
Good Afternoon Overtorque,
I thought I would have an answer for you.
It looks very much like the pins used by Beechcraft to feed the ground and power to their wedge type internal instrument lights. They are on the ends which plug into group receptacles on the back of the panel.
I have some somewhere, but can't find them or the Beech part number. Been trying for the last hour or so.
The bad thing is that they cost about ten bucks apiece when purchased from Beechcraft. If I find the ones I have or can locate the Beech Part Number, I will post it here. Meanwhile, maybe this will jog someone else's memory.
'Lectric Bob, do you remember them during your time at Beech?
Happy Skies,
Old Bob
In a message dated 10/2/2009 12:45:18 P.M. Central Daylight Time, lezbnd(at)gmail.com writes:
http://img42.imageshack.us/i/dsc00979fq.jpg/) (http://g.imageshack.us/img42/dsc00979fq.jpg/1/)
PostPosted: Fri Oct 02, 2009 8:16 pm    Post subject: What is the type of this pin? Reply with quote
At 12:42 PM 10/2/2009, you wrote:
--> AeroElectric-List message posted by: "Overtorque" <lezbnd(at)gmail.com>
Hi All,
A number of high-end manufacturers of switches
(and relays, etc) are offering very robust,
environmentally sealed devices that are
electrically terminated IWTS (integrated wire
termination system) by means of built-in sockets
having female pins.
The idea is not new. Patent 3717838 was issued
in 1973 on this topic. There are no doubt earlier
documents.
An exemplar product line is illustrated starting
on page A27 of
http://tinyurl.com/ya22ub8
I did a search of IWTS in this pdf file and found
a couple of switch lines offering that feature.
I believe there are probably few sizes and styles
of pins used across these product lines . . . but
pins, extraction tools and installation tools are
unique to the pins. I've not personally put my
hands on any of these but we used a goodly number
at Hawker-Beech.
I didn't see any references to mating pin numbers
in the EATON catalog. I did see a reference to M39029/1-101
pins for 20AWG wire for THAT particular part. You'll
need to check your existing pins against the dimensions
of similar pins (OR) get the part number of your
switch and see what its catalog listing calls out
for the mating pin.
These wont be easy to find in small quantities but
if you identify a part number, you can try
Aircraft and Commercial Enterprises in Derby
KS. They might have and be willing to supply you
a small quantity of pins.
( -Thomas Paine 1776- )
Overtorque
PostPosted: Fri Oct 02, 2009 9:44 pm    Post subject: Re: What is the type of this pin? Reply with quote
Hi all,
Thank you very much for these input.... I made myself the extraction tool. I have to leave for the WE. Monday, I will take accurate size of the connector and the brand (if I can find it) of the switch.
I wish a nice nice WE to all
Overtorque
Overtorque
PostPosted: Tue Oct 27, 2009 3:02 am    Post subject: Re: What is the type of this pin? Reply with quote
Hi everybody,
I found the name of my contact: Amphenol AIRLB....
Fortunatly I met a guy familiar with this type of contact.
Thank you very much for all input
Overtorque
johnnyblame
PostPosted: Wed Nov 04, 2009 3:25 am    Post subject: Re: What is the type of this pin? Reply with quote
Hi Overtorque
I read your post. In your post u show one pin it is push to on pin.
It use in the some electronics component.
The function of this pin is to set and reset circuit.
r4
