Jabiru regulator wiring and 2nd ground
PostPosted: Wed Nov 04, 2009 11:56 am    Post subject: Jabiru regulator wiring and 2nd ground Reply with quote
It sounds like this latter way is how you would do it, which means
less firewall penetrations would trump having these components in
the cooler cabin.
Virtually everybody would like to have their pride-n-joy
products mounted in the most benign location possible
aboard the airplane . . . lower risk. At the same time,
except for direct radiation from hot exhaust stacks, the
environment under the cowl isn't all that bad either.
The capacitor and relay are rated for temperatures
greater than what's expected under the cowl . . . so
make the installation clean and simple as opposed to
"cooler".
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
messydeer
PostPosted: Wed Nov 04, 2009 8:35 pm    Post subject: Re: Jabiru regulator wiring and 2nd ground Reply with quote
Thanks, Bob Smile
Dan
