agustafson(at)Chartermi.n Guest
Posted: Tue Nov 03, 2009 8:10 am Post subject: Fuel line antifreeze |
I know that ethanol and isopropyl are 2 different things, but, does having
ethanol in auto gas prevent water in fuel from freezing like isopropyl does.
In other words, is there still a need for isoprpyl to prevent fuel line and
carb bowl icing.
Note, I am aware of the draw backs of any kind of alcohol in aircraft fuel
so please don't lecture me on that.
Aaron Gustafson
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Nov 03, 2009 6:25 pm Post subject: Re: Fuel line antifreeze |
Aaron, I know ethanol will absorb water but I'm not sure if it will prevent it from freezing. You could put some water in a sample, and put it in the freezer to find out.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Float Flyr
Michel
Posted: Wed Nov 04, 2009 8:01 am Post subject: Fuel line antifreeze |
| Quote: | From: Noelloveys [noelloveys(at)yahoo.ca]
Ethanol will actually remove moisture from air
Really Noel? Rats, now I understand why, when I open a bottle of moonshine, I feel so dry in my troath; it dries up the air!
Cheers,
Michel
Do not archive!
Float Flyr
Michel
Posted: Fri Nov 06, 2009 10:43 am Post subject: Fuel line antifreeze |
I hope you are not so brave to drink ethanol!
.. how do I know what I drink, I am already blind! )
Seriously and regarding soldering: The only place I have it is on the end terminal of the throttle cable of my Jabiru. The end terminal is conic and you open the wires of the cable into the cone and fill it with solder.
Cheers,
Michel Verheughe
Float Flyr
Posted: Sun Nov 08, 2009 7:37 am Post subject: Fuel line antifreeze |
Got me! Both times... I never ask what I'm drinking. My answer is,
"whatever you're serving" One of these days I'll get a full serving of
hemlock.
Solder I was talking about was basically electrical soldering on copper
wires... I never thought of using it on mechanical parts like throttle
cables.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
