Garmin GNS 530 Internal Battery
longg(at)pjm.com
PostPosted: Thu Jul 30, 2009 12:45 pm    Post subject: Garmin GNS 530 Internal Battery Reply with quote
It's time to change the internal battery on my GNS 530. Does anyone have
any documentation on...
1. How to find the battery?
2. What is required to remove and replace?
Glenn
joburke
PostPosted: Sat Nov 07, 2009 7:32 am    Post subject: Re: Garmin GNS 530 Internal Battery Reply with quote
Did you ever find a source for this information? I'm looking for the same thing.
Thanks.
longg(at)pjm.com
PostPosted: Mon Nov 09, 2009 7:16 am    Post subject: Garmin GNS 530 Internal Battery Reply with quote
No, I just dove in and replaced the battery. If you are well organized
when you disassemble thing, you'll have not trouble. I've got a few
pictures on my website and I can send you a few more on request. It
appears intimidating at first, but in reality many of the boards used
are rather old school, using typical connectors and screws to fasten
them. If the 530 were re-designed with new technology, it would weigh
half as much, have better resolution and fewer contraptions inside. I'm
guessing with all the new products coming out from Garmin, the 430 and
530 will eventually fall unsupported. For now , they are a great unit.
Once you get down to the battery you have a choice. You can trim the
tabs and buy a tab type battery or break looks the tabs from the battery
and re-solder a new battery in its place. The batteries are easily
sourced and cost < $10.
I think Garmin charges $800.00 to replace a $10.00 battery, so you have
a choice.
Glenn
