Phil.Perry(at)netapp.com Guest
Posted: Fri Nov 06, 2009 9:19 pm Post subject: Tailcone / Fuse Template |
I managed to chew up my template, so I'm wanting to double check my work
before committing some new holes into my longerons. J
Can I get one of you with the longeron template measure the edge
distance (on the template) for the aft four bolt holes that hold the
tailcone to the fuse?
I've got the hole spacings and distances from the trailing edge of the
longeron, but I need the edge distance because my edge is pretty chewed
efdsteve(at)aol.com Guest
Posted: Sat Nov 07, 2009 7:52 am Post subject: Tailcone / Fuse Template |
The holes in my template got a bit elongated as well but here's what I measured from the end of the template:
3/8", 1 1/8", 1 7/8", 2 5/8"
Steve Weinstock
40230 fuse and engine
Posted: Sat Nov 07, 2009 8:03 am Post subject: Tailcone / Fuse Template |
Thanks Steve.
How far were the from the edge? I've got the end measurements.
Thanks again,
Phil
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Sat Nov 07 07:50:58 2009
Subject: Re: RV10-List: Tailcone / Fuse Template
Steve Weinstock
Lew Gallagher
Posted: Sat Nov 07, 2009 9:48 am Post subject: Re: Tailcone / Fuse Template |
Hey Phil,
It's been a while since we did this, but I think I remember this edge distance being important -- after the fact. Make sure you get the holes close enough to the edge so that the nuts will turn; and no more, so that installation works and you still have structural integrity. We ended up using a nut to get the distance.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Sat Nov 07, 2009 10:06 am Post subject: Tailcone / Fuse Template |
Hi Lew,
Yeah, I asked a couple of questions around this topic a few weeks ago
and Bob Leffler helped me out with the measurements.
But late last night I built a mock up of the longerons and tested the
hole positions. Unfortunately I couldn't keep the washers off the
fillet curve and moving the hole further to the edge compromised the 2D
edge distance for #12 (AN3) holes. The only way I can really keep the
washers flat on the aluminum is to compromise edge clearance by 1/32 or
2/32 (1/16th).
That's why I am curious to see what the real measurements on the
template are. I'm curious to know if Vans intentionally compromised the
edge distance a bit to get flat washers. It's 1/8" aluminum angle, so I
could see them cheating a bit.
But before I commit holes, I want to be absolutely sure.
Another option that came up is to maintain the proper edge distance, but
file the washer down where it intersects the fillet curve. Then prime
the washer where the cadmium plate was removed.
Phil
Lew Gallagher
Posted: Sat Nov 07, 2009 10:13 am Post subject: Tailcone / Fuse Template |
johngoodman
Posted: Sat Nov 07, 2009 10:29 am Post subject: Re: Tailcone / Fuse Template |
Grind down the washer.
