jbr79r(at)yahoo.com Guest
Posted: Sun Nov 08, 2009 12:13 pm Post subject: wire size |
Hello Bob
I have a wire size question. I use your 2 bat 2 alt all electric configuation for my Glasair. I use circuit breakers on a panel on the right side of the panel. The problem is that the person that helped me wire the airplane ran #4 wire from the firewall pass through and attached to the breaker panel. These are very stiff ( not welding cable) and put stress on the connections to the breakers. I would like to terminate the 2 #4 wires on the sidewall on 2 separate studs and from each of these two studs run 2 #10 wire (about 6 to 10 inches)to each end of the strap connecting the hot side of the breakers on each of the two circuits. I hope this is clear. My question is; would 2 #10 wire be sufficient to replace for a short run the #4 wires?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Posted: Sun Nov 08, 2009 3:46 pm Post subject: wire size |
At 02:09 PM 11/8/2009, you wrote:
| Quote: | Hello Bob
I'd really rather you didn't have all this "hardware"
in the system. How about replacing the 4AWG tefzel with
a 6AWG welding cable which will be MUCH easier to work
with and entirely adequate for alternator outputs of
60A. I'm presuming that your alternator is no larger
than this. Alternatively, a single chunk of 4AWG welding
cable would be MUCH preferred.
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
Posted: Sun Nov 08, 2009 4:41 pm Post subject: wire size |
Hi Bob
Your solution is OK and doable. I just worry about the weight of the wire on the copper tie strip on the breakers. I could figure a support for the much more flexible wire.
I am running a pad mount 20 amp and a belt driven 40 amp alternators. Can you make up the wires with ends if I provide the length and connector sizes?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Sent: Sun, November 8, 2009 3:43:57 PM
Subject: Re: wire size
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Hello Bob
Posted: Sun Nov 08, 2009 5:03 pm Post subject: wire size |
If you walk into your local welding supply shop & tell 'em you need x
feet of #6 and y crimp-on lugs for the wire with z stud size, then ask
if they know anyone who might rent you a crimper, odds are good that
someone at the counter will go get a crimper out of stock & do it for
you on the spot.
Charlie
James Robinson wrote:
| Quote: | Hi Bob
connector sizes?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
*From:* "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
*To:* aeroelectric-list(at)matronics.com
*Sent:* Sun, November 8, 2009 3:43:57 PM
*Subject:* Re: wire size
<nuckolls.bob(at)aeroelectric.com <mailto:nuckolls.bob(at)aeroelectric.com>>
> Hello Bob
the #4 wires?
Posted: Sun Nov 08, 2009 6:10 pm Post subject: wire size |
Thanks Charlie
I have a welding shop around the corner. I'll check with them.
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Sun, November 8, 2009 4:50:56 PM
--> AeroElectric-List message posted by: Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)>
If you walk into your local welding supply shop & tell 'em you need x feet of #6 and y crimp-on lugs for the wire with z stud size, then ask if they know anyone who might rent you a crimper, odds are good that someone at the counter will go get a crimper out of stock & do it for you on the spot.
Charlie
[quote] Hi Bob
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
*From:* "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
*To:* aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com) <mailto:nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>>
> Hello Bob
in the system.
