djluscher
Posted: Sun Nov 08, 2009 7:48 am Post subject: tooling holes |
Hi Group,
I'm just starting to build CH750 from plans and am making form blocks for the rudder ribs. The plans only indicate the location for tooling holes on the nose rib. The others are unspecified and I was seeking some advice/assurance on using two or three 1/4" holes on the center line of each rib to hold blanks between the form blocks. On the narrow end of the ribs these holes will be within an inch of the flange.
Is this OK? Any rules of thumb for drilling holes in small ribs?
thanks in advance,
DJ
Posted: Sun Nov 08, 2009 11:15 am Post subject: tooling holes |
Hi DJ,
Tooling holes are generally found on the centerline, but just be careful
that that hole doesn't interfere with
points of attachment etc. Presuming the holes will be used to sandwich
the rib between forms and center flanged holes.
You only need one every foot or so. The vise you use to grip while
hammering flanges will provide a better hold at small ends.
Don't forget to add the 7-degree over bend angle.
Larry McFarland 602HDS at www.macsmachine.com
djluscher wrote:
Hi Group,
thanks in advance,
DJ
http://forums.matronics.com/viewtopic.php?p 71693#271693
djluscher
Posted: Sun Nov 08, 2009 3:01 pm Post subject: Re: tooling holes |
Hi Larry,
Thanks for the guidance. To be clear, many of the rudder ribs have flanges 2 degree open. Do you mean a 7-degree relief or bevel on the rib form is a good number to get a 92 degree flange or do you mean I should bevel form blocks 7-degrees closed beyond the desired flange angle (5 degrees total bevel in this case?) I see 10-deg net called out in the construction standards from Zenith, but am anxious to hear what angle has proven to work best in practice.
thanks again,
DJ
| larry(at)macsmachine.com wrote: | Hi DJ,
djluscher wrote:
Hi Group,
thanks in advance,
DJ
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sun Nov 08, 2009 5:02 pm Post subject: Re: tooling holes |
I don't think the location of the tooling holes are that critical in the rear rudder ribs as they are just a way to clamp the form around the rib blank. ( do put them on the center line. But then I'm I lovely down town Chicago, getting ready for a 10 day Fabtech trade show marathon.... so I don't have my prints handy, and though they are 701 prints,they may have helped.
The over bend is for "spring back" if you make the form block corner 90 degrees the formed part will "spring back" 6-8 degrees. So if you want a 2 degree open rib flange, then you need to make your form block 92 degrees minus 6-8 degrees. Don't sweat it though as you can tweak them a little if they are not perfect.
I would suggest getting the Metal working 101 video from John C, it guides you through scratch building a 701 rudder. A little different for sure, but the techniques are the same for all of the Zenith line.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Posted: Mon Nov 09, 2009 6:43 am Post subject: tooling holes |
djluscher wrote:
Hi Larry,
thanks again,
DJ
DJ, the forms should allow you to overbend the aluminum 7-degrees to get a real 90-degree bend.
Any other, more or less according to the drawing requirements can be
adjusted by hand.
| Quote: | larry(at)macsmachine.com wrote:
> Hi DJ,
> djluscher wrote:
>> Hi Group,
>> thanks in advance,
>> DJ
http://forums.matronics.com/viewtopic.php?p 71737#271737
djluscher
Posted: Tue Nov 10, 2009 6:01 am Post subject: Re: tooling holes |
Thanks, Larry and Kevin. It is appreciated. -D
