		rv10free2fly(at)yahoo.com Guest
				 Posted: Tue Nov 10, 2009 3:05 pm    Post subject: Fuel Lube on Brake Line Fittings? |
				Guys, could you please tell me if fuel lube should be applied to the threads on brake line fittings during installation?
  Kind regards from a warm down under - fours days straights of 100F, at least there's no snow!
  Patrick Pulis
  Adelaide, South Australia
 Sent: Tue, 10 November, 2009 12:37:03 PM
 Subject: RE: RV10-List: Question about AN Fittings
 No, don’t use Teflon.  Use fuel lube on the threads.
 bob
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
 Sent: Monday, November 09, 2009 8:16 PM
 Subject: Question about AN Fittings
 Hi
 I have some AN nipples that I want to install on a Matco parking brake. As these connections are not compression fittings, should I be using anything like Teflon tape on the joints?
 Inquiring minds need to know
 Les
 #40643 still in fibreglass hell but out on a day pass 	  | Quote: | 	 		  |     www.aeroelectric.com   | 	  0123456789012345678http://www.mearch & Download, =   --> http://www.matronics.com/Navigator?RV10-List[/url] ======    [/b][/quote]
            Win 1 of 4 Sony home entertainment packs thanks to Yahoo!7. [url=http://us.lrd.yahoo.com/_ylc=X3oDMTJxN2x2ZmNpBF9zAzIwMjM2MTY2MTMEdG1fZG1lY2gDVGV4dCBMaW5rBHRtX2xuawNVMTEwMzk3NwR0bV9uZXQDWWFob28hBHRtX3BvcwN0YWdsaW5lBHRtX3BwdHkDYXVueg--/SIG=14600t3ni/**http%3A//au.rd.yahoo.com/mail/tagline/sony/*http%3A//au.docs.yahoo.com/homepageset/%3Fp1=other%26p2=au%26p3=mailtagline]Enter now[/url].
		jeff(at)westcottpress.com Guest
				 Posted: Tue Nov 10, 2009 4:01 pm    Post subject: Fuel Lube on Brake Line Fittings? |
				That's what I was advised to do and what I have done... for what little that is worth.
 Jeff Carpenter
 40304
 On Nov 10, 2009, at 2:35 PM, Patrick Pulis wrote:
  	  | Quote: | 	 		  Guys, could you please tell me if fuel lube should be applied to the threads on brake line fittings during installation?
 Patrick Pulis
 From: Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)>
 Subject: RE: Question about AN Fittings
  bob
  From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Les Kearney
  Hi
  Les
 0123456789012345678www.buildersbowww.matronics.com/contribution" target=_blank rel=nofollow>http://www.mearch & Download, = -->http://www.matronics.com/Navigator?RV10-List ======
 Win 1 of 4 Sony home entertainment packs thanks to Yahoo!7. [url=http://us.lrd.yahoo.com/_ylc=X3oDMTJxN2x2ZmNpBF9zAzIwMjM2MTY2MTMEdG1fZG1lY2gDVGV4dCBMaW5rBHRtX2xuawNVMTEwMzk3NwR0bV9uZXQDWWFob28hBHRtX3BvcwN0YWdsaW5lBHRtX3BwdHkDYXVueg--/SIG=14600t3ni/**http%3A//au.rd.yahoo.com/mail/tagline/sony/*http%3A//au.docs.yahoo.com/homepageset/%3Fp1=other%26p2=au%26p3=mailtagline]Enter now[/url].9
		rleffler
				 Posted: Tue Nov 10, 2009 5:19 pm    Post subject: Fuel Lube on Brake Line Fittings? |
				It’s certainly easier than after installation.  :^)   I had to beat Rick to the punch.
 I applied fuel lube to the threads of all my brake fittings.
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
  Sent: Tuesday, November 10, 2009 5:36 PM
  Subject: Fuel Lube on Brake Line Fittings?
 Patrick Pulis
  _________________ Bob Leffler
N410BL - Phase I
		AirMike
				 Posted: Tue Nov 10, 2009 7:33 pm    Post subject: Fuel Lube on Brake Line Fittings? |
				I used fuel lube on my brake line fittings and had good luck with all except two fittings at my Matco (after market) parking brake. I had one heck of a leak (very messy brake fluid) on the floor of the pilot footwell. It was a real mess. I finally used Permatex non-hardening sealant on these fittings and finally got the leak sealed. If you do not have a parking brake just use the fuel lube. If you have the Matco parking brake valve (I love it) use Permatex on those fittings. I think that it is Permatex #2 but not sure - it is a non-soluble sealant.
 See my prior post (over 1 year ago) on the Matco brake.
  _________________ See you OSH '18
Q/B - sold. |
		kearney
				 Posted: Tue Nov 10, 2009 9:52 pm    Post subject: Fuel Lube on Brake Line Fittings? |
				Hmmm
 This has been an interesting thread. When I asked the original question, I was referring to (and I hate to use this work again because of Rick Sked <vbg>) the NPT nipples to be installed on the front of the Matco parking brake. These do not have a compression fitting on the Matco side.
 I was not referring to the compression fittings. My understanding was that compression fittings do not need any extra "help" in sealing when done correctly.
 Anyway, this is what I found on Wikipedia:
 Joint compound or Thread seal tape (a.k.a. PTFE tape, Teflon tape) is not applied to a compression fitting's threads. The compression is the means of sealing the joint, not the sealing of the threads themselves. Pipe compound or PTFE tape frequently leads to a leaks in the fitting because it allows a gap to form between the compression ring and nut in the case of Teflon tape. Joint compound is usually applied to the ferrule or olive to seal imperfections in the fitting, but really serves no purpose as the sealing is enacted through the compression ring itself; if the compression ring indeed becomes "ovalled" because it is overtightened when it is in a misoriented position in relation to the compression nut or there is some factory defect in the product, rarely does joint compound (pipe "dope") or Teflon tape compensate for the loss of an air/watertight seal. In this instance, the compression fitting are simply replaced. Joint compound and Teflon tape act to seal the threads from the water pressure in normal threaded connections, but serve little purpose in compression seals and may actually serve to weaken them.
 It sounds like fuel lube etc may actually increase the change of leaks by adversely impacting the compression of the pipe flare against the AN fitting.
 AC43.13 (page 9-1  does suggest using hydraulic fluid as a lubricant when tightening but makes no mention of anything like a sealant such as fuel lube.
 Cheers
 Les
 #40643 - Still in fibreglass hell but on a day pass
		Kelly McMullen
				 Posted: Wed Nov 11, 2009 4:28 am    Post subject: Fuel Lube on Brake Line Fittings? |
				Les,
 I believe most respondents interpreted your question correctly, and
 were answering what to use on the NPT threads, not the flare fittings.
 PTFE tape is to be avoided, because it leaves threads of PTFE on the
 fitting when removed, and can migrate into the system when
 reassembled. Fuel lube serves as a sealant that is not soluble in
 typical hydrocarbon fluids. Pipe seal paste can be used, but residue
 left on dis-assembly is still a concern.
 Kelly
 On Tue, Nov 10, 2009 at 10:49 PM, Les Kearney <kearney(at)shaw.ca> wrote:
  	  | Quote: | 	 		   Hmmm
  correctly.
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Wed Nov 11, 2009 5:19 am    Post subject: Fuel Lube on Brake Line Fittings? |
				For the panel builders, I found EZ Lube to be just the right stuff to
 dab on the end of a screwdriver to hold those pesky screws in place.
 Very handy.
				 Posted: Wed Nov 11, 2009 6:31 am    Post subject: Fuel Lube on Brake Line Fittings? |
				Les, I'm still confused here.  You said you were not referring to
 compression fittings, but your Wiki example was .... compression fittings.
 So,let's start by dividing the fittings.  Compression fittings are used
 on tubing without a flare.  I've never seen blue anodized compression
 fittings ..... but that doesn't mean they don't exist.  Compression
 fittings are typically brass, and found in the aviation isle of Ace and
 others.  They need no pipe dope or teflon tape on the compression side
 or the NPT (National Pipe Thread)side, but some lubrication with fuel
 lube or brake fluid can't hurt.  The rest of the fittings we, in
 aviation, use are 'AN' fittings, and come in steel, and in blue or red
 anodized aluminum.  The flare fitting gets it's seal from mashing the
 flared tubing between the fitting and a sleeve, pressure applied by a
 "B" nut. This isn't your standard hardware store 45 degree flare.  It's
 a 37 degree JIC flare, and is standard in hydraulic applications. This
 joint doesn't NEED anything else, but some lubrication doesn't hurt.
 Now onto the fitting side.  Since we've covered flare fittings .... and
 some AN fittings have flares on both sides, we're going to focus on
 those fittings that screw into something hard, like an aluminum block.
 These fittings use NPT (National Pipe Thread) which is a tapered thread.
   This NPT fitting doesn't usually need anything to seal it.  Sealing is
 done in the taper.  Leaks are caused by poor threading .... either the
 fitting, or the part it's screwed into.
 After all that, what about Teflon tape, or Teflon pipe dope?  Why use
 it?  You have a leak???  Well, the fitting isn't tight enough ....
 either in the taper thread side, or the "B" nut side, or there's a
 manufacturing problem.  But, you still want to put something in there. I
 don't know why, but you do.  Teflon tape isn't recommended since it can
 migrate into the tubing because when you've changed the fitting, and
 some string of Teflon tape got pushed into the hole .... and plugs
 something up down the line.  Pipe dope isn't recommended for the same
 reason .... but the pieces aren't big, and stand less chance of plugging
 something up.  Fuel lube or brake fluid on the threads for lubrication
 is OK, but by design the fittings are made to go together dry.
 Sorry for the long post, but I want to see us be safe and fly for many
 years without damage to people or aircraft.
 Linn
 Les Kearney wrote:
 [quote] Hmmm
  *_I was not_* referring to the compression fittings. My understanding
  /Joint compound or Thread seal tape (a.k.a. PTFE tape, Teflon tape) is
  the case of// Teflon// tape. Joint compound is usually applied to the
  does joint compound (pipe "dope") or// Teflon// tape compensate for the
  fitting are simply replaced. Joint compound and// Teflon// tape act to
  weaken them.///
  fitting.
  fuel lube.
  Cheers
  Les
		kearney
				 Posted: Wed Nov 11, 2009 7:55 am    Post subject: Fuel Lube on Brake Line Fittings? |
				Hi Linn
 Apologies for the confusion. My original post was referring to the NPT
 connections at the Matco brake. My follow up was because there were a couple
 of posts recommending fuel lube on all the brake line fittings - this would
 encompass the blue anodized flared compression fitting. It is my
 understanding that flared fittings are a type of compression fitting
 although not all compression fittings are flared. I stand to be corrected
 though.
 Cheers
 Les
 #40643
				 Posted: Wed Nov 11, 2009 11:51 am    Post subject: Fuel Lube on Brake Line Fittings? |
				Now, I think I understand.  Compression fittings usually have a .....
 barrel, thimble .... whatever your favorite is .... that deforms to seal
 on the tube, and also forms itself to the fitting and the nut.  Flare
 fittings aren't in the compression fitting category.  They seal by the
 mating flare and the surface area of the flare.  They will, in some
 cases, seal just fine with very little pressure.  Most all flare
 fittings I come across are way overtightened, and actually cause the
 flare material to flow outwards, which causes premature cracking of the
 now-thinner material.  Do not ask the gorilla to tighten the B-nuts.
 Linn
 Les Kearney wrote:
  Hi Linn
  though.
  Cheers
  Les
  #40643
