Richard Pike
Posted: Wed Nov 11, 2009 6:45 pm Post subject: Re: Trim System Question |
[quote="pj.ladd(at)btinternet.com"]The intention was to reduce noise >>
Hi there,
Did it? The farmer who owns the field I fly from is constantly wickering on about the noise from the Kolb. He says it is worse that the Challenger I used to have and that got him pretty hot under the collar.
Noise seems to be built in with a pusher configuration. Not noise in the cockpit, that can be dealt with by decent headphones , but the noise which causes complaints from the neighbours.
i cocked up a landing the other day and decided on another circuit for practice. I am reluctant to climb out at less than full throttle so went out at full chat and the farmer was waiting for me when i landed, looking down his nose. Of course he flies a Cub which makes no more noise than a sewing machine.
Does a larger a gap between the trailing edge and the prop help?
Pat
Pat, don't remember what engine/gearbox you are running, but recently I had a chance to fly a MKIII with a C box on the 582, and a 3 blade Warp. The 3:1 gearbox makes the prop noise way less than my 2.58:1 box. Also got to stand on the ground and listen to it while someone else flew it, and it is much quieter. Apparently prop noise is the biggie.
Richard Pike
MKIII N420P (420ldPoops)
Thom Riddle
Posted: Thu Nov 12, 2009 5:10 am Post subject: Re: Trim System Question |
Richard,
Pat and I and several other Kolbers have Jabiru power with no PSRU so the prop noise can get pretty onerous. My full throttle climb at Vy is at 3,000 rpm. The 64" prop means a tip speed of about 570 mph. Not Mach 1 but a good bit faster than most Rotax powered props.
Pat can correct me if I'm wrong but I'm pretty sure the UK does not permit his Jabiru powered Kolb to turn the maximum the engine manufacturer allows (3,300 rpm) because of the noise regulations.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
rickofudall
Posted: Thu Nov 12, 2009 6:16 am Post subject: Trim System Question |
Richard, Pat, I second this. My IIIC has a 582, C box with 4:1 and 3 blade 66" WD prop. My neighbor has told me I can barely be heard on downwind when I fly it low (700' instead of 1000'). My other neighbor flies a couple VW direct drive planes and can still be heard when he's out of sight.
Rick Girard
On Wed, Nov 11, 2009 at 8:45 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Hi there,
Pat
> [b]
Richard Pike
http://forums.matronics.com/viewtopic.php?p=272389#272389
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
Posted: Thu Nov 12, 2009 6:27 am Post subject: Trim System Question |
Pat, don't remember what engine/gearbox you are running,>>
Hi Richard,
I have a Jabiru with a 2 blade 157 cms dia.. I had a 503 with a 2 blade on
the Challenger.
Pat
