Ken Hill
Joined: 08 Apr 2006 Posts: 6 Location: Pleasanton, CA
Posted: Sat Apr 08, 2006 2:25 pm Post subject: Daylight readable PDA for GPS navigation |
I'm trying to use Mountainscope software on a Dell Axim PDA. It looks georgous in the office but when I use it in the a/c it almost unreadable. Does anybody else have the same problem?
I have put an antiglare screen on but it is still unreadable. I have also tried to reduce any white background with no improvement. I even made a little box around the screen with no improvement.
Any suggestions regarding portable daylight readable GPS systems would be greatly appreciated. I am aware of the Motion tablets
( big and expensive) and Garmen's products (single use). The UMPCs look promising but they are not available yet and do not appear to be daylight readable.
Ken
Posted: Sat Apr 08, 2006 3:09 pm Post subject: Daylight readable PDA for GPS navigation |
Hi! Ken
My Skyforce Tracker IIIc reads out ok fixed in the Mono wheel lift lever
recess (G-PTAG is a trike so the recess was unused) It is slightly off
centre view for me and has never been a problem in brilliant sun light.
P2 can't read it though since he looks across the screen.
Bob Harrison G-PTAG Europa MKI/Jabiru 3300
flyinggpa(at)comcast.net Guest
Posted: Sat Apr 08, 2006 3:35 pm Post subject: Daylight readable PDA for GPS navigation |
Ken
I found my laptop, when on battery power, reduced the intensity of the screen display. Maybe your PDA is doing that???
Cliff Shaw
1041 Euclid ave.
Edmonds, WA 98020
425 776 5555
http://www.europaowners.org/WileE
g-iani(at)ntlworld.com Guest
Posted: Sun Apr 09, 2006 2:18 am Post subject: Daylight readable PDA for GPS navigation |
I can confirm that the Axim reduces the brightness by about 50% when on
internal battery. Do you have the 12V car power lead? It will be fully
bright on this.
I am just about to try out the same combination with an Axim X51v and I
will let you know the outcome.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
M.Grass(at)comcast.net Guest
Posted: Sun Apr 09, 2006 3:07 am Post subject: Daylight readable PDA for GPS navigation |
All Axim or Windows CE users,
The brightness is adjustable and by default the brightness on battery power
is adjustable. This is not only good for daylight flying but it is also
necessary to adjust for night flying.
On the Dell Axim go to
- "Start"
- "Settings"
- Select on the bottom the tab "System"
- click on "Brightness"
here you have 1 slider for the brightness for battery power and 1 slider for
external power. Also from there, if you select here the tab "Battery Power",
you can switch the "Auto Dim" function off. My Axim will run for about 3 h
using full brightness, full processor speed and the Bluetooth GPS.
Michael Grass
A266 Trigear, Detroit.
n9zes(at)verizon.net Guest
Posted: Sun Apr 09, 2006 5:00 am Post subject: Daylight readable PDA for GPS navigation |
Cliff Shaw wrote:
Ken
My Dell PDA does have two settings for the display whether it's on
battery or on the docking station. You have to go into the setup to
adjust the display intensity.
However, I still don't think it will be bright enough even on max in the
daylight.
I was really considering using the Dell with a GPS Bluetooth receiver
and software as a GPS, but never considered until this thread came up
that I wouldn't be able to read it in bright light.
Chris
Ken Hill
Posted: Sun Apr 09, 2006 1:35 pm Post subject: Re: Daylight readable PDA for GPS navigation |
Thanks for all the prompt responses.
Bob -- Your Skyforce system looks very nice. I was unaware it existed. However, I want to fight the PDA issue a little longer before I give up.
Cliff -- I have seen screen brightness reduction before but mine is adjusted to full bright. I should have mentioned that in my writeup.
Ian -- I usually run it from a 12v. car lead in the dash. Should have mentioned that also. When do you think you will test the AximX51V? Since I'm using the original Axim, maybe the new screens are more sunlight readable. When you test your PDA if you would try it with a light shirt then a dark shirt and report the difference I'd appreciate it.
Michael --Thanks I like details.
Cris -- I hope other users will tell us how they make it work since many others currently use PDAs.
Ken
daseitz(at)cfl.rr.com Guest
Posted: Sun Apr 09, 2006 6:11 pm Post subject: Daylight readable PDA for GPS navigation |
Look at the Navaero Tpad 800. I use it with the laptop in the rear baggage
and the Tpad mounted on the tunnel. It's a daylight readable touch screen
monitor. With direct sun on the screen it's a little light but still
readable in direct sun.
http://www.navaero.com/t_pad/features_benefits.asp
Dean Seitz
dglauser(at)gmail.com Guest
Posted: Sun Apr 09, 2006 6:49 pm Post subject: Daylight readable PDA for GPS navigation |
Another route is to have a separate display with high brightness, and
use whatever computing unit you wish. The average laptop LCD has a
maximum brightness level of around 250 cd/m
2 (candelas per square
meter or nits). There are some high-brightness displays available -
for true visibility in full sunlight you really want 1000 nits or
better. http://store.earthlcd.com/ has a few - there is a 400 nit
10.4" display at
http://store.earthlcd.com/s.nl/sc.7/category.234/it.A/id.4439/.f and a
600 nit display here:
http://store.earthlcd.com/s.nl/sc.7/category.234/it.A/id.680/.f Note
that the way you get a bright display is with bright backlighting, and
that takes power. Some day we'll have truly bright displays working
from ambient light, but not yet. Sigh.
Search on "high bright lcd" and you get good hits.
http://www.vartechsystems.com/products/crystalvue/default.asp?source=google
has backlit panels fro m700 to 1800 (!!!) nits, or passive systems
that are still brighter than a standard screen. From the site:
We utilize a standard LCD and then integrate a partially reflective
mirror layer between the LCD and the backlight. When a transflective
monitor is used indoors, it is illuminated by the backlight just like
a transmissive LCD, except that the mirror layer blocks some of the
light. When a transflective LCD is used outdoors, ambient light
reflects off the mirror layer and illuminates the LCD. The
transflective monitor is brighter than a traditional monitor, however
is not as bright as a daytime viewable monitor which can be viewed in
any daytime light condition. Note, that outdoor light has to go
through the LCD twice, once on the way in and once on the way out and
this trends to make the outdoor performance of a transflective LCD not
as good as the indoor performance, where the light only has to go
through the monitor once. A transflective monitor is therefore by
definition a compromise. It can never be as bright as a transmissive
LCD indoors, and it can never be as bright as an ultra high-bright LCD
outdoors, but with transflective technology, there is no added power
requirement, the cost savings over
traditional ultra high-bright LCDs can be significant, and the need to
dissipate additional heat is minimized. The transflective monitor can
be a substitute for a daytime viewable monitor in conditions where
very bright direct sunlight is not a constant.
David
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Sun Apr 09, 2006 7:47 pm Post subject: Re: Daylight readable PDA for GPS navigation |
I've had an Axim A5 for several years now, and have written a few programs for outside use or in the car, but the screens have to be simple, big buttons, big text, limited color selections available for contrast in sunlight. GPS map relies too much on color contrast for detail information. I wouldn't buy a GPS card and software off eBay for $25, just to play with it. If the screen were twice as bright, it might be OK, but still small screen and very slow computer. And tapping on it, while in turbulence, while looking down and not for traffic, forget it. I'm passing this along especially for anyone who hasn't used these devices, to consider before spending big money for the whole package.
Fred F.
jodel(at)nildram.co.uk Guest
Posted: Mon Apr 10, 2006 4:01 am Post subject: Daylight readable PDA for GPS navigation |
I've just run a little test with three different PDA's. results are at
http://homepages.nildram.co.uk/~jodel/Europa/screentest.htm
Might be food for thought?
Simon
