Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Wed Nov 18, 2009 10:20 am Post subject: Need advice on Z16 5amp circuit breaker |
Ref Z16 schematic. There is a 5 amp circuit breaker on the wire from the main bus to the S700-2-10 Master. Can I use an in line 5 amp fuse. I would appreciate the advice. Thanks.....Geoff
Posted: Wed Nov 18, 2009 10:45 am Post subject: Need advice on Z16 5amp circuit breaker |
At 12:20 PM 11/18/2009, you wrote:
You're apparently unaware of why the breaker is even there . . .
The Z-figures are intended to display various ARCHITECTURES,
not recommended wiring diagrams and bills-of-materials. In
the case of Z-16, it shows the use of fuseblocks in combination
with a CROWBAR over voltage protection system. A panel re-setable
breaker is one of the installation requirements for a crowbar
ov protection system. So when combining with fuseblocks, the
solitary breaker illustrated is part of the system integration
task.
Now, if your choice of power distribution protection is
breakers instead of fuses then the 5A breaker would be
right on the bus and labeled ALT FIELD. If you're
going to use some form of field disconnect ov protection
system, then yes, the 5A breaker could be a fuse . . . but
not an in-line . . . it would be one of many fuses on the
main bus.
The simple answer to your question depends on the
combination of components you're planning to use. In
all cases, an in-line fuse is not a recommended
substitute in any case. If you're using fuse blocks
AND have crowbar ov protection, then you need the breaker
as suggested.
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
mprather(at)spro.net Guest
Posted: Wed Nov 18, 2009 11:18 am Post subject: Need advice on Z16 5amp circuit breaker |
Bob,
Questions about the field breaker are a relatively common. I know you
cover the reasoning for the breaker in the discussion about over voltage
protection but it seems there ends up being a disconnect when people look
at the Z diagrams. I kind of suspect that many more people look at the Z
diagrams (seeking a wiring diagram/recipe) than read all parts of the
Aeroelectric connection book, so some may miss the part about crowbars,
etc. I see that you have a descriptive note (1 regarding the crowbar
module..
Maybe it would help people if there were an additional note next to the
field breaker that said something about this being part of the crowbar OV
circuit functionality - maybe refer to your discussion about controlling
alternators. I realize you don't mind answering the same question
multiple times (in the interest of educating an ever changing classroom),
but this could be a place where a tiny amount of additional documentation
speeds the whole process.
Matt-
<nuckolls.bob(at)aeroelectric.com>
> <stol10(at)comcast.net>
task.
main bus.
as suggested.
( community. )
Geoff Heap
Posted: Wed Nov 18, 2009 11:39 am Post subject: Re: Need advice on Z16 5amp circuit breaker |
Thanks for the info Bob. Correct. I did not know why it is there......Geoff
