		capt_riney(at)yahoo.com Guest
				 Posted: Thu Nov 19, 2009 9:27 am    Post subject: Fuel Tank Strap |
				I'm putting a 20+ gal aluminum fuel tank in my kolb MIII. It rests on a 0.125" thick aluminum tray which is riveted to the fuselage cage.  My question is how to strap to the tray.  Those of you with similar tanks, do you use straps and if so, are they metal or nylon.  I've seen nylon straps used before on an aluminum tank installation but am concerned that they might not be strong enough.
 Mark Rinehart
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		russkinne(at)mac.com Guest
				 Posted: Thu Nov 19, 2009 11:21 am    Post subject: Fuel Tank Strap |
				Mark
 We've put 20 and 25-gal tanks in a Cessna tied down  with woven nylon
 or dacron straps. You won't break those.
 Russ K
 On Nov 19, 2009, at 12:26 PM, mark rinehart wrote:
  Mark Rinehart
		by0ung(at)brigham.net Guest
				 Posted: Fri Nov 20, 2009 7:43 am    Post subject: Fuel Tank Strap |
 Mark Rinehart
  	  | Quote: | 	 		  >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
 How is the tray attached?   Remember a chain is only as strong as the
 weakest link.
 On the bottom of my 16 gal alum tank, there are 2 pieces of alum angle
 welded to the bottom of the tank.  They are installed so that they match the
 tubing that the stock tank support tray would have sat on.  There are some
 tabs welded to the support tubing.  And the aluminum angle is bolted to  the
 tabs.  The mounting bolts go through  some rubber grommets to give some
 vibration dampening and the tank is also grounded to the frame.
 Make sure that if in an accident the tank does not come loose from its
 mounting, sheer the fuel lines,  well nuf said.
 Boyd Young
 Kolb mkiii
 Utah
				 Posted: Sun Nov 22, 2009 9:57 am    Post subject: Fuel Tank Strap |
 Mark R/Gang:
 Aircraft parts supply houses have 1" stainless steel strap, T-bolts, etc.,
 to fabricate normally approved aircraft fuel tank tie downs.  That is what I
 have securing my 25 gal aluminum fuel tank.  Two straps have proven
 satisfactory in my mkIII.
 Yuma, AZ
  _________________ John Hauck
Titus, Alabama |
