Phil.Perry(at)netapp.com Guest
Posted: Thu Nov 19, 2009 8:54 pm Post subject: Brake cable |
When you get the FWF kit, it will come with an extra push/pull for the parking brake. If you get it from Spruce be sure to remove that extra cable (used for the Carb) from your order. Think it's the CT-740.
No idea about the need for a spring. I think there is enough friction to not need it..
Sent: Thursday, November 19, 2009 7:53 PM
Subject: Brake cable
I'm getting ready to place my weekly order to $pruce. Included this week is the Matco parking brake (new style).
I should also order a push/pull type of cable to operate with it. So what cables have been used so far this job? Any complaints with your choice?
Also, I'd think that loading the arm on the brake with a small spring to swing the brake open would be a good idea? Touching down with the brakes on isn't something I'd like to try in my RV-10.
Phil �~� [quote][b]
dlm46007(at)cox.net Guest
I used a Bowden cable; all the way forward ,against the stop, the valve is open. Pulled aft with pressure applied to the brakes, sets the parking brake. I used a clic bond with stud and Adel clamp on the fuselage sidewall to properly move the Matco brake lever
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Thursday, November 19, 2009 8:53 PM
Phil �~� [quote][b]
Dick Sipp
Posted: Thu Nov 19, 2009 9:42 pm Post subject: Brake cable |
I used the Bowden type cable with the "T" handle and push button lock/release available from AS. I wanted this cable to be different from all the others in the quadrant of controls.
I did not use any extra springs; the valve seems to hold well and releases easily with release of the handle. Often times when I "added" some option I thought I needed they turned out to be not that useful. This is one that I use often and works well.
Dick Sipp
N110DV 190 hours
Sent: Thursday, November 19, 2009 10:53 PM
Phil �~� [quote][b]
johngoodman
Posted: Fri Nov 20, 2009 5:43 pm Post subject: Re: Brake cable |
I originally thought that a spring would be a good idea, as well. Haven't flown yet but I'm now satisfied that a spring isn't required.
John
_________________ #40572 Phase One complete in 2011 |
