Mike Whisky
Posted: Fri Nov 20, 2009 12:19 pm Post subject: Nose wheel nut wrench |
Where can I get this large wrench used to torque the nose wheel nut?
Best
Michael
_________________ RV-10 builder (flying)
#511 |
jeff(at)westcottpress.com Guest
Posted: Fri Nov 20, 2009 12:44 pm Post subject: Nose wheel nut wrench |
David McNeill makes a nice one...
On Nov 20, 2009, at 12:19 PM, Michael Wellenzohn wrote:
Where can I get this large wrench used to tie the nose wheel nut?
Best
Michael
RV-10 builder (avionics, wiring)
#511
http://forums.matronics.com/viewtopic.php?p 73987#273987
dlm46007(at)cox.net Guest
Posted: Fri Nov 20, 2009 2:14 pm Post subject: Nose wheel nut wrench |
Water pump pliers
Posted: Fri Nov 20, 2009 2:49 pm Post subject: Nose wheel nut wrench |
Big channel locks with duct tape on the teeth.
Do not archive.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
On Nov 20, 2009, at 5:13 PM, "David McNeill" <dlm46007(at)cox.net> wrote:
Water pump pliers
ricksked(at)embarqmail.co Guest
Posted: Fri Nov 20, 2009 3:01 pm Post subject: Nose wheel nut wrench |
Silly me...I went to Sears and bought the socket.....duh... ;'
Sent via BlackBerry by AT&T
partner14
Posted: Fri Nov 20, 2009 3:04 pm Post subject: Nose wheel nut wrench |
For those of you not to this point yet... do yourselves a favor and drill a 2nd hole through the front axle.... if you don't you will almost always end up with too little torque or too much. Because of the nut and use of cotter pin, we are limited to 60 degrees, 1/6th turn to get it right. Drilling a 2nd hole, you can at least get closer to optimum (30 degrees, 1/12th of a turn.
Don McDonald
--- On Fri, 11/20/09, David McNeill <dlm46007(at)cox.net> wrote:
Subject: RE: Nose wheel nut wrench
Date: Friday, November 20, 2009, 2:13 PM
--> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Water pump pliers
40636 |
partner14
Posted: Fri Nov 20, 2009 3:06 pm Post subject: Nose wheel nut wrench |
Does the duct tape go on your teeth because you're tightening so much?
--- On Fri, 11/20/09, Jesse Saint <jesse(at)saintaviation.com> wrote:
Subject: Re: Nose wheel nut wrench
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Friday, November 20, 2009, 2:48 PM
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Do not archive.
Jesse Saint
Saint Aviation
352-427-0285
On Nov 20, 2009, at 5:13 PM, "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] --> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Water pump pliers
40636 |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Fri Nov 20, 2009 3:19 pm Post subject: Nose wheel nut wrench |
no. It goes on your wife's mouth for obvious reasons.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Posted: Fri Nov 20, 2009 3:20 pm Post subject: Nose wheel nut wrench |
yeah and for the wheel axles with extensions I went to the farm
store and bought a "bigass" combination wrench and cut it in half for
easier maneuvering. Gotta love them tools.
BTW: harbor freight has a flyer out with the infared laser thermometer
on sale for under $30. When you need one they're awesome.
Posted: Fri Nov 20, 2009 3:44 pm Post subject: Nose wheel nut wrench |
Lol...if you have a wife I hope her sense of humor is as good as your response....I've known a few women in my time that liked duct tape...but never on their mouths...wouldn't hold up very long!!!
Posted: Fri Nov 20, 2009 4:22 pm Post subject: Nose wheel nut wrench |
.. sorry, I got my David McNeills and Don McDonalds confused... (I've
been talking to both of them lately). Don McDonald gave me a very
nice wrench.
Best
Michael
#511
partner14
Posted: Fri Nov 20, 2009 4:56 pm Post subject: Nose wheel nut wrench |
Hey, wait a minute, Rick and Deems have met my wife.... they know she doesn't need the tape.... on the other hand, me, maybe.
Don
Date: Friday, November 20, 2009, 3:13 PM
40636 |
partner14
Posted: Fri Nov 20, 2009 5:00 pm Post subject: Nose wheel nut wrench |
Jeff, you mean that wrench I gave you fits the main gear nuts and the front axle nut???? Shucks, if I'd known that I would have charged you twice as much! Wait, 2 times 0.... is still 0.... I can't win.
Don
--- On Fri, 11/20/09, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
Date: Friday, November 20, 2009, 4:09 PM
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
... sorry, I got my David McNeills and Don McDonalds confused... (I've
nice wrench.
40636 |
Posted: Fri Nov 20, 2009 6:59 pm Post subject: Nose wheel nut wrench |
Great idea Don! It may be easier to drill the hole in the nut however.
P
Sent: Friday, November 20, 2009 3:00 PM
For those of you not to this point yet.... do yourselves a favor and drill a 2nd hole through the front axle.... if you don't you will almost always end up with too little torque or too much. Because of the nut and use of cotter pin, we are limited to 60 degrees, 1/6th turn to get it right. Drilling a 2nd hole, you can at least get closer to optimum (30 degrees, 1/12th of a turn.
Don McDonald
Water pump pliers
robin1(at)mrmoisture.com Guest
Posted: Fri Nov 20, 2009 9:19 pm Post subject: Nose wheel nut wrench |
It's easy to remember:
Don McDonald had a wrench, E-I-E-I-O
I agree completely with drilling the nut or extra hole concept. We
drilled the nut after finding one was too tight and one was too loose.
The other day I was heading out for my regular commute when I saw a
friend in his sweet F33 Bonanza in the run up area. We waved and he was
off for his left downwind. I completed my run-up as another two
departures and an arrival proceeded my left downwind. I ended up passing
the F33 at on my way through 8,000' to 9,500'. I was climbing faster and
at a greater rate of climb. While we were not that close to each other
he did comment that he could see my "shit eating grin." All I could say
is that its an "official RV Shit eating grin" thank you very much and
shit never tasted so good!
The more I fly the -10 the more I like it. I am not sure if it's the
avionics suite, the comfort or it's utilitarian nature but it is one
terrific airplane.
Keep building and fly safe,
Robin
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, November 20, 2009 5:57 PM
P
From: Don McDonald <mailto:building_partner(at)yahoo.com>
Don McDonald
<http://us.mc537.mail.yahoo.com/mc/compose?to=dlm46007(at)cox.net> >
Water pump pliers
