Posted: Sat Nov 21, 2009 7:44 am Post subject: side baffles side |
I am leaning toward using a single piece side baffle on both sides
versus the 3 piece that comes with the VAN's kit. Any one see any issues
with doing so? I know the industry standard is three (one per
cylinder)and I gather there is a reason for that (movement of cylinders)
so not sure if having a single piece will cause any issues..
Thanks!
P
Tim Olson
Posted: Sat Nov 21, 2009 8:24 am Post subject: side baffles side |
You wouldn't like it if it came time to remove a cylinder.
You'd have a LOT more work to do.
Tim Olson - RV-10 N104CD
Pascal wrote:
Thanks!
P
partner14
Posted: Sat Nov 21, 2009 9:04 am Post subject: side baffles side |
Tim, how is it more work to do,,,, Only 7 screws holding it on the side, a few in fromt, and a few in back. And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also, help me out here.... is removing a cylinder something that I'm going to have to do very often?
Thanks, Don McDonald
--- On Sat, 11/21/09, Tim Olson <Tim(at)myrv10.com> wrote:
Subject: Re: side baffles side
Date: Saturday, November 21, 2009, 8:23 AM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Pascal wrote:
| Quote: | --> RV10-List message posted by: Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
so not sure if having a single piece will cause any = this year's Terrific Free Incentive Gifts provided
matronics.com/contribution"   href="http://www.matronics.com/Navigator?RV10-List" target=_blank>httpbsp; --> h
40636 |
deej(at)deej.net Guest
Posted: Sat Nov 21, 2009 9:35 am Post subject: side baffles side |
On 11/21/2009 12:02 PM, Don McDonald wrote:
| Quote: | and also, help me out here.... is removing a cylinder something that I'm
Depends...
<http://aero-news.net/index.cfm?ContentBlockID=420682ed-fa3d-46bc-82bd-e84403417e8a&>
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
Posted: Sat Nov 21, 2009 9:49 am Post subject: side baffles side |
It's enough work getting the front & back assemblies on as it is without having them tied together. Why add the fabrication work of making it all 1 piece?
Jesse SaintSaint Aviation
352-427-0285
On Nov 21, 2009, at 12:02 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]Tim, how is it more work to do,,,, Only 7 screws holding it on the side, a few in fromt, and a few in back. And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also, help me out here.... is removing a cylinder something that I'm going to have to do very often?
--- On Sat, 11/21/09, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
From: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
--> RV10-List message posted by: Tim Olson <[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]>
Pascal wrote:
| Quote: | --> RV10-List message posted by: Pascal <[url=mailto:rv10builder(at)verizon.net]rv10builder(at)verizon.net (rv10builder(at)verizon.net)[/url]>
[/url] | [url=http://forums.matronics.com/]
ricksked(at)embarqmail.co Guest
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> As much as your flying Don....yes. Your due for a cylinder change very soon.
Sent via BlackBerry by AT&TFrom: Don McDonald <building_partner(at)yahoo.com>
Date: Sat, 21 Nov 2009 09:02:00 -0800 (PST)
Subject: Re: RV10-List: side baffles side
Tim, how is it more work to do,,,, = Only 7 screws holding it on the side, a few in fromt, and a few in back.&n= bsp; And the ones in the front and back are there no matter how many pieces= the baffle is made from.... and also, help me out here.... is removi= ng a cylinder something that I'm going to have to do very often?
--- On Sat, 11/21/09, Tim Olson [i]<Tim(at)myrv10.com></= I> wrote:
Subject= : Re: RV10-List: side baffles side
Date: = Saturday, November 21, 2009, 8:23 AM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
You wouldn't l= ike it if it came time to remove a cylinder.
You'd have a LOT more work = to do.
Pascal = wrote:
| Quote: | I am leaning toward using a single piece side baffle on both si= des
versus the 3 piece that comes with the VAN's kit. Any one see a= ny issues
with doing so? I know the industry standard is three (one= per
cylinder)and I gather there is a reason for that (movement of = cylinders)
so not sure if having a single piece will cause any =3D this year's Terrific Free Incentive Gifts provided
= matronics.com/contribution"  = href=3D"http://www.matronics.com/Navigator?RV10-List" target=3D_blank>http= bsp; --> h=
=0A=0A [quote][b]
Posted: Sat Nov 21, 2009 10:54 am Post subject: side baffles side |
Thank you for the reply.
While I am flying however, would there be any issue with a single sided
baffle. I am thinking does the baffle need to move at all, is there a
heat expansion issue that having three separate pieces would allow for
expansion and contraction, etc..
Thanks!
P
On Sat, 2009-11-21 at 10:23 -0600, Tim Olson wrote:
> Thanks!
> P
Posted: Sat Nov 21, 2009 12:23 pm Post subject: side baffles side |
You'll wind up with three pieces sooner or later anyway. Starting out
with three pieces means you get to pick where the cracks go.
Linn
Pascal wrote:
Thanks!
P
Kellym
Posted: Sat Nov 21, 2009 2:25 pm Post subject: side baffles side |
IIRC, TCM lifters come out without splitting the case, however if the
cam is damaged the engine will have to come out entirely to send back to
TCM for repair. On new Lycoming engines you should not have any cam or
lifter distress with the roller cam, but if you do, it is still pull the
engine and tear it down, not a cylinder removal. Only ring, piston,
valve, and piston pin plug problems are likely to cause a cylinder
removal by itself.
Dj Merrill wrote:
Depends...
-Dj
KCHD |
partner14
Posted: Sat Nov 21, 2009 5:22 pm Post subject: side baffles side |
Jesse, because I built a plenum, I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles. It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top.... so it's already setup.... I'm going to make Pascal a set, and he/we were just trying to find out if there were any additional issues.
Linn, as to your statement about them ending up in 3 pieces anyway.... I use a floating system whereas the screws tighten down on stainless shims, thicker than the baffles, thereby letting the aluminum baffle float. So far 90 hours, no issues.
Thanks guys, Don
--- On Sat, 11/21/09, Jesse Saint <jesse(at)saintaviation.com> wrote:
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Saturday, November 21, 2009, 9:41 AM
Jesse Saint Saint Aviation
352-427-0285
On Nov 21, 2009, at 12:02 PM, Don McDonald <building_partner(at)yahoo.com> wrote:
| Quote: | Tim, how is it more work to do,,,, Only 7 screws holding it on the side, a few in fromt, and a few in back. And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also, help me out here.... is removing a cylinder something that I'm going to have to do very often?
Pascal wrote:
| Quote: | --> RV10-List message posted by: Pascal <rv10builder(at)verizon.net>
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
blank rel=nofollow>http://www.matronics.com/contribution
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
1.9 MB |
5002 Time(s) |
1.76 MB |
5002 Time(s) |
40636 |
Posted: Sat Nov 21, 2009 9:33 pm Post subject: side baffles side |
With an engine that pretty C how do you justify a cowling.
Date: Sat C 21 Nov 2009 17:11:46 -0800
Jesse C because I built a plenum C I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles. It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top.... so it's already setup.... I'm going to make Pascal a set C and he/we were just trying to find out if there were any additional issues.
Linn C as to your statement about them ending up in 3 pieces anyway... I use a floating system whereas the screws tighten down on stainless shims C thicker than the baffles C thereby letting the aluminum baffle float. So far 90 hours C no issues.
Thanks guys C Don
--- On Sat C 11/21/09 C Jesse Saint <jesse(at)saintaviation.com> wrote:
Date: Saturday C November 21 C 2009 C 9:41 AM
352-427-0285
On Nov 21 C 2009 C at 12:02 PM C Don McDonald <building_partner(at)yahoo.com> wrote:
| Quote: | Tim C how is it more work to do C C C C Only 7 screws holding it on the side C a few in fromt C and a few in back. And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also C help me out here.... is removing a cylinder something that I'm going to have to do very often?
Thanks C Don McDonald
--- On Sat C 11/21/09 C Tim Olson <Tim(at)myrv10.com> wrote:
Date: Saturday C November 21 C 2009 C 8:23 AM
partner14
Posted: Sat Nov 21, 2009 10:18 pm Post subject: side baffles side |
Thanks John, tried it without, but it doesn't cool very well!
--- On Sat, 11/21/09, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
Subject: RE: side baffles side
To: "RV 10 group" <rv10-list(at)matronics.com>
Date: Saturday, November 21, 2009, 9:32 PM
With an engine that pretty, how do you justify a cowling.
Date: Sat, 21 Nov 2009 17:11:46 -0800
Thanks guys, Don
352-427-0285
40636 |
Posted: Sun Nov 22, 2009 4:29 am Post subject: side baffles side |
Well, I was hoping to avoid admitting that I 'had a better idea' when I
rebuilt my baffles on my Pitts. I didn't want to rivet the plates that
capture the adjacent part .... so did it in one piece. I bolted the
single part on .... and about 1 year on the new part .... it started to
crack. Stop-drilled the crack didn't keep it from migrating. Over
about 4 years .... I had 6 pieces .... with the capture plates riveted
on. When I got cracking from the mounting holes I rebuilt with 3 pieces.
Maybe having them float would have prevented the cracking.
Linn
Don McDonald wrote:
| Quote: | Jesse, because I built a plenum, I also built the side panels so I could
Thanks guys, Don
partner14
Posted: Sun Nov 22, 2009 9:49 am Post subject: side baffles side |
Thanks Linn for the input.... that's what Pascal and I were looking for.... I am hoping that by being able to float on the screws, it will avoid the cracking issue.
Don McDonald
Flying, and lovin it.
--- On Sun, 11/22/09, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Date: Sunday, November 22, 2009, 4:27 AM
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Well, I was hoping to avoid admitting that I 'had a better idea' when I rebuilt my baffles on my Pitts. I didn't want to rivet the plates that capture the adjacent part .... so did it in one piece. I bolted the single part on .... and about 1 year on the new part ... it started to crack. Stop-drilled the crack didn't keep it from migrating. Over about 4 years .... I had 6 pieces .... with the capture plates riveted on. When I got cracking from the mounting holes I rebuilt with 3 pieces. Maybe having them float would have prevented the cracking.
Linn
Don McDonald wrote:
| Quote: | Jesse, because I built a plenum, I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles. It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top.... so it's already setup.... I'm going to make Pascal a set, and he/we were just trying to find out if there were any additional issues. Linn, as to your statement about them ending up in 3 pieces anyway.... I use a floating system whereas the screws tighten down on stainless shims, thicker than the baffles, thereby letting the aluminum baffle float. So far 90 hour========================http://www.matronicsp; -Matt Drathe r?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List
60.77 KB |
4975 Time(s) |
40636 |
