Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sun Nov 22, 2009 8:07 pm Post subject: Landing lights |
2 Duckworks DS1 35w for $740 or the 50w for $500. Why not buy the brighter for less? Anyone know which is better? pros/cons?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Posted: Sun Nov 22, 2009 8:25 pm Post subject: Landing lights |
Tough call. I have the 2 35W bulbs, since mine have been around a
while. I really think it's nice having the even lighting
of doing it on each wing. My old plane had one on the Left, with
2 bulbs, and the distribution wasn't as nice on the right side
of the runway. If it were a nose bulb, no big deal, but for a
wing it's kind of nice to have one per side. I can tell you that
the 35W bulbs are powerful enough in HID form that I wouldn't
bother with the 50W unless they were very close in price.
The catch is, you're comparing one bulb to two, which makes it
a tougher decision.
Tim Olson - RV-10 N104CD
Strasnuts wrote:
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 74373#274373
Strasnuts
Posted: Sun Nov 22, 2009 8:33 pm Post subject: Re: Landing lights |
I should have written (2)DS1 35w HID's for $740 or (2)50w HID's for $500. Why is the more powerful light more expensive. 500,000 candle light vs 320,000?
780 Hours
Strasnuts
Posted: Sun Nov 22, 2009 9:07 pm Post subject: Re: Landing lights |
I guess I should read more before I bother everyone on Matronics. I just read about the igniter being installed at the lamp than at the ballast which reduces interference noise and shock. I will do Q and A by myself more often. Thanks Tim, I will be buying the 35w phillips for each wing.
780 Hours
Tim Olson
Posted: Sun Nov 22, 2009 9:11 pm Post subject: Landing lights |
I can't remember what changed when they came out. I'd call Don and
ask personally. It may just be that the 50w are more "common". I
suppose some people may want lower power draw too. I think the 50w
may be rectangular while the 35w are round but don't quote me on that.
Unless quality is different, I'd just go with the cheaper of the two
on a new install.
You'll love the HIDs!
On Nov 22, 2009, at 10:33 PM, "Strasnuts" <sean(at)braunandco.com> wrote:
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 74375#274375
Posted: Sun Nov 22, 2009 10:33 pm Post subject: Landing lights |
I have the Duckworth dual 35W and as I have posted many times I think
they are fantastic.
That being said on my 8A I am placing dual 50W Automotive HID's
available online. Something like $135/pair with water proof ballast that
you can hit with a hammer (saw it on a video some place). You can even
choose the light temperature (color) from a range of about 6. Keep in
mind these are bulbs/ballast/wiring, no lens. The lenses are available
through any NAPA type place for $6.00 each. The old RV builders use to
use these housings all the time for lighting but now they fit HID bulbs.
Between the automotive HID & automotive LED position lights plus Strobes
N More power supply & strobes and an aviation Strobe/LED tail light I
think my entire lighting system is about $500. I think it will compare
favorably against any other lighting package out there.
Robin
dlm46007(at)cox.net Guest
Posted: Mon Nov 23, 2009 2:40 am Post subject: Landing lights |
I used the 50 watt www.planelights.com. Brighter is better
Strasnuts
Posted: Mon Nov 23, 2009 7:05 am Post subject: Landing lights |
Websites robin?
Sent via BlackBerry from T-Mobile
780 Hours
Posted: Mon Nov 23, 2009 12:23 pm Post subject: Landing lights |
You can also get drop in replacement for the Vans lights. See
www.planelights.com (guy who also does off road vehicle lights); the
pictures are my installation on my 10.
Strasnuts
Posted: Mon Nov 23, 2009 12:30 pm Post subject: Re: Landing lights |
Well this info gives me plenty of time to look at the internet instead of fiberglass work:)
Thanks for the info.
780 Hours
