BruceE7837(at)aol.com Guest
Posted: Tue Nov 24, 2009 10:59 am Post subject: Model 4 tail wheel spring |
I'm completing a Model 4 started years ago by someone else. My kit has a single leaf tail wheel spring, and its been suggested that I add a second leaf for safety, should the first leaf break. I'm concerned about the tail spring being too stiff. The single spring is about 3/16 thick, and is already pretty stiff. What does the list think? Bruce Estes
sourdostan(at)aol.com Guest
Posted: Tue Nov 24, 2009 11:37 am Post subject: Model 4 tail wheel spring |
Buy the 2-leaf (actually 2 and one-half) from John McBean. My single spring set-up broke and I replaced it with John's, which is doing well and isn't too stiff.
Stan Specht
Model-IV Speedster 1600 hrs.
Lakewood, CO
jareds(at)verizon.net Guest
Posted: Tue Nov 24, 2009 11:55 am Post subject: Model 4 tail wheel spring |
I just ordered a leaf from kfox and they only sell in a complete kit unfortunately. It comes with 3 leafs but the stud on bottom is only long enough for two which is what i have always had and that is a perfect amount of cushion for my model 4. I have had some hard landings and fly in badlands of SD and would not fly with less than 2 springs.
Just my opinion. Also when i had to trailer the fox out recently of a winter wheat field i didnt have a chance to empty the fuel and the weight alone broke the tail spring after only a few bumps on a flatbed trailer.
bw12345(at)sbcglobal.net Guest
Posted: Tue Nov 24, 2009 5:53 pm Post subject: Model 4 tail wheel spring |
Who is John McBean and how do you get in touch?
BOB
--- On Tue, 11/24/09, sourdostan(at)aol.com <sourdostan(at)aol.com> wrote:
From: sourdostan(at)aol.com <sourdostan(at)aol.com>
Subject: Re: Kitfox-List: Model 4 tail wheel spring
Date: Tuesday, November 24, 2009, 2:31 PM
Stan Specht
Lakewood, CO
MDKitfox(at)aol.com Guest
Posted: Tue Nov 24, 2009 6:17 pm Post subject: Model 4 tail wheel spring |
You can reach John, president of Kitfox, LLC at:
Contact Info
Please contact us... | Quote: | | Quote: | 123 Airport Way
PO Box 997
Homedale, ID 83628 USA
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Nov 24, 2009, at 8:48 PM, Robert Rivard wrote:
[quote]Who is John McBean and how do you get in touch?
BOB
--- On Tue, 11/24/09, sourdostan(at)aol.com (sourdostan(at)aol.com) <sourdostan(at)aol.com (sourdostan(at)aol.com)> wrote:
From: sourdostan(at)aol.com (sourdostan(at)aol.com) <sourdostan(at)aol.com (sourdostan(at)aol.com)>
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Stan Specht
Lakewood, CO
Lynn Matteson
Posted: Wed Nov 25, 2009 6:00 am Post subject: Model 4 tail wheel spring |
Ditto what Stan said...if it's good enough for Stan "the man", it's
good enough for me. : )
Actually I modified my "half-spring" by shortening it to soften the
ride a bit. It wasn't quite enough softening, so the next time I have
the notion, I'll cut a little bit more off the length of the half-
spring/ helper spring/ booster spring....whatever it's called.
Lynn Matteson
Jabiru 2200, #2062, 814.7 hrs
Countdown to 1000 hrs~185 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Nov 24, 2009, at 2:31 PM, sourdostan(at)aol.com wrote:
[quote] Buy the 2-leaf (actually 2 and one-half) from John McBean. My
Stan Specht
Lakewood, CO
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Pat Reilly
Posted: Wed Nov 25, 2009 7:43 am Post subject: Model 4 tail wheel spring |
Bob, John McBean owns what used to be Kitfox. Google up Kitfox and you will see the link to his store and ph#. I also have his 3 leak spring. I used only the 2 full length leaves. I rearched them to get proper castor angle on my tail wheel. I also had the 1 piece aluminum bar they called a "spring". I sold it to someone that wanted to use what was originally supplied with his plane even though they appear to be junk in my mind.
Hey guys airworthy inspection scheduled for 1 week from tomorrow!
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Tue, Nov 24, 2009 at 7:48 PM, Robert Rivard <bw12345(at)sbcglobal.net (bw12345(at)sbcglobal.net)> wrote:
[quote] Who is John McBean and how do you get in touch?
BOB
Stan Specht
Lakewood, CO
