jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Tue Nov 24, 2009 6:19 pm Post subject: Main Gear Shimmy - While Braking |
We have been working on solving a main gear shimmy while braking. First just to clarify our symptoms, after landing, after the nose wheel comes down, as soon as we went to the brakes we got a shimmy. If we did not use the brakes we did not have a shimmy. We visually confirmed it was main gear shimmy. We also had a scalloped wear patter starting on our mains (80 hours TT).
I may be stating something very obvious, but the fix was very simple, we had to re-torque our axle nuts. Tightened up the nuts, and the shimmy is gone.
Just passing along an experience.....
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Nov 24, 2009 7:12 pm Post subject: Main Gear Shimmy - While Braking |
This is why I think a lot of the gear legs are misaligned. My right gear was toed in and my left was toed out until I drilled the left gear to match the right at 1.10 degrees in.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
jkreidler
Posted: Wed Nov 25, 2009 4:17 am Post subject: Re: Main Gear Shimmy - While Braking |
I am not sure I understand your statement.... Please expand.
My point in passing this along was really to say that for us (again for us), the fix was as simple as tightening the axle nut. This solution came after checking toe, contemplating balancing tires, researching brake failure modes, etc.
In the end after hours of head scratching it was just a basic maintenance item. Possibly everyone on the list who has faced main gear shimmy issues has a different problem, but I could not find this solution anywhere. I also couldn't find a case of someone who changed their toe setting and solved the problem.
Posted: Wed Nov 25, 2009 9:52 am Post subject: Main Gear Shimmy - While Braking |
I see that on mine also Rt In C Lf Out. Problem is not necessarily corrected by changing the hole location as it may be the bend in the gear leg itself.
[quote] To: rv10-list(at)matronics.com
Subject: Re: Main Gear Shimmy - While Braking
Date: Wed C 25 Nov 2009 03:06:28 +0000
--> RV10-List message posted by: sean(at)braunandco.com
Strasnuts
Posted: Wed Nov 25, 2009 7:14 pm Post subject: Re: Main Gear Shimmy - While Braking |
jkreidler,
Sorry about the reply, I received it on my phone and didn't see your fix from the weird format on my phone. I just thought you had a shimmy and you didn't know what was wrong.
780 Hours
ajs_pvt_1(at)sbcglobal.ne Guest
Posted: Wed Nov 25, 2009 7:34 pm Post subject: Main Gear Shimmy - While Braking |
Not obvious so some of the lesser experienced here (i.e. me). Thanks
for the info!
Andrew Stryker
Building - Empennage
jkreidler wrote:
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p 74711#274711
