thane
Posted: Wed Nov 25, 2009 5:22 pm Post subject: G-430/W wont aquire gps signal |
Just wanted to see if anyone has had a similar problem??
I have a G-430 /W and after 6 weeks of down time to complete Conditional Inspection, I am unable to get the unit to aquire a signal and thus position. It has done this in the past maybe 5-6 times but always came up within 5 minutes or so.
Today I was unable to get to work by powering the unit down.
Any ideas or input would be great.
Thane States
N321BY
80 hrs.
[quote] | Quote: |
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
| [b]
_________________ Working on finish kit: I hate fiberglass!! |
Posted: Wed Nov 25, 2009 5:40 pm Post subject: G-430/W wont aquire gps signal |
You may need to ensure the time is correct and give it a rough idea of where it is located. Also, make sure it is outside and can 'see' the satellites (not trying to be a smart (at)ss) - I used an extension cable on my GPS antenna to put it outside the hangar when I couldn't roll my plane around. Also, part of my oil-change requires me to remove my GPS antenna (it's mounted under the cowl and is in the way of the wrench to loosen the fliter) - so I test mine after each oil change too...just some thoughts
Before I swapped out my GX60 for a GNC420W, the GX60 needed a little help in figuring out where it was.
Something to try - haven't had this problem with the new 420W....
jim(at)CombsFive.Com Guest
Posted: Wed Nov 25, 2009 5:47 pm Post subject: G-430/W wont aquire gps signal |
Couple of things to check:- Make sure you are not in a metal hanger (Visible Sky). Sounds silly, but the unit must be able to see the sky.- Check the cable to the GPS antenna. It is an active antenna and gets DC power from the 430W. Make sure the connections are good and no stray shield wire strands are creating shorts.- Make sure antenna location is optimum. On the top of the instrument panel, top of the fuselage or way out under the cowling away from the firewall.Jim C (N312F - Flying 140 hours - almost ready to do first condition inspection)--------------------------------------------------Just wanted to see if anyone has had a similar problem??I have a G-430 /W and after 6 weeks of down time to complete ConditionalInspection, I am unable to get the unit to aquire a signal and thusposition. It has done this in the past maybe 5-6 times but always came upwithin 5 minutes or so.Today I was unable to get to work by powering the unit down.Any ideas or input would be great.Thane StatesN321BY80 hrs. [quote][b]
Deems Davis
Posted: Wed Nov 25, 2009 6:27 pm Post subject: G-430/W wont aquire gps signal |
I've had this problem before, after being down for some period of time.
The solution for me was to let the GPS search for up to 20-30 minutes.
I'm not a rocket scientist, but the position of the satellites has
likely changed since you went down for inspection, and when I talked to
the GPS gurus' (at) Freeflight they said it could easily take 20 + minutes
particularly if the plane was moved from it's last 'on' position.
Deems Davis
N519PJ
www.deemsrv10.com
Thane States wrote:
| Quote: | Just wanted to see if anyone has had a similar problem??
Thane States
N321BY
80 hrs.
thane
Posted: Thu Nov 26, 2009 9:11 am Post subject: G-430/W wont aquire gps signal |
Deems, thanks for that info, that may be what it needs. I was not able with
the short flight's to be airborn for more than 10 minutes or so. I hope
that is it.
Thane
Deems Davis
Posted: Thu Nov 26, 2009 10:51 am Post subject: G-430/W wont aquire gps signal |
Try dragging the plane out of the hangar, powering it up and let it
'search for 30 minutes.
able with the short flight's to be airborn for more than 10 minutes or
so. I hope that is it.
Thane
Nick Nafsinger
Posted: Fri Nov 27, 2009 2:46 pm Post subject: Re: G-430/W wont aquire gps signal |
You can also try a factory reset. Hold down the CLR key when powering up. This clears the internal memory, including any user points and flight plans... Then let it reaquire (10-20 min).
_________________ RV-10 40569
Flying! |
