riveting the cabin top
roxianmike(at)msn.com
PostPosted: Thu Nov 26, 2009 5:09 pm    Post subject: riveting the cabin top Reply with quote
So I can no longer avoid it..........I am going to rivet on my cabin top this weekend.  I have avoided it as long as possible to enjoy the advantage of having good access to the tailcone as I discovered more and more things I wanted to do back there........but I digress.
I saw this morning that the plans call for CS4-4 rivets for attachment of the cabin top to the side skins.  Has anyone used solid rivets C as I clearly have access to buck them?  Would that be an improvement? Would that potentially damabe the composite from the impact of driving the rivets?
Thanks in advance for any thoughts on it.
egohr1
PostPosted: Thu Nov 26, 2009 5:28 pm    Post subject: Re: riveting the cabin top Reply with quote
the cs-4 rivets will not damage the composite top and are used in shear between the two aluminum layers. If you use solid rivets you will damage the epoxy / glass as the rivet expands.
Use the cs-4's
eric gohr
EGOHR86@alumni.carnegiemellon.edu
Strasnuts
PostPosted: Thu Nov 26, 2009 5:28 pm    Post subject: riveting the cabin top Reply with quote
I read on Tim olsens site that he tried it. I won't try to remember what he stated but you can look it up on his site.
Sent via BlackBerry from T-Mobile
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rv10rob(at)gmail.com
PostPosted: Thu Nov 26, 2009 5:38 pm    Post subject: riveting the cabin top Reply with quote
I used the CS4-4s.  Most people I've talked to who used solid rivets said it wasn't worth it.  Tim's comments sum it up pretty well:
http://myrv10.com/N104CD/fuselage/20050816/index.html
-Rob
On Thu, Nov 26, 2009 at 5:05 PM, Roxanne and Mike Lefever <roxianmike(at)msn.com (roxianmike(at)msn.com)> wrote:
I saw this morning that the plans call for CS4-4 rivets for attachment of the cabin top to the side skins.  Has anyone used solid rivets, as I clearly have access to buck them?  Would that be an improvement? Would that potentially damabe the composite from the impact of driving the rivets?
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
ttp://forums.matronics.com
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
Phil.Perry(at)netapp.com
I have heard that Van’s selected pulled rivets over solid rivets, so we don’t break any glass pounding the rivet head. Ultimately causing structural issues.
Most people lay a layer of 2 oz glass over the top of the pulled rivets to hide the rivet heads.
Phil
From: Roxanne and Mike Lefever [mailto:roxianmike(at)msn.com]
Sent: Thursday, November 26, 2009 7:06 PM
Subject: riveting the cabin top
PostPosted: Thu Nov 26, 2009 6:45 pm    Post subject: riveting the cabin top Reply with quote
Thanks for multiple great replys..........CS4-4s it is!
Subject: Re: riveting the cabin top
Date: Fri C 27 Nov 2009 01:23:34 +0000
.ExternalClass .ecxhmmessage P {;} .ExternalClass body.ecxhmmessage {font-size:10pt=3B font-family:Verdana;} I read on Tim olsens site that he tried it. I won't try to remember what he stated but you can look it up on his site. Sent via BlackBerry from T-Mobile
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Date: Thu C 26 Nov 2009 18:05:51 -0700
So I can no longer avoid it..........I am going to rivet on my cabin top th= is weekend. =3B I have avoided it as long as possible to enjoy the adva= ntage of having good access to the tailcone as I discovered more and more t= hings I wanted to do back there........but I digress.
 =3B
I saw this morning that the plans call for CS4-4 rivets for attachment of t= he cabin top to the side skins. =3B Has anyone used solid rivets=2C as = I clearly have access to buck them? =3B Would that be an improvement? W= ould that potentially damabe the composite from the impact of driving the r= ivets?
 =3B
¦·›~‰í² CÞÜ=œ¢Z+ÓM4ÓGÚqíÃr‹«‰êç{(º¸ž¯p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷ ù^jÇ’ºšh®Ö(º²â²Û†+ ¢{aÜ0'tg­J‰ža8ÁDA‰ûlÜ=Ã6‹Þ™·«ŠËax 繩KŠËEºwQj+¬)brJ'Ü;ax*'¶¸›ºØ¨žX§‘·¥£ h~)Ý¢ëf¢·šn‹­Ü;aŠÌžj»zºâ~'­çˆ�ǧ¶+Þ'í²šè¾'^wpÛËpÀzº•ç-®'†·ŸÜ8m¶Ÿÿà zº•ç-®'¢l0Á§«¡é^rÚâqÊ&ý­ÃN�º)]z»¢‰ C¶ŠÞjÞpá¶Úÿ 0nè¥uêìnŠ$±Ê&à º)]z»¢‰ Cr‰¿kpÇ¢g›º)mBÏjÞpá¶Úÿ 0†‰žn襶¥¥Ê&à !¢g›º)m…éir‰¿kp÷ ¸¬´*'¶¸›ºØ¨�g›J+^Ü=ÃjÞpá¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨žm§ÿðà š¶º'‰Ë¢oÜ¢{k‰»­Š‰ÿkp÷ 8ZžL¨¹ú+Ê‹«�éÞ®‹¬²êi¢»wpÌjÛC­©ex¸¬´fŠ}ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ4áyuи¬´IšŠQh®é· K¶ŒjÚèž' C.+-æ­º·¬5«â�«h®Ú®Œ C{pí…隟"â²Û­ŠX­‰ë C¹ÈZ°¸¬µIÿJæìr¸©¶*'Ü0+r¯y'š­ÈC£ å¡§{ ¬�®Œ Cx(Z´PÜ3á¢Ú C…ªÞjwf¹Èf¹Èf¢··pÚ†·ŸÜ8m¶Ÿÿà &jÚèž' Cr‰¿5«â�«h­u謶m§ÿðà š¶º'‰Ë¢oÍjø jÚ+E]t.+-ý­ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ3�M� $–NECÜ4š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›ŠîšÍÃÜ6¡­ç÷m§ÿߢ»¦²f­®‰ârÇ(šm§ÿߢ»¦²f­®‰ârÇ(›ö·p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷öÿ~‰íþšÞýºËømš [quote][b]
