Question on Aircraft Cowl Openings
andrew.bridget(at)telus.n
PostPosted: Fri Nov 27, 2009 7:57 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
Hello everybody,
Happy Thanksgiving to all those from the US.
I wonder if one of you could help me, please... On the cowl of a piston engine aircraft, on either side of the prop hub there are usually two openings that allow air into the cowl to cool the engine. What are those openings called? Do they have a name?
Thanks in advance!
God bless,
Andrew
dongirod
PostPosted: Fri Nov 27, 2009 8:21 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
That is where my filters for the air intakes are as well as the cooling.
Does the term "hole" come to mind
From: andrew.bridget(at)telus.net (andrew.bridget(at)telus.net)
Sent: Friday, November 27, 2009 10:55 AM
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Subject: Question on Aircraft Cowl Openings
Hello everybody,
Thanks in advance!
God bless,
Andrew
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
Release Date: 11/27/09 02:58:00
rcdettmer(at)charter.net
PostPosted: Fri Nov 27, 2009 8:28 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
There are 3 on my engine nacelles – 1 in the middle for the oil cooler, and 1 on either side of the spinner for the cylinder heads. I call them “air inlet opening thingies”. Happy holidays..!!
Randy Dettmer, AIA, NCARB
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of dongirod
Sent: Friday, November 27, 2009 8:21 AM
Subject: Re: Commander-List: Question on Aircraft Cowl Openings
Hello everybody,
Thanks in advance!
God bless,
Andrew
href="http://www.aeroelectric.com">www.aeroelectric.comhref="http://www.buildersbooks.com">www.buildersbooks.comhref="http://www.homebuilthelp.com">www.homebuilthelp.comhref="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">http://forums.matronics.com
5
6
7
8
9
5
6
 Filesize:  2.9 KB
 Viewed:  6142 Time(s)
PostPosted: Fri Nov 27, 2009 8:32 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
> Does the term "hole" come to mind Smile
I guess I was looking for something a little more precise and/or technical - "D ducts", maybe?
God bless,
Andrew
dongirod
PostPosted: Fri Nov 27, 2009 8:58 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
Andrew, I'm looking, but thought maybe a little humor in the mean time, might work.
So far under "Aircraft Technical" this is what they say "v=induction system The engine receives ram air through an intake in the lower front portion of the engine cowling. An air filter is placed at the intake end of the duct. " which lacks a lot, calling it only an intake. But will keep looking.
Sent: Friday, November 27, 2009 11:29 AM
Subject: Re: Question on Aircraft Cowl Openings
God bless,
Andrew
dongirod
PostPosted: Fri Nov 27, 2009 8:59 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
OH, forgot to mention, on my Commander, the term "Birdhouse" describes it very well in the summer time.
God bless,
Andrew
PostPosted: Fri Nov 27, 2009 9:10 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
Thanks, Don, I knew you were kidding.
What I found was this on a Diamond aircraft service bulletin: (http://www.diamondaircraft.com/library/10/11/Enlarged_cowl.pdf)
"The engine cooling air inlets in the upper cowling may be enlarged to reduce engine temperatures for operators who regularly fly at high outside air temperatures. This change is compatible with the Two Stage Winter Kit (SB DAC1-71-03)."
I guess they are "engine cooling air inlets"...
Thanks!
God bless,
Andrew
BobsV35B(at)aol.com
PostPosted: Fri Nov 27, 2009 9:40 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
How about engine cooling air intake?
My Stearman ain't got none!
Happy Skies,
Old Bob
In a message dated 11/27/2009 10:22:12 A.M. Central Standard Time, dongirod(at)bellsouth.net writes:
Hello everybody,
Thanks in advance!
God bless,
Andrew
ttp://www.aeroelectric.com/">www.aeroelectric.com
m/ href="http://www.buildersbooks.com/">www.buildersbooks.com
"http://www.homebuilthelp.com/">www.homebuilthelp.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
ms.matronics.com/">http://forums.matronics.com
dongirod
PostPosted: Fri Nov 27, 2009 10:33 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
I have been on Google, FAA, and Airman Information Manual, for over an hour and don't find a thing, so sounds good to me.
Don
Sent: Friday, November 27, 2009 12:39 PM
Happy Skies,
Old Bob
In a message dated 11/27/2009 10:22:12 A.M. Central Standard Time, dongirod(at)bellsouth.net (dongirod(at)bellsouth.net) writes:
Hello everybody,
Thanks in advance!
God bless,
Andrew
PostPosted: Fri Nov 27, 2009 11:19 am    Post subject: Question on Aircraft Cowl Openings Reply with quote
Thanks, Don & Bob.
