		woxofswa
				 Posted: Thu Nov 26, 2009 9:18 pm    Post subject: Tools for starting on cabin top |
				Santa's elves have been making inquiries.  I was looking at tools for the cabin top.
 A couple of interesting one's are the bandfile and the dual saw / twin cutter (Sear's version)
 Any suggestions?
 http://www.sears.com/shc/s/p_10153_12605_00989738000P?keyword=portable+belt+sander
  _________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
		Phil.Perry(at)netapp.com Guest
				 Posted: Fri Nov 27, 2009 1:04 am    Post subject: Tools for starting on cabin top |
				I have a Fein Multimaster for making cuts and sanding.  My kit is
 referred to as the "Top" kit.  Most of the time I use the circular blade
 and it will cut anything - except skin.  (Warning: Don't try it with a
 straight blade. Those will cut.)
 http://www.fein.de/fein-multimaster/us/en/products/multimaster_top.html
 I've used it multiple times throughout the project and it's now a very
 valuable tool in the shop.  It's a real time saver.
 I've frozen plexi and then pulled it out and immediately cut it with the
 circular (or semi-circular) blade.  It worked just fine without any
 cracking at all.  It cuts fiberglass too as well as aluminum.  The kerf
 from the blade is pretty much nonexistent compared to other methods.
 Here's some videos.
 http://www.fein.de/fein-multimaster/us/en/media/multimaster_video.php
 Now for some of the best news.  It's nearly a dust free operation.
 Since the tool oscillates, it chips away small pieces of material and it
 falls straight down on the floor.  Some folks will tell you that it
 doesn't generate heat, but it does.  Not nearly as much as traditional
 cutting methods, but anytime you're ripping material apart it's going to
 generate some heat.  By the way, the set I purchased comes with a shop
 vac attachment too.
 The Fein Multimaster held the patent for this tool and it recently
 expired.  This is allowed other companies to come in with knock-off
 brands that are much cheaper.  The Fein isn't a cheap tool, but it is
 the BMW of tool brands.
 The knock off versions were available when I bought my Fein, but I still
 went ahead with the higher end tool.  I decided on the Fein because 1) I
 didn't want to buy a disposable tool.  If I'm going buy a tool for the
 shop, I want to buy the best tool for the job. 2) Performance.  The
 other tools will work, but they don't cut as effectively. 3) Ergonomics
 of the Fein is much better.  4) The Fien's ability to quickly change
 blades with the flip of a lever was a selling point too.
 The Fein tool travels in a 3.2 degree arc 21,000 times per minute.
 Dremel's Multi-Max travels in a smaller arc (1.5 degrees) at 10,000 -
 21,000 oscillations per minute.
 http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=Multi-Max
 Craftsman has come out with a knock-off tool called the Nextec
 Multi-tool.  It travels 2.8 degrees at 15,000.
 http://www.craftsman.com/shc/s/p_10155_12602_00917438000P?vName=Tools+%2
 6+Equipment&cName=Power+Tools&sName=Portable+Power+Tools
 The Bosch PS50 doesn't state it's arc, but has as oscillation of 20,000.
 http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?p
 id=PS50-2B
 You get the idea.  I think Harbor Freight has a knock off that they're
 selling too.
 I've spoken with folks who were happy with their Dremel's, but I don't
 have any regrets for spending the extra money on the Fein.  I'd like to
 get their opinion on the Dremel after they've had a chance to use the
 Fein for a while, just to get an opinion with a more realistic point of
 reference to compare the two from.  I did offer my Fein to a friend
 (Dremel user) but he refused to use it because he was afraid it might
 cost him $400 in the end to happy again.
 But it is one awesome tool for the garage and for the house.
 Phil
		rleffler
				 Posted: Fri Nov 27, 2009 3:33 am    Post subject: Tools for starting on cabin top |
				I bought the Harbor Freight version to trim the cabin cover.  I was a little
 skeptical at first since it only does 10,000 rpm.  For $34.95 I figure it
 was worth the try.
 The good news is that it cut the fiberglass just fine.   I did go through
 some blades.   After three to four feet of cutting the pink fiberglass, the
 blades teeth were worn smooth.  I don't know how long the Fein or other
 vendors' blades last.  But when the HF blade is $5 and the Fein is $40, you
 can afford to buy a few more blades.
 The blade did get rather hot when cutting the fiberglass, so I'm not sure if
 it will be effective on the plexi.  I suspect that may be due to the lower
 RPM.
 It's clearly not as nice as the Fein.  I am curious if anyone has attempted
 to cut the windows with it yet.
 bob
  _________________ Bob Leffler
N410BL - Phase I
				 Posted: Fri Nov 27, 2009 5:44 am    Post subject: Tools for starting on cabin top |
				In retrospect, the most valuable tool for me was a belt sander.  There
 are a lot of straight lines  and big curves to fit (green top, pink
 cowling and doors) and the belt sander has done the best job for me.
 I got two cheap bandfiles from HF via mail order.  The 1/2" one was
 handy for 2 or 3 cuts.  Worth it at less than $50 , but not $100+ worth
 it.  The bigger bandfile was 2X as useful and that's the one I would get
 if I was getting one.
 I did get a Fein knock-off.  Neat tool, glad I have it, but don't use it
 on the plane after some experimentation.  If I were more familiar,
 perhaps. Just no useful experience at this point.
 The handiest tool throughout has been the air powered die grinder with
 the thin disks.  Fast, accurate and wears well.  I'm using them on the
 plexiglass now.
 I had never realized how abrasive fiberglass is on tools.  Once I use a
 drill  bit on it, I move it to the FG bag.  If you use a saw blade on
 it, get more than few.  If you have a good ($$=hard and durable) Unibit,
 keep it off the FG.  But a cheap pack from HF on sale and use those on
 FG and SS.  Or just stick with the HF stuff.  And for countersinking,
 Perma-Grit tungston carbite 100 degree countersinks will save all your
 nice steel ones.  They won't go in the countersink cage but trust me,
 you can eyeball it.  Avery has them.
 I made up a tool that really worked well on the top cuts.  I get a
 couple of blades for a 18volt reciprocating saw with abrasive carbide
 coatings (no teeth).  They are made for straight cuts on pipe and
 stuff.  I ground down the blade's depth so that it could turn corners
 and found it great for trimming the window holes on the old green top.
 Two blades did the whole top.  No toothed blade would do that.
 I went thru 2 HF air powered reciprocating saws from HF.  Tough tool to
 handle well but I did cut out the holes for the HID lights with it.
 That was scary.  They work and <$20 but not worth it in retrospect.
 After really getting comfortable with the air die grinder, someone here
 suggested checking out the new Dremel mandrels for cutting disks.  That
 has become one of my favorite tools.  Now you have a durable abrasive
 wheel for metal or plastic that can be changed out in 10 seconds without
 tools.  WhooWhee!  Neat tool and congrats to Dremel for getting it right
 after so many years.  It's too small for the plexglass but will do the
 job (air die grinder here).  But for almost everything else, it is the
 easiest to handle and most accurate tool to use.
 As I sit here in the middle of my second full fitting of the doors, I
 still consider a torch at times but think that would be counterproductive.
 Bill "who suggests that a good shop vac with a filter bag is the best FG
 tool of all" Watson
		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Fri Nov 27, 2009 6:01 am    Post subject: Re: Tools for starting on cabin top |
				For tools, the Fein really is great. My uncle (a 9A builder) has used it throughout his project. When helping him before OshKosh this year I became more familiar with it. I had already done the canopy and doors on my project so it is a little late for me to invest in the tool. If I hadn't started the top yet it would be on the top of my wish list. Other knock off tools will get you through the project eventually. I too have used a lot of Harbor Freight tools, but the Fein is the best tool for the job.
 A MUST HAVE for the job though, are extra drill bits and tools. If it is used on Fiberglass, it stays on fiberglass. I took the bits I was currently using to the fiberglass and put new ones on the metal tools. Have good files, drill bits, and cutting tools to make the project less of a hassle.
 Eric Kallio
 40518 installing overhead console and awaiting engine
		Strasnuts
  Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
				 Posted: Fri Nov 27, 2009 6:54 am    Post subject: Tools for starting on cabin top |
				I will agree with Bill, The belt sander has been great.  I also liked a
 diamond bit blade on a jigsaw to cut the rough openings.
  _________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
		woxofswa
				 Posted: Fri Nov 27, 2009 10:22 am    Post subject: Re: Tools for starting on cabin top |
				Thanks for the info.  Anyone try the DualSaw or Twin cutter (same thing different brands)?
 My kids saw the infomercial and told my wife they were going to get it for me, but I'll head them off if it doesn't serve any worthwhile purpose.
 BTW, the one thing for the shop that I couldn't live without is the Irobot dirt dog floor sweeper.  I know it sounds stupid, but the thing works like a charm and keeps the floor really clean.  I got mine at Fry's electronics for $89  Easily worth twice that.
 http://store.irobot.com/product/index.jsp?productId=2475131
Mesa, AZ
Flew May 10 2014 |
