Powermate V's B&C LR3C-14
PostPosted: Fri Nov 27, 2009 1:10 pm    Post subject: Powermate V's B&C LR3C-14 Reply with quote
At 03:59 AM 11/27/2009, you wrote:
<chris_sinfield(at)yahoo.com.au>
Hi gang
working on my Elec system for my Jab 3300.
The alt on the Jab outputs around 20Amp ( so they say) and a lot of
people don't like the standard Jab regulator.
I was thinking of replacing the jab regulator with either the Aussie
Powermate or the B&C LR3C-14 regulators.
An LR3C regulator is for WOUND FIELD, automotive alternators.
It is NOT a replacement for RECTIFIER/REGULATORS appropriate
to PERMANENT MAGNET alternators.
<snip>
So which one is best suited and why?
What's the service history on the stock regulator?
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
chris Sinfield
PostPosted: Fri Nov 27, 2009 3:06 pm    Post subject: Re: Powermate V's B&C LR3C-14 Reply with quote
thanks Bob
I knew I did not fully understand it. so the PMR1C-14 would best suit my needs along with a crow bar circuit and low voltage warning system
Here in Australia a lot of people have ditched the std Kabota tractor Regulator supplied with the Jab engine as they only tend to last 6 months .( although some have lasted years). if you have any elec problem's, the first step is to chuck the old reg and buy another one and also carry a spare on fly aways. Or use a Powermate or some other product that meets your needs
Chris
PostPosted: Fri Nov 27, 2009 8:32 pm    Post subject: Powermate V's B&C LR3C-14 Reply with quote
At 05:06 PM 11/27/2009, you wrote:
--> AeroElectric-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
thanks Bob
Consider one of the John Deere tractor regulators
like the AM101406. These are heavy duty critters with
hefty heat sinks.
http://tinyurl.com/yarwkv3
( community. )
mrspudandcompany(at)veriz
PostPosted: Mon Nov 30, 2009 10:02 am    Post subject: Powermate V's B&C LR3C-14 Reply with quote
hefty heat sinks.
[quote]   Bob . . . Would you recommend this JD regulator over the generic Ford regulator? Are they pin compatable? Roger
PostPosted: Mon Nov 30, 2009 5:36 pm    Post subject: Powermate V's B&C LR3C-14 Reply with quote
hefty heat sinks.
Bob . .
Would you
The "Generic Ford Regulator" is for wound field
alternators. The JD RECTIFIER/REGULATOR is for
permanent magnet alternators.
( community. )
