		harvey4(at)earthlink.net Guest
				 Posted: Mon Nov 30, 2009 10:21 am    Post subject: Tracking a high resistance joint |
				My alternator is putting out 14+ volts but I'm only seeing low 13's
 at the panel bus, suggesting a high resistance joint somewhere on the
 way to the panel.
 Any ideas on how to diagnose the bad joint would be appreciated. My
 limited knowledge of Ohm's law says that the resistance drop across
 the bad joint will be too tiny to detect with a standard meter and I
 probably won't find it that way.
 Thanks for ideas.
 Neil C
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Nov 30, 2009 4:41 pm    Post subject: Tracking a high resistance joint |
				At 12:15 PM 11/30/2009, you wrote:
 the way to the panel.
     You're right, attempting to measure very small
     resistances with the commercial off the shelf
     multimeter is not in the cards.
     However, the same instrument can measure VOLTAGES
     and in particular, DIFFERENCE voltages. Hook your
     (+) meter lead to the alternator b-terminal. Fire
     up the engine. Turn lots of stuff ON and then probe
     the pathway between b-terminal and the bus with the
     (-) lead of your voltmeter.
     If it's not practical to do this with the engine
     running, then temporarily hook a charged AGM battery
     from  b-terminal to ground. Perhaps you can fabricate
     a jumper to run from your hot side of the battery
     contactor over to the b-lead.  Do this with a piece
     of 10AWG or larger and include a series fuse of 30A
     at the battery end. . . . make the battery pretend to be
     an alternator.  Leave the battery master OFF, turn
     on lots of stuff and then probe the path from alternator
     b-lead to the bus.
     In big airplanes, we do this with a constant current
     power supply set up to deliver 30 or so amps over the
     power path to be explored. I do have a whippy micro-
     ohmmeter but prefer the constant current technique
     and voltmeter.
     When you have access to the power supply, the rest
     of the airplane can be OFF while the survey is being
     conducted.
         ( It's MATRONICS FUND RAISER MONTH!    )
         ( Do your part to keep this marvelous  )
         ( tool sharp and available to all our  )
         ( brothers in the OBAM aviation        )
         ( community.                           )
