		dugnaylor(at)hotmail.com Guest
				 Posted: Tue Jan 10, 2006 5:04 am    Post subject: scenery flying/ greenhouse effect |
 Hi Guys,
 Two quick questions:
 #1 Really, how good is the Zodiac XL at relatively low and slow,
 looking-at-the-ground-scenery type flying? i.e.-- is it pretty stable
 flying at slow speeds (with some flaps), and how much can you really see
 over the wings tightly strapped into those steeply reclined Lazy Boy-type
 seats? I've had one short ride in the company's XL but it's hard to
 remember the small details. --I'm trying to compare the Zodiac to a high
 wing, semi-STOL design (Wittman Buttercup). I'm not interested in the 701
 because of it's slow cruising speed.
 #2 How hot can it get under that big bubble canopy in the summertime? Can
 the little fresh air vents keep up with the sun rays?
 Much Thanks,
 Doug N.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		japhillipsga(at)aol.com Guest
				 Posted: Tue Jan 10, 2006 8:49 am    Post subject: scenery flying/ greenhouse effect |
 Doug, like any low wing vs high wing the ground view suffers. The trade off is safety in flight with the great view to the sides and above, etc. Whenever I want to see something below I just point one wing up and one down and look out the side and top. As to the Green House effect it is a real issue in summer and the venting on the ground is marginal, but this summer in Mid Georgia after take off and air could circulate it was not much of an issue. You do always have to wear a hat for sun though and my wife hates hats. Big hair woman. I would advise the larger air vent eyeballs. I plan to increase mine for more flow in the near future. Best regards, Bill N505WP 601XL-3300w/DC
		David X
  Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
				 Posted: Tue Jan 10, 2006 8:57 am    Post subject: Re: scenery flying/ greenhouse effect |
 Once in the air, the cabin cooling is not bad. On the taxiway, it can get really hot in the summer - same as a piper. There are little circular rotating scoops that you can install in the canopy to catch the prop wash when on the taxi.
  _________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
		David X
				 Posted: Tue Jan 10, 2006 8:58 am    Post subject: scenery flying/ greenhouse effect |
 http://forums.matronics.com/viewtopic.php?p=2502#2502
DO NOT ARCHIVE |
		mfothergill(at)sympatico. Guest
				 Posted: Tue Jan 10, 2006 9:22 am    Post subject: scenery flying/ greenhouse effect |
 Hi;
 Install a 12 volt computer fan in the bulkhead at the back of the
 baggage shelf to exhaust some of the hot air. Also helps to defog the
 bubble in cold weather.
 CH-601HDS
 UHS Spinners
		dredmoody(at)cox.net Guest
				 Posted: Tue Jan 10, 2006 1:22 pm    Post subject: scenery flying/ greenhouse effect |
 Most folks keep the canopy slightly open until just before takeoff in warm weather to get a little more air in the cockpit.
 There is a gizmo I've seen in a friends RV7-A which is a retractable sunshade that works on a track mounted along the center line of the canopy with pressure sensitive adhesive. We slide it all the way back for full visibility and extend it forward as much as needed at cruise altitude. I'm going to that in my 601XL because Louisiana is way too close to the sun.
 Ed
  	  | Quote: | 	 		   Subject: Re: scenery flying/ greenhouse effect
		Larry McFarland
  Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
				 Posted: Tue Jan 10, 2006 1:32 pm    Post subject: Re: scenery flying/ greenhouse effect |
 Doug,
 I'd stay with the low wing as visibility is excellent in the 601s. Last year I flew off the 40 hours and there were just a few days that reached mid 90s. So long as I wore a ball cap and sunglasses, things were mostly comfortable.
 On a couple of days, I found myself overheated because of the intense humidity and I'd not been drinking enough water. The canopy does allow a lot of heat to be radiated in, so wear the hat and do spend some time putting vents in or below the panel that you can focus air toward your face. Try to fly a bit higher when it becomes unbearably warm to take in cooler air. It will really make a difference.
 These links show my $2. vents and they work great.
 http://www.macsmachine.com/images/largeassembly2/full/outletvent.gif
 http://www.macsmachine.com/images/largeassembly2/full/freshairassy.gif
 http://www.macsmachine.com/images/largeassembly2/full/NACAvent.gif
 good luck,
 Larry
  _________________ Larry McFarland - 601HDS - Stratus |
		Larry McFarland
				 Posted: Tue Jan 10, 2006 1:35 pm    Post subject: scenery flying/ greenhouse effect |
 Doug,
 good luck,
 Larry
 http://forums.matronics.com/viewtopic.php?p=2622#2622
		jim(at)pellien.com Guest
				 Posted: Tue Jan 10, 2006 2:06 pm    Post subject: scenery flying/ greenhouse effect |
 Do you have a web URL where I could go and see what this gizmo looks like?
 Jim
 Jim Pellien
 Mid-Atlantic Sports Planes
 www.MASPL.com
 703-313-4818
 jim(at)sportsplanes.com
		moorecomp(at)yahoo.com Guest
				 Posted: Tue Jan 10, 2006 2:45 pm    Post subject: scenery flying/ greenhouse effect |
 Jim,
 http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1136932743-0-756&browse=airframe&product=koger-shade
 Craig Moore
 A&P
 701 Builder wannabe
 --- jim <jim(at)pellien.com> wrote:
				 Posted: Tue Jan 10, 2006 3:30 pm    Post subject: scenery flying/ greenhouse effect |
 Yep, that's the device. Thanks for the info.
 Ed
 Date: 2006/01/10 Tue PM 05:43:19 EST
 Subject: Re: Re: scenery flying/ greenhouse effect
		daberti(at)sbcglobal.net Guest
				 Posted: Tue Jan 10, 2006 5:14 pm    Post subject: scenery flying/ greenhouse effect |
 As an aside to this issue Plexiglas does not block any of the UV rays as
 glass will. Last spring I found myself quite red after a four hour jaunt
 through clear blue sky's. Now I pack sunscreen, especially in early spring.
 I also installed a Koger sunshade on the canopy this last fall.
 Dave 601-HD 912ULS
 ....... Last year I flew off the 40 hours and there were just a few days
		rdewees(at)mindspring.com Guest
				 Posted: Tue Jan 10, 2006 7:19 pm    Post subject: scenery flying/ greenhouse effect |
 I had the same problem flying last summer in my HDS and am "follicle
 challenged" north of my ears so I was very sensitive to cutting down the
 heat/UV/ and glare. I went to the local Pep Boy's parts store and paid
 about $5 for a pair of sun screens that are attached with suction cups
 on the corners. They are a black mesh of some sort and the frame is
 wire. You just wad them up and they will fit in a small space as long
 as you can confine them. You can look thru them easily and I would
 estimate that the glare is cut by 30% or more. you can remove or
 reposition them easily and throw them away after the hot season passes
 if they are too dirty. I guess the dimensions are something like 8X14
 inches and two of them cover a lot of the overhead canopy. Worked for me!
 Ron
 David Alberti wrote:
 Dave 601-HD 912ULS
 ........ Last year I flew off the 40 hours and there were just a few days
		jhstarn(at)verizon.net Guest
				 Posted: Tue Jan 10, 2006 9:03 pm    Post subject: scenery flying/ greenhouse effect |
 Me too...but because I run the Young Eagles for my EAA Chapter and we also
 encourage parents to fly with us, we refer to ourselves are the Apple Valley
 Air Corps Bald Eagles. 8*). Hey it always breaks the ice & gets a laugh or
 two. KABONG Do Not Archive. HRII N561FS approaching 300 hrs.
 am "follicle challenged"  |
