Z19RB Engine Battery Buss Question
ZuluZephyr
PostPosted: Fri Dec 04, 2009 12:10 am    Post subject: Z19RB Engine Battery Buss Question Reply with quote
I am building a Sportsman with 2 batteries in the back behind a bulkhead (about a 10 to 12 foot run to the firewall).
Z19 call for the always hot Engine Battery Buss (fuse block) to be within 6 inches of the battery. This would mean bringing about 10 hot wires forward to the panel from the buss.
What would be the downside of mounting the Engine Battery Buss (and Main Battery Buss) near the panel and resizing the 2 hot wires from the battery to the buss and adding an ANL fuse to protect the wire other than the addition of the fuse? This would reduce the wire count for this run length.
Rocky
PostPosted: Fri Dec 04, 2009 5:39 am    Post subject: Z19RB Engine Battery Buss Question Reply with quote
That's a lot of items for a hot battery bus.
What systems make up the 10 loads and what
are their current requirements?
It's a crash-safety thing. We'd like for wires
that are always hot to be breakered at 5A or
less, fused at 7A or less. A battery buss feeder
to a remotely mounted battery would not fit
the design goals for contemporary TC aircraft.
ZuluZephyr
PostPosted: Fri Dec 04, 2009 10:12 am    Post subject: Re: Z19RB Engine Battery Buss Question Reply with quote
The Engine and Main buss are basically duplicates with the following:
1. EFI 4a
2. ECU 1a
3. Pri Fuel Pump 7.5a
4. Sec Fuel Pump 7.5a (only one running except take off and landing)
5. Electric Constant Speed Prop 4.5a (9a peak)
Rocky
PostPosted: Sat Dec 05, 2009 7:12 pm    Post subject: Z19RB Engine Battery Buss Question Reply with quote
1. EFI 4a
2. ECU 1a
Hmmm . . . Sounds like you're splitting engine electrical
source duties between on battery bus and the main bus. I
presume you're combining the dual path sources with
a diode-pair.
The battery bus really needs to be close to the battery
if you subscribe to the notion of minimizing the length
and fusing of always hot-wires. If you want to extend
a bus feeder to some more forward location, conventional
wisdom calls for a "mini-contactor" or power relay like
that suggested in Z-32 for a "heavy-duty e-bus".
I think I'd leave the relay out and run the long wires
to small fuses.
ZuluZephyr
PostPosted: Mon Dec 07, 2009 7:22 pm    Post subject: Re: Z19RB Engine Battery Buss Question Reply with quote
Hi Bob,
You are correct, I am planning on using diodes. I have not looked at Z32 but I believe long wires and small fuses make sense.
Rocky
