messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Tue Nov 24, 2009 8:54 am Post subject: Re: Dan's Switches |
Thanks, Bob.
I'd be happy to send the unit to you. Pretty sure it's got the right die set. I'll lookup your address on your website.
_________________ Dan |
Posted: Tue Nov 24, 2009 10:06 am Post subject: Dan's Switches |
At 10:54 AM 11/24/2009, you wrote:
Thanks, Bob.
If it's mashing insulators such that they
expose the insulation grip sleeves, then it
seems likely that it's not the right die-set
for the terminals you have.
| Quote: | I'll lookup your address on your website.
Good. Send some terminals too. Let's see what
ingredients are not meeting design goals
in your recipe for success.
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
messydeer
Posted: Tue Nov 24, 2009 12:51 pm Post subject: Re: Dan's Switches |
USPS scheduled to pickup tomorrow. Should be there in 3-4 days. Could have made it sooner, but didn't want to drop your name to them. It fit in a small priority mail box, but reminded me of sitting in an Allegiant Airline seat.
I didn't see your post about the terminals, so they aren't included. Seems like it was the yellow ones that I started with, and know that one insulation gripper ring poked through. They were AMP PIDG bought from B&C. Others failed the pull test when cycled through. I had done some red terminals, too, that I'd tried. To start, I didn't know which end the terminal should go, so I called Ideal tech support and verified it. I'm curious to see what you find.
mprather(at)spro.net Guest
Posted: Tue Nov 24, 2009 1:45 pm Post subject: Dan's Switches |
I use a cigarette lighter... Carefully. Just kidding... Mostly.
Matt-
<nuckolls.bob(at)aeroelectric.com>
At 03:41 PM 11/21/2009, you wrote:
><jmtipton(at)btopenworld.com>
>Hi Guys
>What's the chosen method of shrinking, 'heat-shrink' ?
Heat . . .
Seriously, it depends on your situation. I've had $150 heat
guns than put concentrated heat into tiny spaces. They're
quite useful when working inside some piece of electronics.
95% of the time, a $15 heat gun from Harbor Freight does the
job. ANY heatgun can supply MORE heat than you need. Get
used to the specific combination of shrink, situation and
tools before you dive into finished work.
( community. )
BobsV35B(at)aol.com Guest
Posted: Tue Nov 24, 2009 2:08 pm Post subject: Dan's Switches |
Good Afternoon Matt,
The best, fastest, and most carefully detailing wiring artist I know will use nothing but a Bic to shrink the tubing!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Brookeridge Airpark
Downers Grove, IL
Stearman N3977A
In a message dated 11/24/2009 3:47:06 P.M. Central Standard Time, mprather(at)spro.net writes:
| Quote: | --> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net>
Matt-
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
>--> AeroElectric-List message posted by: "JOHN TIPTON"
>Hi Guys
Heat . . .
( community. )
<================================================nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== = Use utilities Day ================================================ - MATRONICS WEB FORUMS ==================================================
messydeer
Posted: Tue Nov 24, 2009 2:52 pm Post subject: Re: Dan's Switches |
I use a butane lighter. I thought that's what most people used. Just grabbed the long nosed one for the barbeque. Looks like it's refillable. Actually might use the refill feature, since I have a can of butane that I won't use for my soldering iron. I had bought a Bernzomatic micro torch with a soldering iron tip. The flame pulses about every 3 seconds, which makes it useless for the flame part of it. The iron part evens the pulses out, but I've got a 30W that I use for that.
Posted: Sun Dec 06, 2009 5:14 pm Post subject: Dan's Switches |
At 04:21 PM 11/21/2009, you wrote:
> ???? how was the plastic on the PIDG terminal being
> compromised???
The metal insulation closure when pinched down poked through the
outer preinsulation. I thought I was getting a decent device when I
bought the Crimpmaster. I found that terminals don't fit well in it,
both in the direction of the wire and in the direction of the
handle. I tried a few different adjustments and gave up. I have done
almost all of my crimping with a GB cheapo I have and pull tested
enough to know when it's good.
Are you sure you have the right die-set
for the Crimpmaster? As I recall, there's
a suite of interchangeable dies offered
for that tool. I'd be interested in seeing
what you have. I'll pay the postage back
if you pay the postage to me. Send me some
of the terminals you're using too.
I received your tool and tested it with
AMP PIDG terminals and found the finished
results to be satisfactory. You didn't
send me any of the terminals you're using
but I suspect they are not AMP parts. There
are perhaps dozens of pre-insulated terminals
that are 'qualified' to widely accepted
specifications no the least of which is . . .
http://www.aeroelectric.com/Reference_Docs/Mil-Specs/Mil-T-7928slash4.pdf
Can you tell us what the brand and part numbers
are for terminals you're using?
Some years ago a local supplier offered me some
'qualified' terminals that worked pretty good with
$high$ PIDG tooling but looked like (at)#$(at) when
installed with our $low$ favorite tool:
http://aeroelectric.com/Pictures/Terminals/JST_Samples_2.jpg
messydeer
Posted: Sun Dec 06, 2009 7:03 pm Post subject: Re: Dan's Switches |
Thanks Bob.
They were AMP, PIDG. Red and yellow fastons from B&C.
