503 oil injection retrofit
Tom Jones
PostPosted: Mon Dec 07, 2009 6:11 am    Post subject: 503 oil injection retrofit Reply with quote
I want to install an oil injection system on a 503 DCDI. It has an electric starter on mag end. There is a hole in the center of the cover plate above the starter that appears to be for the oil pump drive shaft.
This engine I purchased new in 1994 and it has never had an oil injection installed on it. There are no holes for the injection in the intake manifolds.
I am wondering how big a job it is and what parts I need and where to find them.
Tom Jones
Classic IV
Ellensburg, WA
Blumax008(at)aol.com
PostPosted: Mon Dec 07, 2009 6:48 am    Post subject: 503 oil injection retrofit Reply with quote
In a message dated 12/7/2009 9:12:57 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
Take it from an old hand (very old hand) at ultralights & 2-sicle motors...DO NOT install an oil drive system. Keep mixing your fuel & oil. It's much more reliable & a hell of a lot less trouble. You're just asking for trouble.
Bill Catalina
Class of '78
aoldman(at)xtra.co.nz
PostPosted: Mon Dec 07, 2009 9:33 pm    Post subject: 503 oil injection retrofit Reply with quote
Totaly agree. Keep it simple . Mixe your own fuel.
Downunder
MK111c
503
Tom Jones
PostPosted: Tue Dec 08, 2009 5:45 am    Post subject: Re: 503 oil injection retrofit Reply with quote
I agree. Premixing is simple and bullet proof. My Kitfox is bare bones and I like to keep it that way as much as I can.
My main reason for wanting to convert to the oil injection is to reduce carbon build up. I have to taxi over a mile each way to take off and again after landing. Also there is a University flight school at my local airport so there are almost always five or six or more planes doing touch and goes or stop and goes so I sit there for ever waiting for an opening to take off.
At 50 hours there was plenty of carbon in the piston ring grooves.
People flying 503s with oil injection tell me they go 150 hours or more and the pistons are still clean as a whistle. I think my carbon build up is due to all that low rpm taxiing and idling at 50:1 oil ratio. It about broke my bank account just to buy the gaskets to do the de-carbon work. Rotax has become pretty proud of their parts.
Tom Jones
Classic IV
Ellensburg, WA
PostPosted: Tue Dec 08, 2009 6:42 am    Post subject: 503 oil injection retrofit Reply with quote
In a message dated 12/8/2009 8:47:34 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
Well, good luck on installing that oil injection.
lucien
PostPosted: Tue Dec 08, 2009 7:05 am    Post subject: Re: 503 oil injection retrofit Reply with quote
The main thing you have to check for if you want to fit the oil injection is if your crankshaft has the square driver hole in the end of the shaft. Check that first before you buy anything. The oil pump drive shaft fits into this hole and it's required to use the pump.
A rotax dealer might be able to tell you at what serial no. this was introduced, but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank.
If it doesn't have that, you're SOL (unless you buy an updated crankshaft).
I always ran 50:1 premix as well, mostly just because I liked the simplicity and I'm always really anal about gas that I put into my planes (so didn't ever forget to mix the oil in). But everyone I've talked to who runs the oil injection has reported zero problems. The leaning of the oil at idle is another benifit.....
LS
LS
Titan II SS
Tom Jones
PostPosted: Tue Dec 08, 2009 8:06 am    Post subject: Re: 503 oil injection retrofit Reply with quote
Thanks for the heads up. According to the serial number my engine has the injection drive shaft provision in the end of the crank.
I have an injection pump located and will check the local Ski Doo shop for a price on a reservoir system. The Aircraft engine rotax shops want 2 hunskies for the tank, filter and line.
The last thing I need to figure out now is the injection ports in the intake manifolds. Is that a special nozzle or is it just a an open barbed tube that I could drill a hole in the manifold and install?
Tom Jones
Classic IV
Ellensburg, WA
lucien
PostPosted: Tue Dec 08, 2009 8:28 am    Post subject: Re: 503 oil injection retrofit Reply with quote
Yeah this was a change that came along with the oil injection. The newer intake manifolds already have the fittings in them, the older ones don't have them.
I don't see why if you're good with drilling and tapping that you couldn't drill and tap the holes yourself. I'd be sure and use the rotax fittings tho, since you can be sure they have just the right orifice size for metering the right amount of oil, etc. And I'd make sure to place the holes where they are on the new manifolds.
Otherwise you have to get new manifolds, surely super pricey from Rotax.
But I've never modded the older manifolds so I don't know of any gotchas. I'd talk it over with a rotax mechanic like Thom or any of the other folks on here. Or ask the dealer (maybe you can trade in your old manifolds?)
LS
LS
Titan II SS
thesupe(at)hotmail.com
PostPosted: Tue Dec 08, 2009 9:53 am    Post subject: 503 oil injection retrofit Reply with quote
Tom C  my old CPS catalog shows a coolant recovery bottle which they say can also be used as a oil injection reservoir.  Part # 1609  price was $14.95  (in 2002)  Maybe they still sell it.  Jim Chuk
Subject: Re: 503 oil injection retrofit
Date: Tue C 8 Dec 2009 08:06:36 -0800
To: rotaxengines-list(at)matronics.com
--> RotaxEngines-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> A rotax dealer might be able to tell you at what serial no. this was introduced C but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank.
I have an injection pump located and will check the local Ski Doo shop for a price on a reservoir system. The Aircraft engine rotax shops want 2 hunskies for the tank C filter and line.
The last thing I need to figure out now is the injection ports in the intake manifolds. Is that a special nozzle or is it just a an open barbed tube that I could drill a hole in the manifold and install.
Tom Jones
Classic IV
503 Rotax C 72 inch Two blade Warp
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=276695#276695
Windows LiveT Hotmail is faster and more secure than ever. Learn more.
 Filesize:  79.87 KB
 Viewed:  12304 Time(s)
capedavis(at)yahoo.com
PostPosted: Tue Dec 08, 2009 1:57 pm    Post subject: 503 oil injection retrofit Reply with quote
Tom, I flew a 503 490hrs on premix using pensoil for air cooled engines had it rebuilt before I sold it . The rebuilder said almost no carbon !
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Tue, December 8, 2009 8:45:44 AM
--> RotaxEngines-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
My main reason for wanting to convert to the oil injection is to reduce carbon build up. I have to taxi over a mile each way to take off and land. At 50 hours there was plenty of carbon in the piston ring grooves and it about broke my bank account just to buy the gaskets to do the de-carbon work. Rotax has become pretty proud of their parts.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=276680#276680
www.homebuip; &n================
dave
PostPosted: Tue Dec 08, 2009 4:25 pm    Post subject: Re: 503 oil injection retrofit Reply with quote
Tom,
Call Bob Robertson 1-866-418-4164
he sells a ton of the oil injection change over kits.
You will not beat him in service and parts.
He makes everything you need in one package.
Oil Injection is far superior to pre mix. And although you have a few more parts they have a 99.99999% reliability.
Your plugs will last 100 hours easy now .
It works, it really does.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
PostPosted: Wed Dec 09, 2009 10:10 am    Post subject: 503 oil injection retrofit Reply with quote
In a message dated 12/8/2009 4:58:18 P.M. Eastern Standard Time, capedavis(at)yahoo.com writes:
Well said Chris but I think the "other side" is well entrenched in their thinking too. We'd have as hard a time changing their minds as they would have changing ours. So if they're happy, so be it.
That being said...I've been flying 2 cycle ultralights since 1978, have multiple thousands of hours in them & my favorite principle is K.I.S.S...and I think we all know what that means. My next best saying is..If it ain't broke, don't fix it.
The less crap you have hanging on a motor, the less crap you have to deal with...especially at tear down & inspection. Some people have so much unnecessary crap on their planes it would take hours if not days getting it all off just to get to a problem.
Now think of an ultralight pilot broke down in the bush...100 degrees, 95% humidity, mosquitos, no-see-ums, sweat pouring into your eyes...and a motor loaded with crap that you have to remove (and replace) to get to your problem...or...that may be the cause of your problem.
My best running trike is a DFS with a simple 503, pull start & manual choke with an E.I.S.
Get my drift?
Tom Jones
PostPosted: Wed Dec 09, 2009 1:34 pm    Post subject: Re: 503 oil injection retrofit Reply with quote
Anyone premixing with an engine that came with oil injection want to trade me their manifolds for a pair without the injection ports? I'll pay shipping plus $20.
Tom Jones
Classic IV
Ellensburg, WA
