		dave
				 Posted: Tue Dec 08, 2009 4:33 pm    Post subject: Re: EGTs are killing me |
				Oils.
 Water cooled 2 stroke oil is classified as  TCW3  which is an outboard rating.  Outboards run with a constant supply of water ( coolant  from 32 F to about 90 F )  Out Rotax operating temps for coolant are 140 to 180f approx.
 aircooled oil works  but I will say so does Skidoo oil or any oil that bears the  API-TC classification.
 http://www.cfisher.com/oildebate.html
 Good reading here as well
 http://rotaxaircraft.com/forum/viewtopic.php?f=4&t=46
 Simple engines  but some have to make them so tough.
 Dave
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Ken Potter
  Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
				 Posted: Wed Dec 09, 2009 3:52 am    Post subject: Re: EGTs are killing me |
				Interesting discussion.  I'll be breaking in my 582 and test flying in the spring.  I was planning on using Shell 2 stroke snowmobile oil which is approved by Bombardier.  It's available here in Canada at any Canadian Tire store.  Any comments??
 Cheers
 Ken
  _________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
		dave
				 Posted: Wed Dec 09, 2009 5:48 am    Post subject: Re: EGTs are killing me |
				Guys here use that Shell oil  that is API TC rated to pre mix engines.
 Rest use  Bombardier  XPS mineral oil
 I have also used Castrol Super 2 stroke available at Walmart  for about  4.50 a litre.
 I think any of the 3 above will  work. Castrol makes  Bombardier oil.
		Float Flyr
				 Posted: Wed Dec 09, 2009 2:41 pm    Post subject: EGTs are killing me |
				Bombardier recommends not using outboard motor oil.  Apparently the air cooled oil can withstand the higher temps that the aviation engines endure.
 Noel
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Cecil Stokesberry
  Sent: Tuesday, December 08, 2009 1:05 AM
  Subject: Re: EGTs are killing me
 Mark,
 You say you are using 2-stroke oil for air cooled engines.
 The 582 is water cooled - in your experience does it make any difference to
 use the water cooled 2-stroke oil or the air cooled 2-stroke oil for the 582 engine ?
  Cecil in North Idaho
 Kitfox IV 1050 582 C box GSC prop
 On Mon, Dec 7, 2009 at 7:55 AM, Mark Napier (napierm) <napierm(at)cisco.com (napierm(at)cisco.com)> wrote:
 --> Kitfox-List message posted by: "Mark Napier (napierm)" <napierm(at)cisco.com (napierm(at)cisco.com)>
  Hey James,
  I ran 200 hours on a 582 with the HACMan.  It works pretty well.  Be
  advised that one way to lower your EGT's is by increasing the pitch of
  the prop.  Mine turned about 5800 static.  Only problem I had with it
  was the supplied barbs didn't hold the lines very well so I replaced
  them with something a little better.  Same with the plastic clamps.
  Just use 2 turns of safety wire instead.  To get a little more
  adjustment range out of the HACMan I put in a "vacuum restrictor"
  orifice (drilled out with a #40 drill bit) in the air sense line coming
  from the air cleaner.  If you do that then go up one size on your main
  jets.
  Also, the #55 idle jets that come with the carbs are too big.  Replace
  them with #45 and the engine will idle much better.  Before I changed
  mine out the motor would often quit on final approach and tended to foul
  up on the ground.  The iridium plugs help some too.
  About avgas:  I stuck my rings and had the engine sag on me during a
  take-off run.  It just plain quit taxing back.  Fortunately I aborted
  but 10 seconds later would have been over the trees with few options.
  The inside of my engine looked like it was power coated white.  Piston
  tops, heads, exhaust system, all of them looked like they had just come
  out of the paint shop and the cylinders were scratched.  When I called
  South Mississippi to describe the problem, he said "Let me guess, the
  inside of your motor looks like it was painted white."  This was at ~180
  hours with mostly running car gas but getting avgas at stops cross
  country flights.  The oil was Pennsoil 2-stroke for air cooled engines.
  Maybe the lead scavengers or other oils would do better, I can't say.
  Now I can't buy car gas w/o alcohol but all things considered I would
  rather replace my tanks than feed the engine on a steady diet of lead.
  Charging system:  The engine is only good for about 10 amps.  For
  instance, I could run the radio, strobes, intercom and still put a
  couple of amps into the battery.  However nav lights put me into the
  red.  Fortunately I almost never needed the nav lights!  I used the
  odyssey 625 battery with good results.
  FWIW,
  Mark Napier
  Time: 06:00:34 PM PST US
  Subject: EGTs are killing me
  From: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
  Somebody with a good working knowledge of the inside of a Bing 54 PLEASE
  HELP ME.
  Lets start at the beginning, as temps started to drop below about 55-60f
  I
  started having EGT trouble and I started reading up and doing some
  adjustments.
  The needle jet, jet needle, and up until yesterday the main jet were
  stock.
  I installed the HACman which comes with 180 main jets and I purchased
  but did
  not install the next size up of needle jets, 2.74 I think.  I read that
  going
  up a needle jet size could cool off the mid RPMs but I wanted to work
  with
  the HACman before I made any more adjustments.
  So today I had the HACman full rich for all but a couple minutes of the
  flight
  when I leaned it just to make sure it worked properly.  Temp was 32f and
  PA was
  500'.  Climbing at 62-6500 yielded 1125-1150 and cruise at 5800 was 1175
  as
  long as the prop was loaded, any decent and it headed for 1200.  I went
  to adjust
  the needle and found that it was actually on the bottom ring, tho one
  that
  I am pretty sure is not supposed to be used for a setting so I actually
  took
  it back up to the third ring from the top just to see if it was a case
  of too
  far in the right direction is no better and nothing improved.
  According to the
  chart I have seen I should be running the 165 main jet with stock
  needles at
  all temperatures at this altitude but it is obviously not working.
  Should I install the 2.74 needle jets?  Might this fix the hi temps?  I
  have a
  new prop on the way that is bigger and that should help a little but not
  when
  it is unloaded.  What adjustments do needles make, is there a better
  needle for
  my situation?  Where I am the temps often swing 25-30 degrees through
  the day
  and I cannot chase these EGTs.
  James
  Kitfox 3 / 582 / GSC prop
  The ink is still drying on my new certificate
 http://forums.matronics.com/viewtopic.php?p=276401#276401
   * AeroElectric www.aeroelectric.com
  omebuiltHELP www.homebuilthelp.com
  http:/r generous support!
  ronics List Features Navigator to browse
  s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
  ronics.com/" target="_blank">http://forums.matronics.com
     	  | Quote: | 	 		  |   www.aeroelectric.com  | 	  0123456789012345678
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Float Flyr
				 Posted: Wed Dec 09, 2009 8:49 pm    Post subject: EGTs are killing me |
				The Decalin scavenger requires one thing to work… heat.  Ie the heat given off in combustion. That is why it works very well at keeping the top end and plugs very clean however it does nothing to keep the lower end and main bearings free of plating.  Their own web site, the last time I was there, only mentioned the top end for that exact reason.
 Noel
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
  Sent: Tuesday, December 08, 2009 12:26 PM
  Subject: RE: Re: EGTs are killing me
 At 03:01 PM 12/6/2009, you wrote:
 What would worry me most is the possibility that lead is plating on your
  main roller bearings.  If you get a serious build up of lead there it could
  cause a seizure...  in flight!  Additives the scavenge lead only work when
  the fuel is burned so they will not protect your lower end.  They should
  however help keep your plugs from fouling.
  I don't know if I'd worry too much about it. I've run nothing but 100LL through my 582 for 400 hours using Decalin scavenger and don't seem to be suffering for it.
 Guy Buchanan
  San Diego, CA
  K-IV 1200 / 582-C / Warp / 400 hrs. and counting    	  | Quote: | 	 		  |   www.aeroelectric.com  | 	  0123456789012345678
Kitfox III-A
