Tom Jones
Posted: Wed Dec 16, 2009 4:12 pm Post subject: Oil Injection reservoir size? |
What size oil injection reservoir are you two stroke people running? I am still gathering to convert my premix engine.
The rotax installation manual says the oil reservoir should be a minimum of 5% of the fuel capacity. I have 21 gallon fuel capacity so that works out to a little over a gallon oil reservoir. That seems like a lot of extra weight if I filled it up.
The tank I am looking at is 2.5 liters which would be enough oil for about 35 gallons of fuel.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Paul A. Franz, P.E.
Posted: Wed Dec 16, 2009 6:06 pm Post subject: Oil Injection reservoir size? |
On Wed, December 16, 2009 4:12 pm, Tom Jones wrote:
I assume you mean you're converting from using pre-mix to oil injection.
| Quote: | The rotax installation manual says the oil reservoir should be a minimum of 5% of the
fuel capacity.
That seems a little high to me when the engine runs 50:1 (2% oil) and close to 100:1
at low power settings. Maybe they mean 2% of the fuel capacity plus an additional 5%.
So 2% of 21 gallons is 0.42 gallons plus 5% of the 0.42 gallons which is another 0.021
gallons. The total oil then would be 0.42 + 0.021 = 0.441 gallons of oil. A little
under half a gallon. It doesn't seem reasonable to me to size the oil tank for a 20:1
mix. But then again, I haven't been flying behind one either.
| Quote: | I have 21 gallon fuel capacity so that works out to a little over a
of fuel.
That's well over the minimum required for 21 gallons of fuel assuming it runs 50:1
most of the time. The oil weighs approx 6.8 lbs/gal so half gallon isn't an extreme
weight burden. You'd be carrying that weight anyway if you premixed. It might be nice
to size the oil tank for a typical round trip so you don't have to carry as much in
bottles loose in the cockpit. Maybe size the oil tank for some amount of flight time,
like 6 or 8 hours.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
"He who does not bellow out the truth when he knows the truth makes
himself the accomplice of liars and forgers."
-- French poet, essayist and editor Charles Peguy (1873-1914)
Subject: As the World Turns
So what have we learned in two millennia?
"The budget should be balanced, the Treasury should be refilled,
public debt should be reduced, the arrogance of officialdom should be
tempered and controlled, and the assistance to foreign lands should be
curtailed lest Rome become bankrupt. People must again learn to work,
instead of living on public assistance. --- Cicero, 55 BC
Evidently, nothing....
"An unlimited power to tax involves, necessarily, a power to
destroy; because there is a limit beyond which no institution and
no property can bear taxation."
-- John Marshall, McCullough v. Maryland, 1819
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
About the Federalist Papers - wiki
<http://en.wikipedia.org/wiki/Federalist_Papers>
All of them presented in the Library of Congress
<http://thomas.loc.gov/home/histdox/fedpapers.html>
Searchable e-text of the Federalist and other documents too.
<http://www.foundingfathers.info/federalistpapers/>
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
akflyer
Posted: Thu Dec 17, 2009 7:11 am Post subject: Re: Oil Injection reservoir size? |
I got the KF oil tank from John Mcb at kitfox. It is a pain to take off my boot cowl every time I fill up so I like having the extra oil capacity. A few extra pounds are worth the hassle to me.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Tom Jones
Posted: Thu Dec 17, 2009 7:54 am Post subject: Re: Oil Injection reservoir size? |
| akflyer wrote: | | I got the KF oil tank from John Mcb at kitfox. It is a pain to take off my boot cowl every time I fill up so I like having the extra oil capacity. A few extra pounds are worth the hassle to me. |
Tell me more about the KF oil tank. Size, where does it mount, mounting bracket?
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Thu Dec 17, 2009 10:21 am Post subject: Oil Injection reservoir size? |
At 04:12 PM 12/16/2009, you wrote:
| Quote: | What size oil injection reservoir are you two stroke people
I've been running two liters for the past few years. As Paul says, it
just means you carry more in the baggage compartment when you want to
go long. I've run as long as 4 1/2 hours between re-fills with no
problem. Supposedly I could go longer, but I don't, so I don't really
need more capacity.
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar
Deceased K-IV 1200
A glider pilot too. |
Pat Reilly
Posted: Thu Dec 17, 2009 11:23 am Post subject: Oil Injection reservoir size? |
Tom, My tank mounts on the top of the firewall behind the 582 Rotax engine. My plane was built with a 912 engine and a door on the top of the cowling. The door is directly over the oil reservoir filler cap. I don't have to remove the cowling to check or add oil. Worked out great. I did mount the tank a 1/2" too high and had to lower it to clear the door hinge.
Pat Reilly
mod 3582 Rebuild
Rockford, IL
On Thu, Dec 17, 2009 at 9:54 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
[quote]--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
akflyer wrote:
| Quote: | I got the KF oil tank from John Mcb at kitfox. It is a pain to take off my boot cowl every time I fill up so I like having the extra oil capacity. A few extra pounds are worth the hassle to me.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=277909#277========================
he Contribution link below to find out more about
lder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
-Matt Dralle, Li - The Kitfox-List Email Forum -
fox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List< - MATRONICS WEB FORUMS -
= --> h
akflyer
Posted: Thu Dec 17, 2009 11:31 am Post subject: Re: Oil Injection reservoir size? |
Mine is on the back side of the firewall, mounts with Adel clamps. I will get some pics of it when I get home next week. Some cowlings have an oil door in the them, but mine doesnt. I keep it outside and dont need another water leak in the cabin. I like being able to run long trips and not have to refill the oil. Last one I brought 6 extra Qts with me and did not use one of them till I got back home. I burned 70 gallons of fuel and used less than half the oil.
I think the tank was 90 bucks or something like that from KF.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Pat Reilly
Posted: Thu Dec 17, 2009 12:06 pm Post subject: Oil Injection reservoir size? |
Lennie, My tank is on the front of the firewall so any leaks would not enter the cabin. I mounted mine where a felow out in Maine that sold me the tank had his. He sent me pictures.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Dec 17, 2009 at 1:31 PM, akflyer <akflyer_2000(at)yahoo.com (akflyer_2000(at)yahoo.com)> wrote:
[quote]--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com (akflyer_2000(at)yahoo.com)>
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 (87 hrs and counting on the rebuild)
IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p=277960#277960
ber is the Annual List Fund Raiser. Click on
-= * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
ronics List Features Navigator to browse
s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
dave
Posted: Thu Dec 17, 2009 12:59 pm Post subject: Re: Oil Injection reservoir size? |
Guys, a properly adjusted 582 oil injection will only give 50 to 1 ratio at wide open throttle NOT all the time.
In cruise you might see 65 to 1 to 70 to 1 area.
At idle closer to 90 to 1 or 100 to 1 .
The oil injection ratio is dependant on throttle position.
Pictures of injection bottom mounting on Kitfox.
http://rotaxaircraft.com/forum/viewtopic.php?f=8&t=156
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
akflyer
Pat Reilly
Posted: Thu Dec 17, 2009 3:54 pm Post subject: Oil Injection reservoir size? |
Kitfoxers, I have the oil reserve bottle pictured. If someone needs it, you can have it for $10 + shipping.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Dec 17, 2009 at 4:23 PM, akflyer <akflyer_2000(at)yahoo.com (akflyer_2000(at)yahoo.com)> wrote:
dave wrote:
| Quote: | Guys, a properly adjusted 582 oil injection will only give 50 to 1 ratio at wide open throttle NOT all the time.
news flash on the bold huh :snack:
thought we kicked the crud outa this one last week.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
http://forums.matronics.com/viewtopic.php?p=277987#277987
Tom Jones
Posted: Thu Dec 17, 2009 6:04 pm Post subject: Re: Oil Injection reservoir size? |
| akflyer wrote: | Mine is on the back side of the firewall, mounts with Adel clamps. I will get some pics of it when I get home next week. Some cowlings have an oil door in the them, but mine doesnt. I keep it outside and dont need another water leak in the cabin. I like being able to run long trips and not have to refill the oil. Last one I brought 6 extra Qts with me and did not use one of them till I got back home. I burned 70 gallons of fuel and used less than half the oil.
I think the tank was 90 bucks or something like that from KF. |
Thanks, I would like to see this setup. I have a panel tank so probably not enough room behind the fire wall, but plenty in front. Behind the fire wall would probably be better if there is room as my cg is nearer the forward limit.
I plan to fabricate an oil door for checking and adding oil.
37.71 KB |
9151 Time(s) |
Classic IV
Ellensburg, WA |
dave
Posted: Sat Dec 19, 2009 3:54 am Post subject: Re: Oil Injection reservoir size? |
Tom,
My oil bottle is on front side of firewall. I just put up a movie and when we take off you can see the access door for oil bottle.
Let me know if you need a better pic of it .
http://www.youtube.com/watch?v=dLKDyCSmo7s
| Tom Jones wrote: | | akflyer wrote: | Mine is on the back side of the firewall, mounts with Adel clamps. I will get some pics of it when I get home next week. Some cowlings have an oil door in the them, but mine doesnt. I keep it outside and dont need another water leak in the cabin. I like being able to run long trips and not have to refill the oil. Last one I brought 6 extra Qts with me and did not use one of them till I got back home. I burned 70 gallons of fuel and used less than half the oil.
I plan to fabricate an oil door for checking and adding oil. |
