		daveleikam(at)wi.rr.com Guest
				 Posted: Tue Nov 04, 2008 9:32 pm    Post subject: Wing tip |
				I started fitting my wingtips and found the right  one to be about 1/4 inch short on the trailing edge in relation to the  aileron.  Vans says just build up the edge and finish.  Anyone have  this problem and what is the easiest way to lengthen the edge?
  Dave Leikam
 RV-10 #40496
 N89DA  (Reserved)
 Muskego, WI
		speckter(at)comcast.net Guest
				 Posted: Wed Nov 05, 2008 4:57 am    Post subject: Wing tip |
				Lay up a 2 ply flat layup on your table with release agent.  Cut a piece of this and slip it between the top and bottom trailing edges and adjust to the length you need and glue it in with cabosil mix. Let harden and then fill the top and bottom with chopped fiber mix to make it flush with the rest of the top and bottom.  Finish as usual.
 Gary Specketer
 40274 Flying
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
  Sent: Wednesday, November 05, 2008 12:32 AM
  To: RV-10 matronics
  Subject: Wing tip
 Dave Leikam
  RV-10 #40496
  N89DA (Reserved)
  Muskego, WI
    	  | Quote: | 	 		  |   http://www.matronics.com/contribution  | 	  01234567890123
				 Posted: Wed Nov 05, 2008 6:57 am    Post subject: Wing tip |
				That's a switch!!! Back in the day they were an inch too long!! Gary hit the fix right on the head...much easier to extend than chop off!
 Rick S.
 40185
		kdbelue(at)charter.net Guest
				 Posted: Wed Nov 05, 2008 7:36 pm    Post subject: Wing tip |
				My right wing tip was 1/4" short and I fixed it  the same way as Gary said below.
  Kevin Belue
  RV-6A Flying
  RV-10 Flying
  [quote]   ---
		n277dl
				 Posted: Fri Dec 18, 2009 1:54 pm    Post subject: Re: Wing tip |
 PostPosted: Wed Nov 05, 2008 4:57 am    Post subject: Wing tip 	Reply with quote
 Gary Specketer
 40274 Flying
 Guys,
    See if I understand this correctly.  I need to slit the end of the wing tip and then slide the "2 ply flat layup" in the split wing tip...   Then glue in, chopped fiber mix, etc.
 Will the chopped fiber work by itself.  Guess the concern is it's such a narrow point that it'll easily be broken off without the cloth base?
 Thanks in advance.  I'm going to lay up the strip but wait on a reply to slitting the wing tip before going forward.
 Doug
  _________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
				 Posted: Fri Dec 18, 2009 4:24 pm    Post subject: Wing tip |
				Call me and I can walk you through the process.
 Gary Specketer
 770-403-3450
				 Posted: Fri Dec 18, 2009 8:53 pm    Post subject: Wing tip |
				I assume you are trying to lengthen your wingtip trailing edge?   Works
 great.  Just be sure the slit is straight along the trailing edge and try to
 use a cutter which will leave the gap the exact thickness of the layup.  I
 used a piece of trimming from the edge flange of the wingtip that fits under
 the skin rather than a new lay-up.
 Dave Leikam
 RV-10 #40496
 N89DA
 Muskego, WI
