		jridgway
				 Posted: Sun Dec 20, 2009 4:31 pm    Post subject: can someone help me |
 RDoss Don't give up on eBay.  Ebay will do 90 day daily searches for anyone.  Search under the "Camera & Photo" section so you cover all photo items.  Possible Searches:  First use quotes for all sea
 Oh, God! Yeah, I understand that must be really, really tough My classmates does the same thing Just because a surten film shows up, they all suddenly think they're going to High Shcool and live exa
 signals within the polypeptide chain and of them failed to display a sufficient bind- the fragileX syndrome RNAbinding protein
 morphology, location, and behavior. The Sometimes viruses, like HIV-1, use a coreceptor (yellow) for invade critical sequences within the HCV
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dick Maddux
				 Posted: Mon Dec 21, 2009 7:00 am    Post subject: F210 high readings |
				Jack ,
   You are probably reading liters instead of gals. I think setting number 2 is gals. Check your operators manual. I have had the unit swap the settings by itself.
                                                    Dick Maddux
                                                    Milton,Fl
		akflyer
				 Posted: Mon Dec 21, 2009 7:46 am    Post subject: Re: F210 high readings |
				 	  | jridgway wrote: | 	 		  HI..
 Just installed a F210 on my KF3/582 and getting very very high readings (20GPM). I double checked indicator and it was US GAL/MIN.
 I flew today for 1 hard hour and only REALLY burned 6 gal.
 Documentation says may be air in line. Anybody else have this problem?
 Any ideas??
 Transducer is a new replacement.
 thanks..jack |
 set it to gallons per hour.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
		jridgway
				 Posted: Tue Dec 22, 2009 4:04 pm    Post subject: Re: F210 high readings (SOLVED !!!) |
				OK...found out today that the F210 seems to reset to liters after engine shutdown. It seems fine when I reset it to gal/hr before each flight. Just made it part of my pre-flight checklist.
 thanks for all the comments...Jack
 WONDERING if I isolated the F210 during start up if it would work OK..voltage/current spike during start up???
